Cambi Samba Member
Posted: Wed May 23, 2018 7:07 pm Post subject: Correct chassis Numbers 1955 Oval |
Hello everyone. First I’d like to thank and congratulate for such a helpful and huge site, it’s incredible all the information contributed.
I’m pretty new to VW’s although I’ve owned a 1979 super beetle for about a yr
Happened that I came across an oval and since I am starting to become more attractive to older bugs decided to check it out.
Looked under back seat chasis Numbers and searched here for previous posts in this topi, but can’t really figure it out. Is this a correct chassis for 1955? 3904733
EverettB Administrator
Joined: April 11, 2000 Posts: 69830 Location: Phoenix Metro
Cambi Samba Member
Posted: Thu May 24, 2018 7:32 am Post subject: Re: Correct chassis Numbers 1955 Oval |
Thank you very much EverettB.
Then it’s a 55 on a 61pan. How would I know, is there a number that reflects the year of the car?
If this is the case, this car doesn’t really hold up value, correct? |
Cambi Samba Member
Posted: Thu May 24, 2018 10:18 am Post subject: Re: Correct chassis Numbers 1955 Oval |
Thank you again. I was able to contact owner and have this picture from the tag under the hood by the spare tire
Mark Evans Samba Member
Joined: April 21, 2004 Posts: 1931 Location: Alsea,Oregon
Posted: Thu May 24, 2018 1:51 pm Post subject: Re: Correct chassis Numbers 1955 Oval |
Looks like a May of '55. _________________ '63 Ragtop |
theorangeperil Samba Member
Posted: Fri May 25, 2018 2:50 am Post subject: Re: Correct chassis Numbers 1955 Oval |
is there a way of finding what the original chassis number would have been from the body number? |
txoval Samba Member
Joined: January 23, 2004 Posts: 3553 Location: The Woodlands, TX
Posted: Fri May 25, 2018 3:40 am Post subject: Re: Correct chassis Numbers 1955 Oval |
The original chassis number is on the metal VIN tag shown above
1-0919XXX
Body and VIN number = June 1955 |
Cambi Samba Member
Posted: Fri May 25, 2018 7:53 am Post subject: Re: Correct chassis Numbers 1955 Oval |
If body it’s 55, would be possible that a 55 had originally Ragtop? Or this is also not correct for this 55 year period? |
txoval Samba Member
Posted: Sat May 26, 2018 5:24 am Post subject: Re: Correct chassis Numbers 1955 Oval |
55 ragtop could be original.
You need to set your goal...a 55 on a 61 pan will never hold its value. You could put $50k in it and never sell it for over $15k
So if you don’t care about resale, buy it...but at the same time do not pay too much. Is it titled as a 55 or 61? |
Cambi Samba Member
Posted: Sat May 26, 2018 9:45 am Post subject: Re: Correct chassis Numbers 1955 Oval |
Thanks txoval. It’s titled as a 55. Current owner had no clue about chassis swapped.
Car has rust, patina look, but rust issues. I can see around the ragtop a different old color..it might be original, is there a way to know if ragtop is correct on this car? |
txoval Samba Member
Posted: Sat May 26, 2018 12:27 pm Post subject: Re: Correct chassis Numbers 1955 Oval |
Only sure way would be to cut a hole in the head liner and see if it was welded in...or get the birth certificate for VIN on the metal tag. Birth certificates take a few months to get
Personally, I would move down the road. |
Cambi Samba Member
Posted: Sat May 26, 2018 2:13 pm Post subject: Re: Correct chassis Numbers 1955 Oval |
Thank you. There is no headliner in the car, just the top. I can see the ragtop mechanism, it’s just I’m not familiar with it. |
txoval Samba Member
Posted: Sat May 26, 2018 3:27 pm Post subject: Re: Correct chassis Numbers 1955 Oval |
You need to look at the roof metal...if a ragtop was grafted in from another car you will see where the roof was cut out and the ragtop section welded in.
Look around the perimeter of the opening |
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
Posted: Sat Jun 02, 2018 12:23 pm Post subject: Re: Correct chassis Numbers 1955 Oval |
3 fold ragtop is original for the body, people pay a lot for that. If its 2 fold, its welded in. _________________ I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438 |
Cambi Samba Member
Posted: Sat Jun 02, 2018 10:46 pm Post subject: Re: Correct chassis Numbers 1955 Oval |
Thank you kjell roar. It’s a 3 fold, and can’t see any welding around. I thought wasn’t original because I see some aluminum square tubs . |
