Axel Andersson Samba Member
Joined: June 03, 2011 Posts: 132 Location: Sweden - Europe
Posted: Sun Apr 29, 2018 4:09 am Post subject: 36 hp Pushrods - Wood sticks - Advice |
What are your experiencies about the wood sticks inside the pushrod tubes?
Remove them or working well if they have good flow?
Risks of wood blocking oil flow?
Last edited by Axel Andersson on Thu May 03, 2018 3:53 am; edited 1 time in total |
fl59bug Samba Member
Joined: November 23, 2005 Posts: 1976 Location: North Carolina
Posted: Mon Apr 30, 2018 4:55 am Post subject: Re: 36 hp Pushrods |
Is there really wood inside of these one-piece pushrod/lifters? If so that would discourage me from spraying cleaner down them like I do my 40hp pushrods!
When I freshened up my 36hp and added a new top end I deliberately steered clear of cleaning the pushrods for this reason.
With the vw engines, oil obviously flows from the cam end out to the rocker end through the pushrods to lube the rockers, so it's hard to imagine there being wood inside. Still, that is what I've heard elsewhere about the wood being in them. It just seems like it would swell up and block the flow as you mentioned. |
Posted: Wed May 02, 2018 6:28 am Post subject: Re: 36 hp Pushrods |
Anyone here have experiencies and suggestions on this? |
TomSimon Samba Member
Posted: Wed May 02, 2018 7:06 pm Post subject: Re: 36 hp Pushrods |
The wood is usually disintegrated in the 36hp engines I've taken apart... I think it's original intent was to dampen the high frequency vibrations. _________________ 2-time NASA Pro Racing Champion, Bonneville 130 Club and 150 Club Memeber, BRS Pro Gas racer |
Posted: Thu May 03, 2018 12:40 am Post subject: Re: 36 hp Pushrods |
TomSimon wrote: |
The wood is usually disintegrated in the 36hp engines I've taken apart... I think it's original intent was to dampen the high frequency vibrations. |
I have taken two engines apart recently, and on those the wood is intact.
Would it be wise to run without them? Experiencies? |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Thu May 03, 2018 5:24 am Post subject: Re: 36 hp Pushrods - Wood sticks - Advice |
my 200K 36 HP engine still had the wood in them as have all the original PR's I've seen.
Even when a built my stroker engine I used PR's with the wood still intact. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Thu May 03, 2018 10:02 am Post subject: Re: 36 hp Pushrods - Wood sticks - Advice |
60ragtop wrote: |
Even when a built my stroker engine I used PR's with the wood still intact. |
I second the OPs question regarding the wood swelling - would spraying carb/brake cleaner in the pushrods be a bad idea? This is a step I normally take when rebuilding any engine, but maybe not on the 36hp if its a problem. |
Mr. Motorhead Mad Scientist
Joined: January 06, 2004 Posts: 717 Location: Practitioner of 36hp alchemy
Posted: Thu May 03, 2018 3:06 pm Post subject: Re: 36 hp Pushrods - Wood sticks - Advice |
I find the wood sticks in about half the lifters that go to get reground. I pull them out and leave them out because most are so gunked up. I would imagine the oil flow is better as well. All new lifter sets come without...... _________________ 30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy |
snowbug Samba Member
Joined: June 12, 2005 Posts: 167 Location: Oshawa Ontario Canada
Posted: Sat May 12, 2018 1:49 pm Post subject: Re: 36 hp Pushrods - Wood sticks - Advice |
Not sure if the wood chop sticks act to dampen vibration or act as an oil pump. They slide back and forth and push oil to the top ? _________________ Old enough to remember THRILLS, the gum that tastes like soap. |
