Whaanga Samba Member
Joined: May 07, 2016 Posts: 623 Location: Rochester, NY
Posted: Wed May 02, 2018 6:39 pm Post subject: Diagnosing an off-center steering wheel |
As seen in the photo, my steering wheel is not at the 9:00/3:00 position. The bus drives straight down the road but the wheel is off-centered.
What variables might effect this?
How do I go about troublshooting/asdressing this issue?
Thanks,
Jeff
_________________ Late 1973 Bay w/a transplanted 914 Engine |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Wed May 02, 2018 6:55 pm Post subject: Re: Diagnosing an off-center steering wheel |
Replaced the drag link recently? That looks like one turn of the adjustable end of the drag link will make the steering wheel straight. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Wed May 02, 2018 7:38 pm Post subject: Re: Diagnosing an off-center steering wheel |
Thanks for the reply - I've had the bus for two years and this is how it came.
I'm a newbie so have not done anything to the drag link. Will do some homework and learn about how to do this adjustment. _________________ Late 1973 Bay w/a transplanted 914 Engine |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16922 Location: San Diego, California
Posted: Wed May 02, 2018 7:45 pm Post subject: Re: Diagnosing an off-center steering wheel |
Simple solution is to remove the SW and clock it. Problem is sometimes they are hard to pull off _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
wcfvw69 Samba Purist
Posted: Wed May 02, 2018 7:52 pm Post subject: Re: Diagnosing an off-center steering wheel |
To do this right, you need to center the steering gear exactly to see what's off? The center link, the steering wheel, etc.
My bus had someone in it's past remove the steering wheel. I removed it and centered the steering gear with the pitman arm also removed. I then centered the steering gear. Then adjusted the center link to close as possible wheels straight ahead. Then bolted the steering wheel back on centered correctly. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Wed May 02, 2018 8:00 pm Post subject: Re: Diagnosing an off-center steering wheel |
Do you want split hairs and get all scientific on this or get done? It’s a bit complicated otherwise. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3547 Location: San Diego (Encinitas)
Posted: Thu May 03, 2018 1:05 am Post subject: Re: Diagnosing an off-center steering wheel |
Jack the front end of the bus up and put it on stands. Rotate the steering wheel back and forth through the straight ahead position, feeling for the steering gear "tight spot". This is where the steering gear will have the least "play", the steering will be the most stable, the wheels should be straight forward and the steering wheel should be at 9:00-3:00. Rotate the steering wheel on it's splines to adjust. Adjust the drag link for straight travel. (This can be somewhat coarse. If you have adjustable tie rods both left and right, you can get it exact.) _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
