Fourteen States in Seven Weeks?
SGKent Premium Member
SGKent is offline
PostPosted: Fri Jun 08, 2018 11:16 am    Post subject: Re: Fourteen States in Seven Weeks? Reply with quote
if I was going thru brushes that fast I might concern myself that solder would be next. Considering why the brushes would be wearing so fast it is either mechanical or electrical. While there are many causes of each, most involve heat as part of the process, and that eventually melts solder. Once a generator starts throwing solder it is over. I'd figure it out fast before that happens because one does not walk into an O'Reilly or NAPA and ask for a 38 amp over the counter exchange any more. That probably means taking it apart and growling it to be sure there isn't a winding that is shorted. Other causes like too much load on it can also be an issue - bad battery cell, too many electronics etc.. 38 amps is 500+/-watts max. As I recall, brushes used to last about 40,000 - 60,000 miles on my 1971 bus.
*You can do it right the first time, or do it over, the choice is yours. It is a free country. As to brakes, steering, tires, axles etc. - you may only get one chance at doing those right.
* VW Buses and VW cars share many of the same systems but if you haven't owned a bus and maintained it for awhile, you really don't know how different it is.
Bus Engine Cooling Issues? https://kentcomputer.com/77VW/BusEngineCooling.pdf
telford dorr
telford dorr is offline
PostPosted: Fri Jun 08, 2018 1:03 pm    Post subject: Re: Fourteen States in Seven Weeks? Reply with quote
A good thing to do on any brush replacement is to clean the crap out of the slots between the commutator segments. A sharpened piece of hardwood dowel works good. (Many) years ago, one used to be able go into a drug store and buy an "orange stick", used for cleaning under fingernails. You could also buy disinfectant that contained mercury. But I digress. The orange stick has a chisel tip cut on one end. This edge fit nicely between the commutator segments and safely dug all of the carbon crap out. Being wood, it couldn't hurt the commutator segments themselves (e.g., don't use a knife or small screwdriver - leaves sharp segment edges). Between that cleaning and sanding the commutator smooth, the brushes would last a long, long time.
'71 panel, now with FI
To steal ideas from one person is plagiarism; to steal from many is research - Steven Wright
All models are wrong; some are useful - George Box
More VW electrical at http://flowcon.us/td/ (available 9am to 9pm PST)
Tcash
Tcash is offline
PostPosted: Fri Jun 08, 2018 2:04 pm    Post subject: Re: Fourteen States in Seven Weeks? Reply with quote
Bamboo cuticle pusher
https://www.amazon.com/MASH-Reusable-Cuticle-Manicure-Pedicure/dp/B005MYYE6U
Or busdaddy's favorite, a chopstick.
Can be used to Open that AFM flap for fuel pump testing.
File to a chisel and clean in between those commutator segments.
Used to open and close the points without sparking.
File to a point and chisel for cleaning under those nails and push cuticles back.
Got a loose screw in wood, a touch of glue, drive one in cut it flush and start a new screw hole.
telford dorr
PostPosted: Fri Jun 08, 2018 10:32 pm    Post subject: Re: Fourteen States in Seven Weeks? Reply with quote
That's them.
asiab3
Air-Schooled
asiab3 is offline
PostPosted: Tue Jun 12, 2018 9:54 am    Post subject: Re: Fourteen States in Seven Weeks? Reply with quote
Wrapped up my time in Minnesota with a stark change of plans... Drove though North Dakota in one sitting, and now...
Third gear on an interstate! That means I’m officially in The West.
Robbie
www.airschooled.com
[quote=“sunnydog”]...the sliding door is the party entrance...[/quote]
andrewtf
andrewtf is offline
PostPosted: Tue Jun 12, 2018 11:28 am    Post subject: Re: Fourteen States in Seven Weeks? Reply with quote
Westward Ho.
and by that I just might mean....
"Look! There is a Ho going westward!
Just kiddin' Robbie
'75 Riviera - 'BIG EMMA' (Pan American highway trip paused for a make over)
'77 Riviera - Murphy' (being reborn.... slowly)
'63 Austin Healey
AlmostHeavenWV_VW Premium Member
AlmostHeavenWV_VW is offline
PostPosted: Fri Jun 15, 2018 3:10 pm    Post subject: Re: Fourteen States in Seven Weeks? Reply with quote
asiab3 wrote:
Go Buddy, Go!
[and you too Robbie Laughing ]
1973 Standard Beetle
1600DP AK case
34PICT3 Carb
Bosch 019 Distributor
Tcash
Tcash is offline
PostPosted: Fri Jun 15, 2018 5:36 pm    Post subject: Re: Fourteen States in Seven Weeks? Reply with quote
Ya, haven't heard from you in a few days. What's going on.
Hope all is well!
Tcash
PostPosted: Fri Jun 15, 2018 7:28 pm    Post subject: Re: Fourteen States in Seven Weeks? Reply with quote
Hope all is well!
