Brian_e Samba Member
Joined: July 28, 2009 Posts: 3293 Location: Rapid City, SD
Posted: Wed May 09, 2018 8:40 am Post subject: Re: CB Latest Dyno Results |
Pat D wrote: |
My favorite engine for that type of driving is a 2017cc. dual 44 IDF carbs, 9-1 compression, Panchito heads, W-120 or CB #2242 cam and a 1.25 rocker arm, 1-1/2 merged exhaust. Nothing over the top but an honest 145 HP and you can drive it anywhere without over heating. I build this exact engine often and get really great feedback.
If you want a little larger displacement, a 78x 94 is another good engine. Panchito heads, #2292 cam with a 1.25 rocker, 48 IDF carbs, 9-1 compression, 1-5/8 merged exhaust will get you 165 hp and still run cool enough for the street.
The Panchito head has opened the door for bigger street engines producing good mid range torque. It cools very well and produces some big hp numbers from a 40mm valve. |
Thanks for listing these combos. I built a low revving 2234cc tractor engine with panchitos, and it was impressive. It pushes around a 5000lbs double decker limo bus. Perfect heads for lots of different applications.
The new Wedgeports with the smaller port volume seem pretty impressive also.
Keep up the good work.
Brian |
jason Samba Member
Posted: Wed May 09, 2018 12:04 pm Post subject: Re: CB Latest Dyno Results |
Ivkings, that cam needs more compression. |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3466 Location: Paradise, Ca
Posted: Wed May 09, 2018 1:36 pm Post subject: Re: CB Latest Dyno Results |
Pat,
Any plans of using the new 044 chamber design in the Panchito? _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Pat D Samba Member
Posted: Wed May 09, 2018 2:23 pm Post subject: Re: CB Latest Dyno Results |
jpaull wrote: |
Pat,
Any plans of using the new 044 chamber design in the Panchito? |
No, The tooling on the Panchito is a permanent mold, no changing it. But, The panchito chamber is actually very nice and opened up as best can be for an 85.5mm bore. _________________ Pat, Im too fast slow me downs! |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Wed May 09, 2018 3:42 pm Post subject: Re: CB Latest Dyno Results |
Pat D wrote: |
jpaull wrote: |
Pat,
No, The tooling on the Panchito is a permanent mold, no changing it. But, The panchito chamber is actually very nice and opened up as best can be for an 85.5mm bore. |
Thanks for the info Pat!
Will you please make a comparison between the NEW Panchito and the very last batch of the Old "CNC Ported" Panchito . . . using the 2017cc you mentioned.
FWIW . . . I bought one of the last pair of the old "CNC" Panchito heads . . . C.B. opened mine for 90.5 . . . I'm hoping I won't be leaving too much power on the table using them vs the new version Panchito! _________________ Jesucristo es mi Señor y Salvador! |
Pat D Samba Member
Posted: Thu May 10, 2018 10:07 am Post subject: Re: CB Latest Dyno Results |
57BLITZ wrote: |
Pat D wrote: |
jpaull wrote: |
Pat,
FWIW . . . I bought one of the last pair of the old "CNC" Panchito heads . . . C.B. opened mine for 90.5 . . . I'm hoping I won't be leaving too much power on the table using them vs the new version Panchito! |
The old panchito ports were digitized and used on the new casting. There is no difference in performance or cooling between the two heads _________________ Pat, Im too fast slow me downs! |
mark tucker Samba Member
Posted: Thu May 10, 2018 8:04 pm Post subject: Re: CB Latest Dyno Results |
HotStreetVw wrote: |
Better tell the Society of Automotive Engineers all those technical papers are wrong.
I think JPMs mouse engine is excellent. Its included in that graph above and I can tell you it isn't one of the outliers. |
oh somany sae stuff is rong, out dated, just like the earth is round as we all know it is flat.and a man can not brathe under water or on the moon or live in space...those ex spurts have it all worked out perfectly. keep up the good work pat.I dont know squat about all thise numbers, but the time slips do tell the tale. as does the light at the finish line. |
Onceler Samba Member
Posted: Thu May 10, 2018 8:33 pm Post subject: Re: CB Latest Dyno Results |
mark tucker wrote: |
Yes! If the earth was round my house would be higher than my neighbors, question everything! _________________ 1972 Karmann Ghia |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Wed Oct 28, 2020 6:44 pm Post subject: Re: CB Latest Dyno Results |
I was thinking about this engine the other night. Since the owner has had some time to aggravate his competition, does anyone know who’s engine it is, and have any more specs./speed secrets been divulged? Let’s see now if we can keep this strictly to build sheet specs., and not question how it was possible? |
Posted: Thu Oct 29, 2020 10:52 am Post subject: Re: CB Latest Dyno Results |
Onceler wrote: |
Yes! If the earth was round my house would be higher than my neighbors, question everything! |
depending on the time of day. and who is smoking what and when |
