Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Sun May 20, 2018 3:08 pm Post subject: Re: pulling to one side and drum really hot (front right) |
crankbait09 wrote: |
Quote: |
I’m not convinced the bearings are bad. If the drum isn’t getting hot you should be ok. When you are tightening the nuts are you using a screwdriver to insure the washer behind can still be moved easily? are you using the stock nuts or the later style? This is one area of originality I would forgo and use the newer style. Much easier to deal with. |
as for the nuts.......I was using the two flange nuts that went with that washer with tabs that have to bent over. I have since replaced them with these: http://www.mooreparts.com/chromoly-vw-king-pin-spindle-nuts-clamp-type-with-pinch-bolt/
At first I tightened it just enough to allow that washer to slide easily. Then when I wiggled the tire in that condition, there was a bit of play in the tire. So I tightened it. so the washer didn't move. My wobble went away. Plus after feeling the "hum", that's why I also tightened it. I have not loosened it since I got home.
So at this point, spindle nuts are still tight |
washer is supposed to be able to move. Not flop around, but should slide with pressure from a screwdriver. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
crankbait09 Samba Member
Joined: October 10, 2016 Posts: 1304 Location: Cincinnati, Ohio
Posted: Sun May 20, 2018 3:10 pm Post subject: Re: pulling to one side and drum really hot (front right) |
Sharp64 wrote: |
washer is supposed to be able to move. Not flop around, but should slide with pressure from a screwdriver. |
ok. i'll re-adjust _________________ 1963 Ragtop |
Posted: Mon May 21, 2018 4:45 am Post subject: Re: pulling to one side and drum really hot (front right) |
so let's talk about this front wheel "hum/silent grind" that no one seems to be concerned with.
I know I can't hear anything, but I certainly feel it.
Could this be a possible sign that the bearings could soon need replaced?
I wish I had a better way of explaining it. All I know is that I feel it, but can't hear it. And it was after 15-20 minutes of driving it.
Once I get the new hubcap clips installed, I'll get it back out and see what more I can hear. But for now, I have some work to do _________________ 1963 Ragtop |
Posted: Mon May 21, 2018 5:31 am Post subject: Re: pulling to one side and drum really hot (front right) |
Are the tires balanced? Do you notice the issue at a certain speed? Does the car track straight? Happens under certain road conditions? _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
Posted: Mon May 21, 2018 5:38 am Post subject: Re: pulling to one side and drum really hot (front right) |
It drove straight, and I felt nothing. till I stopped at the gas station. Now that I think back, there was a drain cover on the driveway of the gas station that I rolled over. Could have been coincidence, but once I rolled over that I felt the rubbing/humming. Speed didn't matter. Felt it when turning the wheel slightly to the left, never to the right.
then on the way home, i felt it when slightly turning to the left.
As long as the front wheel doesn't fall off and I have no safety issues with it, then I'll take it out again to listen/feel _________________ 1963 Ragtop |
Posted: Mon May 21, 2018 5:52 am Post subject: Re: pulling to one side and drum really hot (front right) |
As long as the front wheel doesn't fall off and I have no safety issues with it, then I'll take it out again to listen/feel |
Any chance the tire is rubbing the speedo or brake line? _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
Posted: Mon May 21, 2018 5:56 am Post subject: Re: pulling to one side and drum really hot (front right) |
I'm gonna say no. The cable comes straight out of the backing plate and loops upwards. It's no where near the tire.
and to back up. With the oil level back down to where it should have been, and their being no smell of gas in the oil.........Still a chance I could have the issues BlueBus86 mentioned above? _________________ 1963 Ragtop |
Posted: Mon May 21, 2018 6:14 am Post subject: Re: pulling to one side and drum really hot (front right) |
and to back up. With the oil level back down to where it should have been, and their being no smell of gas in the oil.........Still a chance I could have the issues BlueBus86 mentioned above? |
Make some more observations and isolate when its doing it. My opinion, if its intermittent, its most likely not at issue. Check for wear on any surfaces. When you took the brakes apart, did you remove the backing plate? If so, did you replace the bolts correctly? One should have been longer as it acts like a stop. Make sure nothing has come loose, like the upper shock bolts. Check the sway bar. Go under, grab things and shake them. Take the hubcaps off and drive it for a little to see if there is any change. Maybe missing clips is throwing the balance off? Is there a vibration coming form the wheel? What type of tires? Radial or Bias Ply? What does the wear look like on them? What pressure are you running?
If the oil level went back down, I wouldn't worry about it. Don't give in to the Chicken Little syndrome. Relax. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
Posted: Mon May 21, 2018 6:22 am Post subject: Re: pulling to one side and drum really hot (front right) |
Sharp64 wrote: |
If the oil level went back down, I wouldn't worry about it. Don't give in to the Chicken Little syndrome. Relax. |
alright, thanks. I have a list of things to do. When I get back out I'll check everything. I'll report back _________________ 1963 Ragtop |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Mon May 21, 2018 11:43 am Post subject: Re: pulling to one side and drum really hot (front right) |
Pull the bearings, clean them and inspect them. When bearings get pitted they will make a kind of roaring or rumbling sound. You actually feel it more than hear it.
Here is what a bad bearing can look like. (the left one)
_________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
