terryly Samba Member
Posted: Mon May 07, 2018 5:35 am Post subject: Beam clamp Bolts |
Hi folks swapping out my torsion beam for a coil over set up. The frame mead is cut off and I am using 1.5" tube and stamped steel beam clamps. last time I assembled it i used 3/8 grade 8 hardware for the clamps. Wanting to do this correctly What is the correct hardware for beam clamps ?
grade 8 bolt < flat washer <CLAMP >flat washer > lock washer > Grade 8 nut
Is that correct Nylock nut ? Stover nut ? Cap head bolt ?
Thanks _________________ 2180cc MS3PRO sequential fuel and spark 42mm IDF style Throttle boddies
Calgary Alberta Canada
Terry Lytle |
Dale M. Samba Member
Posted: Mon May 07, 2018 7:12 am Post subject: Re: Beam clamp Bolts |
Yes use lock washer or lock nut.... If using washer use SAE and not wrought washer, SAE has smaller od than wrought...
Vanillagurilla Samba Member
Joined: November 21, 2017 Posts: 1061 Location: California
Posted: Mon May 07, 2018 11:09 pm Post subject: Re: Beam clamp Bolts |
Lock washers don't do sh!t lol use a nylock nut if you can find some. |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5417 Location: Holland, MI
Posted: Tue May 08, 2018 3:48 am Post subject: Re: Beam clamp Bolts |
Loctite 271 or permatex high strength is also a good idea.
For the record, I tend to favor M10 bolts over 3/8. Everything else is metric, why mix and match standard and metric? Use class 12.9 M10 bolts. Overkill, but very strong.
I use a bolt with a flat washer Uber the head, a flat washer on the back with a Schnorr washer between the flat washer and nut, and a dab of 271/high strength on the nut. It won’t go anywhere. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
L5wolvesf Samba Member
Joined: August 17, 2009 Posts: 196 Location: Northern AZ
Posted: Tue May 08, 2018 9:06 am Post subject: Re: Beam clamp Bolts |
Vanillagurilla wrote: |
Agreed as far as split lock washers, the star type are somewhat better. And YES to Nylock. _________________ Amonster Motorsports
SNORE # 1196 sponsored by:
- www.356carburetorrescue.com/home.html
- Barnwerks Fabrication & Welding
- ArtSpeed Graphics
“Racing's important to men who do it well. When you're racing, it's life. Anything that happens before or after is just waiting.”
S. McQueen |
Posted: Tue May 08, 2018 12:57 pm Post subject: Re: Beam clamp Bolts |
L5wolvesf wrote: |
Agreed as far as split lock washers, the star type are somewhat better. And YES to Nylock. |
Star type are ok as a anti vibration washer on smaller fasteners but the only locking washer that actually works is a nordlock. Bad part is there about $10 each and don't work well with high grade hardened bolts as they need something to bite into. |
Posted: Wed May 09, 2018 4:53 pm Post subject: Re: Beam clamp Bolts |
Thanks for the input fellas. Time to go hardware shopping _________________ 2180cc MS3PRO sequential fuel and spark 42mm IDF style Throttle boddies
Terry Lytle |
dustymojave Samba Member
Posted: Fri May 11, 2018 1:06 pm Post subject: Re: Beam clamp Bolts |
Just so you know..
Those beam clamps are JUST FINE with Gr5 bolts. SAE flat washers for the smaller OD for better fit, or even maybe 5/16" SAE washers for an even smaller OD. Some 5/16" washers are made with oversize ID and will fit snug on 3/8" bolts.
I use nylock nuts. When prepping offroad race cars, I go for a belt & suspender sort of approach with nylock nuts AND Loc-Tite. I prefer fine thread bolts and nuts. But It's really not necessary. I've seen lots of play buggies that have run around for years with Gr2 bolts that haven't failed. I like to install those bolts with the head forward, so the thread are less likely to get damaged if you slam the front into a dirt bank, hole or rock. _________________ Richard
SoCalBajas Member
