Frodge Samba Member
Posted: Thu May 03, 2018 10:44 pm Post subject: Solex 30 pict 3 adjustment procedure. |
What is the procedure for tuning this carb? I have a dwell/tach. Is there any way to know whether you’re running lean or rich without pulling the plugs?
I had adjusted this a year or so ago and just want to double check. |
Frodge Samba Member
Posted: Fri May 04, 2018 7:03 am Post subject: Re: Solex 30 pict 3 adjustment procedure. |
How do you know if it’s too lean or too rich? The mixture screw, even as described in the original vw films that the be watched is very slight. It explains that ththe mixture is controlled by the carb. |
Randy in Maine Samba Member
Posted: Fri May 04, 2018 7:13 am Post subject: Re: Solex 30 pict 3 adjustment procedure. |
I have always just used the basic procedure outline here with reasoanable results.
http://www.vw-resource.com/34pict3.html |
Frodge Samba Member
Posted: Fri May 04, 2018 2:23 pm Post subject: Re: Solex 30 pict 3 adjustment procedure. |
I’ve followed that procedure. When I had the 009 in, the volume was basically totally closed down with the mixture out 2.5 turns. When I put my 205t in the idle was lumpy so I started from scratch. (The 205t would be lumpy because it is retarded by 10 degrees). So I backed both screws out 2.5 turns, and that is not too far from where they are now. It idles at about 930 and I did the procedure with the mixture. My question is why would the volume come out from where it was with the 009 and the mixture kind of stay where it was? What color should the inside of the tailpipes be? How should the decor fee on a 90 degree day? The dipstick? The timing and valves are spot on. |
Frodge Samba Member
Posted: Sat May 05, 2018 8:09 am Post subject: Re: Solex 30 pict 3 adjustment procedure. |
https://youtu.be/5CZ8NY4V7s8
This is my car running. I followed the procedure, this is the first time I’ve done this. How can I be sure the mixture is good and not running lean? |
bluebus86 Banned
Posted: Sat May 05, 2018 8:20 am Post subject: Re: Solex 30 pict 3 adjustment procedure. |
lean running can also be caused by intake leaks, get the motor to idle, then spray flammable carb cleaner on each intake manifold joint, one at a time and wait ten seconds before the next spray. check base of carb, intake to head, and if dual port, the two rubber intake boots. if idle speed foes up or down coincident with the spray, you habe a leak. all leaks MUST be fixed before any tuning is attempeted
Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Cusser Samba Member
Joined: October 02, 2006 Posts: 31374 Location: Hot Arizona
Posted: Sat May 05, 2018 8:31 am Post subject: Re: Solex 30 pict 3 adjustment procedure. |
Frodge wrote: |
Let engine cool down. Then pull a spark plug and look at its color.
I think you're worrying about nothing though. I adjust my own carb as you did, and don't worry about it. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Frodge Samba Member
Posted: Sat May 05, 2018 9:05 am Post subject: Re: Solex 30 pict 3 adjustment procedure. |
I probably am worrying about nothing cuss. I just read in here that you could ruin the heads from it. |
