iattelbrum Samba Member
Joined: June 02, 2006 Posts: 33 Location: MUGELLO FLORENCE ITALY
Posted: Mon Apr 30, 2018 5:16 am Post subject: Engine code ? |
Hi there ,
can you please help me to sort out year of production of this engine ?
Thanks in advance |
wimkever Samba Member
Joined: July 16, 2004 Posts: 411 Location: Holland (the Netherlands)
Posted: Mon Apr 30, 2018 6:04 am Post subject: Re: Engine code ? |
iattelbrum wrote: |
Hi there ,
Thanks in advance |
Based on the information you've provided, it must be between the years 1936 and 2003 _________________ a beetle is like a cocker spaniel, always funny but sometimes not listening |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Mon Apr 30, 2018 6:21 am Post subject: Re: Engine code ? |
This one ?
Posted: Mon Apr 30, 2018 12:39 pm Post subject: Re: Engine code ? |
My mystake .....for some given reason I did not attach the pic.
Picture is now on the post |
Yustrn JHC Controla
Joined: August 01, 2000 Posts: 5478 Location: Ovaland, CA
Posted: Mon Apr 30, 2018 3:27 pm Post subject: Re: Engine code ? |
many thanks
it looks like a 1948 but it does not have the "zero" in front of the number.
What is your opinion ? |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1461 Location: Finland
Posted: Tue May 01, 2018 12:38 am Post subject: Re: Engine code ? |
it looks to me that the A at the end is not really an A but it looks to be more like a "slash" which ends on top of the welding area |
peter schepens Samba Member
Joined: April 17, 2003 Posts: 1014 Location: belgium Caesars camp
Posted: Tue May 01, 2018 12:46 am Post subject: Re: Engine code ? |
Could the A mean Austausch? It seems that the Zundfolge is partial grinded.. Just an idea. _________________ Zelensis, glassfibre body made in Belgium , disigned and built on a VW platform About 25 body's built.
Hebmuller info wanted for http://www.hebmueller-registry.com/home.html |
rod_vw Samba Member
Joined: December 20, 2006 Posts: 416 Location: Shropshire, UK
Posted: Tue May 01, 2018 2:22 am Post subject: Re: Engine code ? |
DUBIOUS!
It all looks wrong. _________________ Rod,
Please visit http://www.historicvws.org.uk
https://www.facebook.com/historicvwclub/
1946 Beetle (Back on the road after over 50 years! Last major outing - Hessisch Oldendorf 2022)
2016 T6 Selfbuild Camper and a LWB MAN TGE in build. |
Posted: Tue May 01, 2018 12:11 pm Post subject: Re: Engine code ? |
what do you means by "it all looks wrong ?"
The only thing I know is that the car , most likely , was produced for Austrian market.
It has all accessory as old engine including the heater duct. |
rod_vw Samba Member
Posted: Tue May 01, 2018 12:30 pm Post subject: Re: Engine code ? |
Sorry, I was looking at the casting marks, the poor visibility of the firing order markings and the inclusion of the 'A' after the numbers.
Maybe a different view of that would be convincing enough to believe that it was never an 'A' but a numerical digit. As far as I am aware VW (in this era) did not use 'Alpha' characters, they were all numeric.
If we ignore the last character i.e. 1-115107 then the engine was made in the latter part of 1948.
If we consider it as 1-115107? then it was made in September 1955
{Dating from Progressive Refinements.}
In 1948 it would have been a 25ps unit and in 1955 a 30ps one. Which is it?
Now I hope that you understand my comment. _________________ Rod,
Posted: Tue May 01, 2018 1:02 pm Post subject: Re: Engine code ? |
Rod,
i really appreciated your explanation and the time you spent to make it clear to me .....I am not a specialist !
I do believe that the last carhacter is a slash instead of a "A" .
can it be the case ?
How can I determine if it is a 25hp or 30 hp ?
Tnx again |
rod_vw Samba Member
Posted: Tue May 01, 2018 1:31 pm Post subject: Re: Engine code ? |
Even the '/' or "\" would not be correct but let us not be too concerned. It is an early VW engine and hopefully worthy of further use.
As a quick identity to differentiate between 25ps & 30ps if the cylinder heads are on the engine and covered by their tinware a 30ps will have raised pressings 'outboard' of each pair of plug holes to clear the cylinder head securing nuts. If it is a 25ps then these are absent as the head studs do not protrude into this area.
If the covering tinware is absent but the heads are in place then notice that the head securing nuts are normal hexagon on a 30ps and special recessed socket nuts on a 25ps.
If no cylinder heads but cylinders visible then the nominal bore size of a 30ps is 77mm and 75mm for a 25ps.
If no cylinders etc then it is difficult without detailed examination to determine the difference. _________________ Rod,
Splitdog Samba Split Personality
Joined: February 16, 2004 Posts: 4125 Location: Planet VW
Posted: Tue May 01, 2018 2:25 pm Post subject: Re: Engine code ? |
Factory rebuild? _________________ CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker |
kdf38 Samba Member
Posted: Tue May 01, 2018 8:44 pm Post subject: Re: Engine code ? |
Are there 3 circles with numbers on the Left side of the generator stand or near the center seam of the case? Are there any dates on case near the oil pump or oil dip stick area?
Mike |
Posted: Wed May 02, 2018 10:25 pm Post subject: Re: Engine code ? |
Virtanen,
can you provide me more details to understand your assumption ?
Anything more I have to cross check on the engine ?
M |
62ItalianRagtop Samba Member
Posted: Thu May 03, 2018 6:39 am Post subject: Re: Engine code ? |
Ciao, che mezzo stai restaurando ? Apri un topic sul restauro _________________ LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
http://tettodistraccio.blogspot.com/ |
Posted: Thu May 03, 2018 7:06 am Post subject: Re: Engine code ? |
What is the casting date on the case?
May be on the left side of the generator stand. It should have a circle with three numbers. They'll be one on each case half.
Look through this thread.
https://www.thesamba.com/vw/forum/viewtopic.php?t=380362 |
