Rome Samba Member
Joined: June 02, 2004 Posts: 9641 Location: Pearl River, NY
Posted: Sat May 12, 2018 7:01 pm Post subject: Re: 1970 Bug Sunroof |
If the car is as solid rust-wise as it appears in your photos, you did well with the purchase. How did it drive on your trip to the car show? With the doghouse fan shroud and single-port engine, you could drive it 75mph all day. Did you mount your 5.5" 914 wheels from your signature line in your Gallery photos? They look great! |
docdanracy Samba Member
Joined: June 26, 2012 Posts: 1118 Location: Auburn, CA
Posted: Sat May 12, 2018 10:16 pm Post subject: Re: 1970 Bug Sunroof |
Car came with same wheels as I had put on my 74.
Car is running great. Reset timing and slight carb adjustment.
May be changing wheels to stock look 5.5 steelies in the future
Next up more interior work
May remove all carpet and go to full rubber floor covering.
Also door cards will be ordered soon!
_________________ Doc
1970 Sunroof Bug Yukon Yellow (L19K)
Custom 6.5x15” 914 Sport Wheels wrapped in 185x65x15 Contis
Empi shifter, full compliment of gauges, 1679 with mild cam, stock induction
SOLD: 1974 Marina Blue Standard Beetle undergoing restoration/preservation
1679 with Kadrons and header/QP
914 sport wheels 5.5" ET40 wrapped in 195x65x15 Kumhos |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sun May 13, 2018 8:20 am Post subject: Re: 1970 Bug Sunroof |
Congratulations! Beautiful car. - Bradford _________________
EverettB wrote: |
FU#5 |
Posted: Tue May 15, 2018 7:25 pm Post subject: Re: 1970 Bug Sunroof |
New door panels installed.
Speakers moved to Bamboo shelf for now.
Next will be new carpets.
New passenger vent window latch
Old and new
Posted: Mon May 21, 2018 4:32 pm Post subject: Re: 1970 Bug Sunroof |
Not a lot of time today
A couple of small details and I replaced the passenger wing window knob mechanism..
Next will be removing old carpet and installing new carpet recently acquired.
Posted: Tue May 22, 2018 8:38 pm Post subject: Re: 1970 Bug Sunroof |
Motor is cleaning up quite nicely
A few more details to take care of as we move along
AlmostHeavenWV_VW Samba Member
Posted: Wed May 23, 2018 4:16 am Post subject: Re: 1970 Bug Sunroof |
That's a good lookin' car you've got.
I think that beige/yellow just looks stunning on the old Beetles. Prob my favorite factory Bug color. _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
Posted: Wed May 23, 2018 10:18 am Post subject: Re: 1970 Bug Sunroof |
Thanks _________________ Doc
Posted: Thu May 24, 2018 9:33 pm Post subject: Re: 1970 Bug Sunroof |
Carb is now off car and apart on my work bench.
Main jet is too small at 120, will be switched to 130
Idle jet was 50, will be 55
Power jet remains at 65
Air correction jet is 125z and will remain
Following suggestions on Rob & Dave’s ACVW pages for H 30/31 with a 009 distributor.
Rebuild will be completed with new parts by Saturday afternoon. Going out of town tomorrow to see 2 of our grandkids
This also gives me access to clean some tough to reach areas on the motor with carb, coil and a few other items out of the way! _________________ Doc
Posted: Sat May 26, 2018 9:08 pm Post subject: Re: 1970 Bug Sunroof |
Carb is cleaned, rebuilt, rejetted, reinstalled.
Runs much better now, especially midrange acceleration!
Ready for EuroSunday here in Auburn tomorrow!
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Posted: Sun May 27, 2018 10:26 am Post subject: Re: 1970 Bug Sunroof |
Thanks!
EuroSunday eclectic group of cars today.
Posted: Wed May 30, 2018 8:51 pm Post subject: Re: 1970 Bug Sunroof |
Next up will be carpet install along with new hand brake boot, and brake handle cover.
Also in next week,new ceramic coated stock muffler and new exhaust tips, installed with new clamps and gaskets.
Little things at a time _________________ Doc
Posted: Mon Jun 04, 2018 4:42 pm Post subject: Re: 1970 Bug Sunroof |
Swapped out taillight/brake light bulbs to Sylvania Zevo 2357R LEDs
Also lined the inside of the reflector with aluminum tape to give the light more help reflecting.
Came out nicely with much more light from tail/brake lights.
May do the rest in LED in future.
Waiting on some parts and then new ceramic coated muffler and carpet will be installed. _________________ Doc
Posted: Mon Jun 04, 2018 7:45 pm Post subject: Re: 1970 Bug Sunroof |
docdanracy wrote: |
Waiting on some parts and then new ceramic coated muffler and carpet will be installed. |
I liked the increase in light output with those LEDs for the brake lights, but I'll have to look into putting that foil tape in there too. Sounds like a good idea! _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Posted: Mon Jun 04, 2018 7:53 pm Post subject: Re: 1970 Bug Sunroof |
I’ve done the foil tape before on several 914s tail lights!
Worked great, so decided to try it on the Bug when I opened up the light and saw the tail/brake reflector was basically flat grey and it wouldn’t polish well with metal polish.
This was with normal bulbs, running lights after lining the housing with aluminum tape _________________ Doc
Posted: Mon Jun 04, 2018 8:16 pm Post subject: Re: 1970 Bug Sunroof |
Today’s light results
Running lights
Running light
Running light
Brake lights
Posted: Mon Jun 04, 2018 9:27 pm Post subject: Re: 1970 Bug Sunroof |
Better in the dark!
This is just the tail lights
Frodge Samba Member
Posted: Mon Jun 04, 2018 9:57 pm Post subject: Re: 1970 Bug Sunroof |
What was the procedure to replace the wing window knob? Thanks. |
Posted: Mon Jun 04, 2018 10:24 pm Post subject: Re: 1970 Bug Sunroof |
Open wing window.
On the bottom there are two small factory rivets.
Drill those out and the pull old latch out...
The rubber grommet will likely come out with it.
Place grommet on new latch and line up holes and install with 2new rivets. _________________ Doc
