tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Sat Apr 28, 2018 6:55 am Post subject: How to Install Intermittent Wipers |
I've long hated bumping the wiper switch in misty weather every few seconds, so I set about doing something about it. For starters, I found this:
https://store.qkits.com/automotive/wind-shield-wiper-timer-module-mxa041.html
The wiring instructions are ambiguous at best, so I'll show you how I wired it to get it to work with a late bus.
Note that the green wire coming from the switch DOES NOT have a black stripe on it. I put on there so you could see where the wires go.
Sorry about my shoddy drawing and spelling skills, I threw it together in a hurry.
Some things to note about this module:
-It clicks when it operates not unlike a flasher relay
-When mounted in the dash the only thing holding it on are 4 solder joints; there are 4 holes in the side of the pcb which should be used to mount it via a bracket (which is what I did)
-It's an open pcb so an enclosure might be good to protect it from solder bloom and shorts. _________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's) |
Bleyseng Samba Member
Posted: Sat Apr 28, 2018 7:47 am Post subject: Re: How to Install Intermittent Wipers |
Easy way is to install the Champange brown wiper switch and wiring harness to the wiper motor and the relay. Bam, done the VW way and it works great _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Sun Apr 29, 2018 1:07 pm Post subject: Re: How to Install Intermittent Wipers |
Yeah, but where ya gonna find a Champagne intermittent wiper switch?
Also, you may have to modify your plastic housing around the steering wheel to allow the switch to move into intermittent position.
My SC, with the Z01 foul weather package, had this stock. I did have to source an intermittent module, and found this:
http://www.busdepot.com/111955531
It is not, however, programmable like the original was. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Posted: Mon Apr 30, 2018 7:46 am Post subject: Re: How to Install Intermittent Wipers |
jtauxe wrote: |
It is not, however, programmable like the original was. |
I got mine from Ken at thebusco _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
