Full Flow not cooling- or flowing?
Muthadragon
Muthadragon is offline
PostPosted: Mon May 07, 2018 7:45 am    Post subject: Full Flow not cooling- or flowing? Reply with quote
Someone please help. Full flow oil. Shows good pressure and increases when engine is revved up but the oil temp is not rising. Oil in sump very hot but it just doesn't seem to be circulation through the engine. Im confident I have everything routed correctly. I'm simply stumped...
DeathBySnuSnu
DeathBySnuSnu is offline
PostPosted: Mon May 07, 2018 6:45 pm    Post subject: Re: Full Flow not cooling- or flowing? Reply with quote
You are not full flowed.
You are hooked up to the stock oil cooler ports with an adapter.
A spring and piston control the flow to those port. If some thing is not right, spring, piston, oil pressure, oil weight ect then oil may not flow there.
Muthadragon
PostPosted: Mon May 07, 2018 9:14 pm    Post subject: Re: Full Flow not cooling- or flowing? Reply with quote
Many thanks. I had someone tell me I have the adapter connections backwards. Any other solutions to offer?
DeathBySnuSnu
PostPosted: Wed May 09, 2018 8:07 pm    Post subject: Re: Full Flow not cooling- or flowing? Reply with quote
Do a real full flow.
Wayne S. Johnson
Wayne S. Johnson is offline
PostPosted: Wed May 09, 2018 8:31 pm    Post subject: Re: Full Flow not cooling- or flowing? Reply with quote
Install a flow meter in the oil hose. If you have a blockage you could have oil pressure without good flow or none at all. Check eBay $25.
Additional products https://www.thesamba.com/vw/classifieds/search.php?username=Wayne+S.+Johnson
Additional products with Bluetooth http://www.thesamba.com/vw/classifieds/detail.php?id=632417
Muthadragon
PostPosted: Thu May 10, 2018 7:46 am    Post subject: Re: Full Flow not cooling- or flowing? Reply with quote
Doesn't a "real full flow" require tapping the case? Or can I do the in/out from an aftermarket pump? If so, what do I then do with the adapter ports?
Also- I will purchase a flow meter. Looks like a good tool to have regardless.
Wayne S. Johnson
PostPosted: Thu May 10, 2018 10:38 am    Post subject: Re: Full Flow not cooling- or flowing? Reply with quote
I had a 69 Bus with a full flow filter/cooler modification, the oil was coming from the oil pump. It was OK until I encountered cold weather. I lost all the oil when the filter split open at the seam form very high pressure caused by the cold oil. This problem is much less likely when the connection is made with an oil cooler adapter, which is protected by the oil pressure bypass valve.
Please post your flow measurements, the flow is pressure and temperature dependant.
Muthadragon
PostPosted: Sat May 12, 2018 6:39 pm    Post subject: Re: Full Flow not cooling- or flowing? Reply with quote
Success!!!! It was indeed routed incorrectly from and into the adapter. After switching in/out, the flow was perfect. Pressure and temp all where they need to be. Thanks for the feedback and assistance!
