Where do they usually break?...
carsdlt
carsdlt is offline
PostPosted: Mon Apr 30, 2018 10:09 pm    Post subject: Where do they usually break?... Reply with quote
... Clutch and accelerator cables, that is. I find I'm getting more free play in my clutch the last 5 K miles,so methinks the cable may be starting to go south and my gas pedal is getting a stiff spot when about 3/4 to the floor. Are there areas on these rascals that I can eyeball to see if failure is near?
Thanx, DLT
'73 181 stock 1600 - "Dr. Bombay"
"If it works, don't fix it....let it break on its own."
YDBD
YDBD is offline
PostPosted: Mon Apr 30, 2018 10:30 pm    Post subject: Re: Where do they usually break?... Reply with quote
At the ends where the pieces are swaged to the cable. But also the clutch pedal hook can also wear and break.
Accelerator cables don't break too often, usually just come out of the barrel clamp.
The hole for the acc. cable on the pedal may get worn and the worm end can slip out. I replaced mine with the locking loop type for buggies.
http://chircoestore.com/h-d-dune-buggy-throttle-cable-9-foot-long.html
'56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing"
74 Thing
74 Thing is offline
PostPosted: Tue May 01, 2018 7:00 am    Post subject: Re: Where do they usually break?... Reply with quote
Where the Bowden tube and metal clutch tube meet there is wear in the Bowden tube over time and it frays the cable.
Only one way to find out-pull the pedal cluster and remove the cable.
carsdlt
carsdlt is offline
PostPosted: Tue May 01, 2018 9:51 pm    Post subject: Re: Where do they usually break?... Reply with quote
Ok thanx. Soon as I get a chance I'll check 'em let ya know.
Thanx, DLT
Wildthings
Wildthings is offline
PostPosted: Wed May 02, 2018 2:59 pm    Post subject: Re: Where do they usually break?... Reply with quote
Check for wear on the forward end of the cable as well.
