1951 driver and passenger door glass and hardware
luftgekuhlt
luftgekuhlt is offline
PostPosted: Sun May 06, 2018 2:00 pm    Post subject: 1951 driver and passenger door glass and hardware Reply with quote
I have the frames (repro) for the driver and passenger door windows for a bd 1951 and wonder if the glass and hardware can be found ready-to-use off-the-shelf.
I need the hardware, i.e. the correct handles for the ventilation and for the sliding window. Repro, NOS or used would do.
Any tips would be appreciated.
Buy the best. Cry once.
1965* 21W Samba (MCode 430 114) - 51 BD Standard Microbus (Type 22A. M62) - 1967 Westfalia pop-top (SOLD)
* 1965 according to chassie number but regged as 1964
EmpiGT
EmpiGT is offline
PostPosted: Sun May 06, 2018 6:27 pm    Post subject: Re: 1951 driver and passenger door glass and hardware Reply with quote
you can get the sliding window butterfly latch from Argentina from Splitpartsunlimited I think. I'll look and see if that is the correct user name. But the vent wing handle/latch I've only seen nos or used. I'm looking for a set myself.
EmpiGT
EmpiGT is offline
PostPosted: Sun May 06, 2018 6:29 pm    Post subject: Re: 1951 driver and passenger door glass and hardware Reply with quote
https://www.thesamba.com/vw/classifieds/detail.php?id=701140
luftgekuhlt
PostPosted: Mon May 07, 2018 11:59 pm    Post subject: Re: 1951 driver and passenger door glass and hardware Reply with quote
Thanks a lot for this info, will consult with the 'Secretary of Finance' at home Wink
What about the glass, did you have it already? I have just the frame (repro) and need to buy the glass as well. Is it available out there or is best to order it new? In that case I would need the measures since it must be perforated for the latches.
luftgekuhlt
PostPosted: Mon May 14, 2018 12:53 am    Post subject: Re: 1951 driver and passenger door glass and hardware Reply with quote
Is there a difference, if any, in the 2 large lateral glasses of the door window frame between barndoor and later (after march 55) split window buses?
At the moment I have a late (after march 55) split window bus model of the door frame in my 1951 barndoor.
I will replace it with the correct early bd 'piano hinge' frame. I have solved the 'piano hinge' glass so my query does not refer to that one.
Will the 2 lateral large glasses just fit from the later frame to the early bd correct 'piano hinge' frame (with exception of the catch)? Is it perhaps a difference in the hole made in the glass to fit the catches?
PS: Borrowed pic that shows a late bd sorry for that.
Scotty
Scotty is offline
PostPosted: Mon May 14, 2018 5:04 am    Post subject: Re: 1951 driver and passenger door glass and hardware Reply with quote
Darren Franklin in the UK can probably help you with brand new glass
https://www.thesamba.com/vw/classifieds/detail.php?id=1898158
luftgekuhlt
PostPosted: Mon May 14, 2018 11:24 am    Post subject: Re: 1951 driver and passenger door glass and hardware Reply with quote
I am trying to conclude if I NEED at all the 2 lateral large glasses or if I can use the ones (later model) that I already have and put them in the bd frame.
