Side view mirrors?
MConstable
MConstable is offline
PostPosted: Fri Apr 27, 2018 5:52 pm    Post subject: Side view mirrors? Reply with quote
Iím sorry if this has been covered, Iím searching but I canít find the answer.
My Thing is my daily driver, Iím 52, eyesight is good, but as far as my side mirrors go, I need bigger.
Are the bay window bus ones bigger than the stock Thing ones?
1974 Thing
mondshine
mondshine is offline
PostPosted: Sat Apr 28, 2018 7:24 am    Post subject: Re: Side view mirrors? Reply with quote
The "real" Thing passenger side mirror has a raised stalk to position the mirror higher on the car. This helps a lot, especially when the side windows are installed. I think the Bus mirrors have the same sized glass as Thing mirrors.
There are many Jeep aftermarket mirrors available (check Amazon, just as an example), which the creative fabricator could adapt to the upper door hinge mounts. The threaded hole mount might be too flimsy for something like this.
Just out of curiosity, I've seen many "P.R." photos of Things with the side mirrors oriented vertically. I have always had mine horizontal, assuming it would give a wider view.
Ron Domeck
Ron Domeck is offline
PostPosted: Sat Apr 28, 2018 7:28 am    Post subject: Re: Side view mirrors? Reply with quote
Bus and Thing share the same mirror head and glass.
MConstable
PostPosted: Sun Apr 29, 2018 3:29 am    Post subject: Re: Side view mirrors? Reply with quote
Thanks guys!
1974 Thing
sam_w
sam_w is offline
PostPosted: Sun Apr 29, 2018 8:16 am    Post subject: Re: Side view mirrors? Reply with quote
you could try to get a 74 passenger mirror, they have a bit longer arm, better to see with.
They are not easy to find. but come up every now and then.
63 singlecab
73 thingster
