dodgerodder Samba Member
Posted: Sat Jul 28, 2018 6:44 pm Post subject: Re: Back to life - my 66 build begins..... |
So now, it is no mystery where all the water was going from the leaking windshield corners......
I was hoping in the mythical, perfect world, this water was magically evaporating before it hit the bottom. That it became drinking water for unicorns haha
It’s funny though, because the bottom of the heater channels (outside the floor pan) are super nice looking
But like my mom taught me when looking for a girl, it’s whats on the inside that counts...
So it appears I’ll be needing funky green KlassicFab parts, fawk....
Well I thing I’ve had enough fun today. Thanks for looking
Dan
. _________________ My 66’ build thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=699235 |
a.wilson Samba Member
Joined: January 11, 2007 Posts: 2033 Location: Georgia
Posted: Sat Jul 28, 2018 10:18 pm Post subject: Re: Back to life - my 66 build begins..... |
dodgerodder wrote: |
a.wilson wrote: |
Bookmarked!!
As others have mentioned.. outstanding photos and detail. The next time someone asks about front quarter replacement in the Paint/body forum -- they should be directed to this thread.
Like the work on the front windshield cowl! My '75 will need a little work in that area on the right-side.. and this will be motivation on how to approach it. |
Thanks man, I really appreciate! Yeah, it’s weird, I couldn’t find much of anything online showing front quarter replacement
And I found nothing showing full cowl replacement
The one thing anybody using a repop quarter would need to do differently (than mine) is leaving the original support in place for the gas tank. All the replacement panels I’ve seen do not have this installed
If you run into any questions when you do your cowl let me know! I’ll be happy to help if I can |
Your doing fine. Thanks for the tip about those gas tank support rail pieces.
Have learned a ton by this thread alone with the kind of tools and methods to use. _________________ Be kind to all critters. America's "H8TERZ" can drink sludgy used Motor Oil!
oemwolf |
Posted: Sun Jul 29, 2018 2:27 pm Post subject: Re: Back to life - my 66 build begins..... |
a.wilson wrote: |
a.wilson wrote: |
Bookmarked!!
Have learned a ton by this thread alone with the kind of tools and methods to use. |
I learn the same way! I see so many things that are different than my normal way, then I try it & love it
There’s so many different ways to do the same thing, good to have options
I attached a pic of the gas tank brace that the repop panels are missing, circled in red.
Hate to see somebody cut it off if their panel doesn’t have it haha!
Posted: Mon Aug 06, 2018 7:38 pm Post subject: Re: Back to life - my 66 build begins..... |
Well had a little time to spend on the front quarter replacement.
The last piece of the original quarter to remove is under the seam in front of the door. So 1st step is opening the seam.
I started with the tool I made, and used to open the seam on the a pillars when I replaced the cowl
Tip looks like this
Start by prying the bottom of seam open, enough to slip the tool into.
Then gently hammer the tool straight up the seam.
This slightly opens the seam up
Tap until tool is all the way to top of seam. This slightly opens the seam.
Now I get to use a tool I made for the air hammer, to open the seam.
Basically a version of the vw seam opener you can find on the Samba, except I made mine to use in a air hammer
Cliff notes version. Started by cutting a piece of 3/8 steel into this
Tapered the tip to look like this
This part makes up the piece that slides under the seam to open it. Welded the rest of the pieces from scrap I had, looks like this when done
The long round part is just a handle to hold.
The pics make no sense on how it works. But start at the bottom
More to come! _________________ My 66’ build thread:
Posted: Mon Aug 06, 2018 7:59 pm Post subject: Re: Back to life - my 66 build begins..... |
Works like this, made SUPER quick work of the seam!
Opened it perfectly in about 1 minute! Edge of seam was 100% smooth when opened, no ripples at all. This would have taken forever to do without the tool, and would never be so smooth
You can see I sprayed Gibbs (kind of like wd40) into to seam, to help the die slide smoothly when i used the air hammer
Then just worked on grinding the spot welds that held the quarter panel lip to the inside of the seam
That section is all gone!
Posted: Mon Aug 06, 2018 8:11 pm Post subject: Re: Back to life - my 66 build begins..... |
Next I removed the front beam, to make fitting the new quarter way easier
Then I just HAD to slip the quarter on, to see how it fits....
Well it fits amazingly! This is obviously far from the final fit, but the NOS quarter fits soooooo nice!! Once I spend time fitting it will be really great I think!!
I literally did ZERO fitting here at all, just quickly slipped it in place
So I’ll work on fitting it for real next time, I'm pretty excited!!
Thanks for looking!
Dan
Disc Samba Member
Joined: September 24, 2009 Posts: 558 Location: Europe
Posted: Thu Aug 09, 2018 2:59 am Post subject: Re: Back to life - my 66 build begins..... |
Nice! Really nice! _________________ The glory never gets old, just need new paint.
Nick |
Oldschoolbmx Samba Member
Joined: December 23, 2006 Posts: 16 Location: Scottsdale, AZ
Posted: Thu Aug 09, 2018 3:26 pm Post subject: Re: Back to life - my 66 build begins..... |
Incredible work!!! Thanks for taking the time to shoot and post the pics--truly inspiring! |
wcfvw69 Samba Purist
Posted: Thu Aug 09, 2018 7:50 pm Post subject: Re: Back to life - my 66 build begins..... |
I agree. Fantastic photos and good tool making skills. I love the tool to open the seam. Hell, you could sell them!
