westina Samba Member
Joined: October 01, 2017 Posts: 368 Location: Beacon/NY
Posted: Fri Apr 27, 2018 11:00 am Post subject: TITAN TS50 pro finish HVLP for DIY paint project |
Hi, i have recently purchased this turbine sprayer. I don't have much experience but not looking for a show room quality results. Can someone take a look at it and let me know if it should work or not?
quote:
This 4 stage turbine system offers higher performance for the most demanding spray finishing applications.
It delivers 8 psi and 82 cfm to achieve the highest level atomization and production.
FEATURES
4 stage turbine - 8 psi at 82 cfm
20' (6 m) high quality air hose with quick disconnect fitting
Weight: 28 lbs. (12.7 kg)
CONFIGURATIONS
773-604 CE (110 volt)
ihttp://www.pawnplex.com/tools/ts50/index.htm
its the same unit as in this listing
since this units are 18 years old, different nozzles, tips are not available. i believe i can hook up a newer model gun and switch tips as needed. The gun that came with the unit uses suction type(paint container is at the bottom of the gun) system. I have read on the internet that gravity feed guns needs less psi so maybe i can go that route if this sprayer is not sufficient? Thanks |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Fri Apr 27, 2018 1:30 pm Post subject: Re: TITAN TS50 pro finish HVLP for DIY paint project |
Turbine sprayers are good but they're not HVLP & use a siphon spray gun, so don't go trying to re-engineer a good spraying system before you even try it out!
Buy some paint & clear and practice with it. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Fri Apr 27, 2018 4:16 pm Post subject: Re: TITAN TS50 pro finish HVLP for DIY paint project |
Mike Fisher wrote: |
Buy some paint & clear and practice with it. |
Thanks , it would be nice if i had automotive paint laying around so i can try a bit. I am thinking about using napa paint i believe they are single stage simple paint. i have seen people using turbine with success but not yet seen exact machine being use. Some more expensive models should be ok i believe,
Once mixed, i would expect the paint i am planning to use somehow in thin consistency, hoping the turbine unit wouldn't have hard time pushing. |
Dake Samba Member
Joined: September 02, 2014 Posts: 481 Location: Georgia
Posted: Fri Apr 27, 2018 6:15 pm Post subject: Re: TITAN TS50 pro finish HVLP for DIY paint project |
I has the TP tools turbine that seems to work vary well. I got it after I saw the paint a guy did in in his driveway that looked great to me. But I'm sure he has had some practice with it. So far i have done a few small things that turned out better than any of my compressor painting. |
Posted: Sat Apr 28, 2018 5:17 am Post subject: Re: TITAN TS50 pro finish HVLP for DIY paint project |
Dake wrote: |
Do u know the specs for your turbine? This one is a small, portable 8 PSI unit. |
Dake Samba Member
Posted: Sat Apr 28, 2018 11:16 am Post subject: Re: TITAN TS50 pro finish HVLP for DIY paint project |
NAPA red looked good on a squareback I stored for a while. They mixed clear & color for the last couple coats & sprayed it all the same day. _________________ https://imgur.com/user/FisherSquareback/posts
jspbtown Samba Member
Posted: Mon Apr 30, 2018 1:47 pm Post subject: Re: TITAN TS50 pro finish HVLP for DIY paint project |
Napa sells a basecoat/clearcoat paint.
If you are thinking of using that premixed single stage stuff they sell in some general colors then don't do it. I sprayed some on some exercise equipment and it was awful.
If you want a cheap, easy to spray single stage check out Kirker. |
Dake Samba Member
Posted: Sat May 05, 2018 5:52 pm Post subject: Re: TITAN TS50 pro finish HVLP for DIY paint project |
Used it this weekend
Posted: Sun May 13, 2018 3:18 pm Post subject: Re: TITAN TS50 pro finish HVLP for DIY paint project |
looks great. |
vwkirb Samba Member
Joined: January 16, 2007 Posts: 812 Location: Athens, GA
Posted: Sun May 13, 2018 5:44 pm Post subject: Re: TITAN TS50 pro finish HVLP for DIY paint project |
Love the color!
What kind of paint? It will look even better wetsanded buffed and waxed _________________ Andrew Kirby |
