kirk knighton Samba Member
Joined: January 23, 2005 Posts: 282 Location: Seattle
Posted: Fri Apr 27, 2018 3:35 pm Post subject: Creaky clutch pedal on my '85 Cabriolet |
Man this is driving me crazy. Just this week my clutch pedal started sounding and feeling creaky, like an old man's arthritic knee. I looked up there under the dash and saw where it pivots and sprayed a bunch of lube but to no avail. Creaky as ever! What can be done? |
Joined: August 31, 2013 Posts: 12857 Location: North Carolina
Posted: Fri Apr 27, 2018 6:27 pm Post subject: Re: Creaky clutch pedal on my '85 Cabriolet |
Replace the cable. When they start getting noisy, they start binding & this increased pressure will cause the cable stop at the top of the pedal bracket to break off (if it hasn’t done so already & this is what you’re actually hearing.). Be sure to lube the new cable before reinstalling, I use either spray chain lube or assembly lube for the thick viscosity. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sat Apr 28, 2018 8:38 am Post subject: Re: Creaky clutch pedal on my '85 Cabriolet |
Oh wow - is the cable difficult to find? A new one that is?
And the job itself? I'm looking at the thing in the engine compartment, looks pretty straightforward. |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
kamzcab86 Samba Moderator
Posted: Sat Apr 28, 2018 12:04 pm Post subject: Re: Creaky clutch pedal on my '85 Cabriolet |
kirk knighton wrote: |
Oh wow - is the cable difficult to find? A new one that is? |
Available at NAPA and other local stores, or through online retailers. I always keep a spare cable in the trunk... just in case.
If you have a Bentley Service Manual (and you should), the procedure is explained. And, yes, it's pretty straightforward. The most complicated part is adjusting the cable to spec (it's easier to adjust if you make your own 12mm adjusting gauge as shown in the diagram):
- Get two wrenches out. The lock nut is 17mm; the second wrench will depend on the cable.
- Put the 17mm wrench on the lock nut; put the second wrench on the sleeve or upper nut, whichever your cable uses.
- Loosen the lock nut and put the wrenches aside.
- Lift the release arm up using the cable sleeve.
- While still holding up the release arm, insert your 12mm adjusting gauge: If it easily inserts, turn the adjusting disc down until it rests on the gauge. If it won't insert, turn the adjusting disc up until it easily fits, then turn the adjusting disc back down until it rests on the gauge.
- Release the release arm/cable.
- Using the wrenches, tighten the lock nut.
- Remove the adjusting gauge.
- Go for a test drive.
Note: There should be a fat rubber grommet that the adjusting disc sits on. If this is worn or missing, replace it. There should also be a rubber washer that wraps over the cable flange; if this worn, broken, or missing, replace it.
Old:
New:
Butcher wrote: |
I have never had a cable make noise... |
I have: Before one broke; when one got stiff as a board. However, given these cars' ages, definitely inspect the carrier tube. _________________ ~Kamz
2016 Golf GTI S
Posted: Sat Apr 28, 2018 12:14 pm Post subject: Re: Creaky clutch pedal on my '85 Cabriolet |
Great info, thanks!
I'm guessing the carrier tube is the tube the cable rides in. Is that something easily obtained new as well as the cable?
I just had a good look at the pedal and bracket; the bracket is NOT cracked or broken ( thank God! ).
In some other forums they talk about spraying some white lithium grease on the various hinge points of the pedal, and some people found that solved the problem. I tried to squirt some 3-in-one up there but just made a mess.
I should add that the car has only 65,000 miles on it. Maybe the cable is not so worn after all? |
Posted: Sat Apr 28, 2018 6:38 pm Post subject: Re: Creaky clutch pedal on my '85 Cabriolet |
Even if the cable is ok, I would replace it anyway. They are not that expensive and sure beats shifting without a clutch till you get home [when it breaks]. |
Posted: Sat Apr 28, 2018 9:00 pm Post subject: Re: Creaky clutch pedal on my '85 Cabriolet |
Good idea.....which reminds me of a story in my life.
Years ago - 1978 I believe it was, in Portland Oregon - I was driving a friend's Corvair Van late at night. Just leaving my girlfriend's house, I turned onto the main road towards my house and right after I shifted into 2nd gear the clutch cable broke. SNAP! And so there I was, putt-putting in 2nd gear, with about 8 miles to go to my house.
Well well, I was able to continue doing just that, going maybe 20 mph the whole way home, every light green, not a cop car to be seen. I slid into my driveway and popped it out of gear and shut off the engine. Home safe! |
Posted: Sun Apr 29, 2018 1:37 pm Post subject: Re: Creaky clutch pedal on my '85 Cabriolet |
I'm guessing the carrier tube is the tube the cable rides in. Is that something easily obtained new as well as the cable? |
The cable, as stated previously, is easy to come by at your local parts stores. The carrier tube, if broken -- usually it's the weld that fails -- requires a DIY repair.
That aforementioned cable that was stiff as a board in my car had about that many miles on it, if not less. Mileage means nothing... replace it. _________________ ~Kamz
2016 Golf GTI S
Posted: Wed Jun 27, 2018 1:18 pm Post subject: Re: Creaky clutch pedal on my '85 Cabriolet |
I finally got my Cabi to the local VW shop and he replaced the cable with a real nice German one. The clutch is smooth as silk now!
The mechanic confirmed that the stiff old cable was the source of the creakiness. He also confirmed that the pedal bracket takes the brunt of the tension from that stiff cable and could break. Luckily for me that didn't happen.
Thanks to all here for the great advice! |
