THall Samba Member
Joined: August 25, 2010 Posts: 324 Location: Verona, WI
Posted: Wed May 02, 2018 9:01 am Post subject: Sealant for breather box cork gasket? |
I'm installing a new cork gasket for the chimney breather box on my '78 2.0 FI engine. Is it recommended to use any type of sealer between the case and gasket and/or gasket and box?
Not positive, but I think in the Raby Bug Me video he installs it without? _________________ '78 Westy - 2.0 FI |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51156 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed May 02, 2018 9:03 am Post subject: Re: Sealant for breather box cork gasket? |
A little grease on the engine side is all it needs, maybe some Permatex 2 or Curil T on the breather box side if you wish. Treat it like a rocker cover gasket. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Wed May 02, 2018 9:11 am Post subject: Re: Sealant for breather box cork gasket? |
half tube of red silicon will do the trick.
(this is sarcasm ^^)
i need to do this job on a customer's bus, and I plan on using either Curil T or a very thin smear of permatex ultra-black for the gasket to box, then grease from gasket to engine case. of course all sealing surfaces will be cleaned and degreased thoroughly prior to installation. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4524 Location: Oklahoma City, OK
Posted: Wed May 02, 2018 10:33 am Post subject: Re: Sealant for breather box cork gasket? |
I have never used any sealant there, no need, vapor only, if you have any oily film then your crankcase has too much pressure and that needs taken care of. |
raygreenwood Samba Member
Posted: Wed May 02, 2018 11:03 am Post subject: Re: Sealant for breather box cork gasket? |
The cork gasket on the breather box is a BIG source of vacuum/gas leak. Not big in volume....but chronic. This is not as big of an issue with L-jet as it is with D-jet because you do not have straight manifold vacuum to the case.
I take any of the Permatex ultra....but Ultra black is the most oil resistant....and run a thin even layer on the box side only. Apply it to the box and set the box into postion on the case nice and square with just a little bit of weight. You do not want to squeeze the sealer out. Let it dry. The cork seal is perfectly adhered now to the breather box.
Apply a paper thin, smooth layer of Ultra black to the case side of the gasket. I use a roller so its a perfect layer. Takes about 30 seconds. Just let it dry. Do not attache it to the case until its dry. You are not trying to glue it to the case.
The RTV makes a very thin compressible sealing layer....that does not allow the oil to attack the rubber compound the cork gasket is made of....so it stays pliable for ages...and also prevents most of the shrinkage it gets with age.
The cork gasket can easily seal perfectly for over 100k miles this way.
Ray |
tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Wed May 02, 2018 5:09 pm Post subject: Re: Sealant for breather box cork gasket? |
raygreenwood wrote: |
But with L-Jet the big fat hose that comes off the s-boot is metered air, so if it's leaking at that seal, unmetered air is entering the system making the L-Jet run lean and making your heads melt at high speed. I actually had a valve seat sink for this very reason. So yeah, it is a big deal _________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's) |
Posted: Thu May 03, 2018 7:51 am Post subject: Re: Sealant for breather box cork gasket? |
tootype2crazy wrote: |
But with L-Jet the big fat hose that comes off the s-boot is metered air, so if it's leaking at that seal, unmetered air is entering the system making the L-Jet run lean and making your heads melt at high speed. I actually had a valve seat sink for this very reason. So yeah, it is a big deal |
Yep....as I noted...I KNOW it is a problem with L-jet.....but its more of a hard to track pain in the ass lean/rich driveability issue.....than a big time run or not run issue like with D-jet. This is because the vacuum on L-jet where the oil breather hose dumps into.....which is between the AFM and the OUTSIDE/atmospheric side of the TB.....is very low and the volume of air flowing from the PCV diaphragm valve.....is relatively low.
I fully agree......its still significant on L-jet.....but compared to D-jet....where the PCV hose is flowing directly to the manifold downstream of the TB snd can have as much as 15" of vacuum on it and dumps into the manifold about 1/2" from the manifold pressure sensor (MPS) inlet.....having a leak at the gasket on the oil breather causes HUGE issues.
A leak can swing you to full enrichment...because a vacuum leak is read by the MPS as throttle opening. Ray |
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Fri May 18, 2018 4:37 pm Post subject: Re: Sealant for breather box cork gasket? |
Sorry to hijack this thread.
I'm refurbing my breather box right now. When I removed the pcv valve (or the equivalent) I noticed that there was a seal or o-ring between it and the box. Is this stock? I don't see any reference of it in the bentley. In fact I don't see any reference to the valve itself in the book either (I looked under engine and FI). If this is normal, does anyone have a part # or a link to a replacement?
Besides the seal it looks like RTV was used on the seal and to seal the valve to the box.
_________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
Posted: Fri May 18, 2018 4:45 pm Post subject: Re: Sealant for breather box cork gasket? |
Yes that's stock, one of those O ring assortments from Harbor freight should have something that fits over the snout of the valve yet still makes the valve sit up a MM or 2 before tightening up the nuts. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri May 18, 2018 6:32 pm Post subject: Re: Sealant for breather box cork gasket? |
busdaddy wrote: |
Yes that's stock, one of those O ring assortments from Harbor freight should have something that fits over the snout of the valve yet still makes the valve sit up a MM or 2 before tightening up the nuts. |
Excellent! Thanks! _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
SGKent Samba Member
Posted: Fri May 18, 2018 7:31 pm Post subject: Re: Sealant for breather box cork gasket? |
it is the same as the one between the booster and master. Easy to find something that fits and works. DO NOT clean the inside of the PCV valve or it will dissolve instantly. To see if it is already perforated draw a small vacuum on the small hole on top. If it holds a vacuum the valve is still good. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Fri May 18, 2018 9:13 pm Post subject: Re: Sealant for breather box cork gasket? |
Don’t put sealant on the oring. Maybe a dab of lube but that’s it. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
WhirledTraveller Samba Member
Joined: January 09, 2008 Posts: 1399 Location: Cambridge, MA
Posted: Sat May 19, 2018 5:47 am Post subject: Re: Sealant for breather box cork gasket? |
I found that the bale wasn't applying very much compression to the gasket. I was able to use a vise and judicious use of pliers to carefully bend the wire in such a way as to increase the tension and that seemed to do the trick. I initially used grease on both sides of the gasket but didn't like the way it allowed everything to slide around, felt like a recipe for extruding the gasket, so I switched to Curil T and that stays in place a little more to my liking. I feel like RTV applied carefully is also appropriate in this instance, but like Ray noted you don't want to glue the breather box on. Just create a nice cushy sealing surface. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
Posted: Mon May 28, 2018 1:52 pm Post subject: Re: Sealant for breather box cork gasket? |
I'm at HF right now and I have 3 choices for o-ring material, nitrile, viton, and HNBR. What should I get for this application? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
SGKent Samba Member
Posted: Mon May 28, 2018 2:43 pm Post subject: Re: Sealant for breather box cork gasket? |
viton if they have it _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