Tcash
yeah, Robbie! I need my vicarious ACVW-ing fix! Very Happy
1600DP AK case
34PICT3 Carb
Xevin Premium Member
Xevin is offline
PostPosted: Fri Jun 15, 2018 7:57 pm    Post subject: Re: Fourteen States in Seven Weeks? Reply with quote
I know where he his Wink And it’s the only place I can’t get service with Verizon. More to follow I’m sure.....,
Keep on Busin'
Clatter wrote:
sunnydog wrote:
(This probably is Xevin's new signature line quote: Sunnydog said:"just the tip...")
Abscate wrote:
I dont hate anyone on the Samba - except for Xevin - who brought me cold coffee in the morning.
Xevin is offline
PostPosted: Sat Jun 16, 2018 9:16 pm    Post subject: Re: Fourteen States in Seven Weeks? Reply with quote
"I spy with my little eye ..." Two familiar buses Think
Keep on Busin'
PostPosted: Mon Jun 18, 2018 9:05 am    Post subject: Re: Fourteen States in Seven Weeks? Reply with quote
Well well well... would ya lookie there Wink
1600DP AK case
34PICT3 Carb
Stuartzickefoose
Samba Post Whore
Stuartzickefoose is offline
PostPosted: Mon Jun 18, 2018 9:33 am    Post subject: Re: Fourteen States in Seven Weeks? Reply with quote
July 27-28 2018- FUNDRAISER Agony Ride 2018!!
Thanks everyone who pitched in!
RAISED $1,065.68
MILES: 216
Next years goal is 300 miles!
https://www.agonyride.org/riders/ZICS/
Stuart Zickefoose
Synergy Solutions
Self Employed Mechanic
1980 Westy~Corkey
206-841-7324
[email protected]
Tcash
Tcash is offline
PostPosted: Mon Jun 18, 2018 9:49 am    Post subject: Re: Fourteen States in Seven Weeks? Reply with quote
Hey Stu who's the old man in the stocking cap?
asiab3
Air-Schooled
asiab3 is offline
PostPosted: Mon Jun 18, 2018 9:52 am    Post subject: Re: Fourteen States in Seven Weeks? Reply with quote
Stu, was I sleeping in that pic?
Yeah we’ll see you all at the Lucky Lab tonight!! Then I’m spending some time with family stuff here, flying to LA for more of it, then coming back up to continue my travels in July.
Life gets in the way of living sometimes, but I’ve had some great moments these last few months and I don’t intend for them to stop- just postpone. All is good though, see y’all tonight. Hawthorne location.
Robbie
www.airschooled.com
asiab3
Air-Schooled
asiab3 is offline
PostPosted: Tue Jun 19, 2018 5:23 pm    Post subject: Re: Fourteen States in Seven Weeks? Reply with quote
2,379 miles since the generator light went on, and the used brush has no discernible wear with a depth micrometer, and the surface looks identical to when I installed it. Case closed- bad brush.
Ran out of gas in Wisconsin...
Raced a vintage fire truck, and a vintage fire truck converted to a race car.
Found a side highway through North Dakota that didn’t suck.
Had a colassal meltdown in Montana- left speaker didn’t sound just right. Found some corrosion in the wire and made it right. Repair bill is now a towering $22.94.
Pulled off to Beartooth Pass, which opened a few hours before and some skiers and snowboarders jumped the roads.
Came into Yellowstone on theee hubcaps. Drove back a bit. Came into Yellowstone on four hubcaps.
Went to my first RendezVW and this guy didn’t break my bus this time.
Met up with some crazies.
Picked up some more bugs.
Packed up and stored it. On a plane to LA right now to learn bass guitar, play a show on bass guitar, and hitch a ride back to Portland to pick up the bus.
Robbie
www.airschooled.com
Clatter
Clatter is offline
PostPosted: Tue Jun 19, 2018 11:18 pm    Post subject: Re: Fourteen States in Seven Weeks? Reply with quote
Congrats.
The bass is by far the BEST instrument of them all.
Bus Motor Build
Fastback Build
I still love Green Bug Girl..
Spike0180
Spike0180 is offline
PostPosted: Wed Jun 20, 2018 3:54 am    Post subject: Re: Fourteen States in Seven Weeks? Reply with quote
Clatter wrote:
Congrats.
Definitely most underrated! Basses bring a band from bland to booming.
Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic"
Xevin is offline
PostPosted: Wed Jun 20, 2018 4:01 am    Post subject: Re: Fourteen States in Seven Weeks? Reply with quote
Spike0180 wrote:
Clatter wrote:
Congrats.
Yeah baby, just like Bootsy Cool
Keep on Busin'
TomWesty
TomWesty is offline
PostPosted: Wed Jun 20, 2018 6:46 am    Post subject: Re: Fourteen States in Seven Weeks? Reply with quote
Xevin wrote:
Spike0180 wrote:
Clatter wrote:
Congrats.
Ain’ nothin’ but a party baby..... Cool
Page 6 of 8