This bug is lucky to have found a person to fix it so correctly. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Thu Aug 09, 2018 8:21 pm Post subject: Re: Back to life - my 66 build begins..... |
Thank you all for the kind words, it really means a lot!
I am honestly really surprised how well (and quickly) the seam opener tool worked!
That would have taken a while to do that long seam the normal way, and the opened edge is super straight & smooth
I’d have lots of hammer & dolly work to do if I pried it open
The only downside is, the tool is side specific. This will only work on the passenger side....
Would have to build a mirror image for the driver side.
Thank goodness I don’t have to do the driver side haha
If anybody needs to do their passenger side, I’d be happy to send it if the user pays shipping. Then just ship it back when you’re done
Thanks again for commenting, is appreciated
Dan _________________ My 66’ build thread:
GELS Samba Member
Joined: April 22, 2014 Posts: 28 Location: NEW ZEALAND
Posted: Wed Aug 15, 2018 9:10 pm Post subject: Re: Back to life - my 66 build begins..... |
Totally amazed at your skills, dodgerodder! What a great thread, keep up the amazing work. |
Posted: Thu Aug 16, 2018 11:02 am Post subject: Re: Back to life - my 66 build begins..... |
GELS wrote: |
Thank you so much GELS, really appreciate your feedback.
Free time has been tough to find this week, but I hope to get some done this weekend
Thanks for watching!
Rhysos Samba Member
Joined: March 17, 2010 Posts: 26 Location: Bristol, UK
Posted: Mon Aug 20, 2018 8:32 am Post subject: Re: Back to life - my 66 build begins..... |
Oh yes, impressive work as always! I assume you are keeping all of those flanges immaculate as you are planning on using a proper spot welder to join them back together (as opposed to plug welding with a MIG)?
I made a manual seam picking tool last week using your specifications and I must say that it works pretty well. My fingers are crossed that when I eventually fold it back over the steel will not split from overworking or stress fatigue. I am now the process of fabricating one of your ingenious fuel tank braces. I actually need to take off both front quarters on my car at the same time, but reckon that the brace will be very handy upon reassembly to bring things back into correct alignment.
Keep the quality content coming my good man! _________________ www.vwbeetlerestoration.blogspot.com |
flc Samba Member
Posted: Thu Oct 04, 2018 9:32 am Post subject: Re: Back to life - my 66 build begins..... |
So next was to fix the butchered area of the lower firewall, where it meets the new quarter section.
The firewall was a warped mess from the previous gas welding repairs. So I bought a BBT firewall patch, & a BBT rear 66 apron.
SUPER nice quality! I highly recommend. Here's the firewall patch:
But I don't want to splice weld the engine seal channel. So I removed the seal channel from the firewall patch panel, & the car:
Removed the tar board spikes, since I'm smoothing out the firewall to paint:
I have a new piece of steel seal channel, that I will have to later form to the shape & curves on the firewall, then I'll spot weld to the firewall so it will look as it did from factory.
Hi really enjoyed your thread so far, do you have a link to the firewall patches? I’ve looked on bbt but failed to locate them |
Posted: Fri Oct 05, 2018 8:59 am Post subject: Re: Back to life - my 66 build begins..... |
Rhysos wrote: |
Keep the quality content coming my good man! |
Hi there Rhysos,
Wow I’m so sorry for the slow response.
Mid August my Dad had unexpected open heart surgery. Thank God he is doing great afterwards, getting better each day.
It just amazed at what surgeons can do, literally a miracle
So soon I hope to get back to the VW, can’t wait
I am so happy that you got your seams open! I wouldn’t stress about ripping them when you close them. Just take your time. I had a junk donor that I opened & closed probably 4 times. The seam never split.
And I wasn’t really being careful with the donor. I think the key is just to take it slow, and close it gradually.
The brace worked out well in the gas tank area. Takes all the mystery out of keeping everything in place.
Thanks again Rhysos! Keep up your progress!
Posted: Fri Oct 05, 2018 9:08 am Post subject: Re: Back to life - my 66 build begins..... |
flc wrote: |
I got mine from cip1, linked here:
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D111%2D813%2D152%2DB
They list it as German made, I didn’t know who made it when I ordered it.
But when I got it there was a bbt label on it.
I just looked at bbt’s site and don’t see it listed, weird!
Cip1 does show them in stock, if that helps _________________ My 66’ build thread:
Posted: Fri Oct 05, 2018 9:12 am Post subject: Re: Back to life - my 66 build begins..... |
flc wrote: |
Cip1 does show them in stock, if that helps. It really did fit nice! Nice clean stampings, no wrinkles. Really is a nice part
flc Samba Member
Posted: Tue Oct 09, 2018 7:40 am Post subject: Re: Back to life - my 66 build begins..... |
Wow I didn’t notice you were in England when I replied, sorry about that!
The Hooky’s panel should be great, everything I’ve ever used of theirs is super nice _________________ My 66’ build thread:
Rhysos Samba Member
Posted: Tue Oct 16, 2018 4:31 am Post subject: Re: Back to life - my 66 build begins..... |
Pleased to hear that your dad is doing OK after his ordeal!
Looking forward to seeing your resto progress in due course _________________ www.vwbeetlerestoration.blogspot.com |
