Mal evolent Samba Member
Joined: March 31, 2009 Posts: 2912 Location: San Antonio, Nuevo Mexico
Posted: Sat May 05, 2018 4:59 pm Post subject: Clamps for the manifold boots |
I have the pleasure of replacing my manifold boots. There are no clamps on there now. given that everyone insists on using OG clamps on the fuel side of the system, is there any need to buy exotic clamps for the manifold boots, or just go with Ace Hardware $2 hose clamps? _________________ 73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat May 05, 2018 5:48 pm Post subject: Re: Clamps for the manifold boots |
Are we discussing a fuel injected bus?, no clamps on the manifold boots on those. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Xevin Samba Member
Posted: Sat May 05, 2018 5:53 pm Post subject: Re: Clamps for the manifold boots |
What’s the set up you dealing with? I got some opinions on boots. _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Posted: Sat May 05, 2018 6:55 pm Post subject: Re: Clamps for the manifold boots |
77 westy. everything else made of rubber has been replaced, and needed it. I have all the parts, but I could not find the clamps listed anywhere. _________________ 73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Posted: Sat May 05, 2018 7:04 pm Post subject: Re: Clamps for the manifold boots |
Because they don't exist, most vacuum related hoses on L-jet are unclamped to relieve pressure in the event of a backfire, clamp them all up tight and the AFM flap becomes a single use fuse _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Hoody Samba Member
Posted: Sat May 05, 2018 7:24 pm Post subject: Re: Clamps for the manifold boots |
As stated they were not used from the factory.....But I noticed years ago Jake put them on one of his turn key engines. If you decide to put clamps on them my suggestion is the Oetiker clamps from Bel-metric with the rolled edges like the fuel line clamps. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Posted: Sat May 05, 2018 7:26 pm Post subject: Re: Clamps for the manifold boots |
Tie wraps work _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21512 Location: Oklahoma City
Posted: Sat May 05, 2018 8:04 pm Post subject: Re: Clamps for the manifold boots |
Aeromech is correct...tie wraps "work". I clamp ALL runner boots. Have been since the late 80s. This is one of the most insidious vacuum leak spots. Typically theu either do not leak ar,start up....until everything heats up....or they leak at,start up and either seal up or change leak characteristics once everything warms up and expands.
A carecul process of installing helps. I push them back on the runners until about 3/8" to 1/2" of runner is sticking out. Install runners and manifolds. Run a thin smear of high temp , oul resistant RTV around that exposed 1/2". Push the runner boots onto the manifild nipple....firmly...twisting slightly as you go to spread the RTV evenly. Then clamp the runner side of the boot so it cannot back or slip off the nipple on the plenum. Let it dry completely. Really only the runner side "needs" to be clamped if you do a careful install like this.
Just because the factory did not clamp these does not mean they are not BETTER with clamps. They didn't clamp most of the vacuum lines either...and virtually all of those leak with age and heat shrinkage. Ray |
