djkeev  Samba Moderator
Joined: September 30, 2007 Posts: 25828 Location: North West New Jersey
jwallis Samba Member
Posted: Sun Jul 22, 2018 7:04 pm Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
djkeev wrote: |
I jsut ordered one of these Perko 0635DPO valves.
Part is no longer available at west marine or amazon, but correct part # is perko 0635DP0 (ending with zero, not letter o) and seems to be available at a few places around the web such as fisheriessupply.com _________________ Love your van.. Keep it Safe! Check out www.thevantracker.com!
Youtube vids covering brakes, bearings, CV joints, 1.9/2.1 cooling system, Bostig and more... |
Posted: Sat Sep 22, 2018 9:07 pm Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
Finally got to this one today. Wasn't too tough but I was treating it like it was microsurgery. In general, pretty straightforward. I realize now I probably should have installed the valve with the spring on top, but it probably won't make a difference.
I couldn't remember if you just pull the filler neck out or if there's some screw involved. There isn't, just pull. It's a pain in the ass. I just did a fuel tank reseal a few years ago, but if it's been a really long time, it's possible that seal will be dry and fall apart. That would turn this job into a reseal job, which takes a while.
I got the hose on ebay and 1ft shipped was about $15. Description was "Marine boat fuel fill hose WIRE 1 1/2 " shields 3551120 type A2 Gas / Diesel" and this is very high quality stuff. It has a thick steel wire in the hose which made it a bit of a pain to work with, but it was fine.
Oh, the only advice I have is after cutting the neck (which is pretty thick, probably 1/8"), if you sand it, it can leave a lot of tiny plastic hangers-on, so I aimed my little torch at it to try to get those parts to settle down or come off.
The whole thing took a few hours but I was going slow because i only have 1 filler neck and this is my daily driver. I considered cutting the neck with a blade but that would have taken forever. Hacksaw worked fine. Dremel would have worked too. I used a little motor oil to lube the neck and tank seal before shoving in there. I jacked the van up but didn't remove the tire. Don't think it would help a ton. _________________ Love your van.. Keep it Safe! Check out www.thevantracker.com!
campism Samba Member
Joined: September 07, 2007 Posts: 3832 Location: Richmond VA
Posted: Sun Sep 23, 2018 4:28 am Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
One of my submissions from the Vanagon Haiku thread:
Gassing up the van
Fuel pukes from the filler tube.
Two flammable shoes.
I have to reseal my tank so will probably take the precaution of installing one of these valves also as insurance. _________________ '87 Westy in Wolfram Grey Metallic |
11BC2 Samba Member
Joined: August 27, 2017 Posts: 263 Location: Cool, California
Posted: Sun Sep 23, 2018 8:16 am Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
campism wrote: |
Gassing up the van
I have to reseal my tank so will probably take the precaution of installing one of these valves also as insurance. |
Brilliant!! |
Dabbler Samba Member
Joined: September 13, 2018 Posts: 7 Location: Golden, CO
Posted: Sun Sep 23, 2018 7:49 pm Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
Brought home an 84 Westy yesterday and was fuelly initiated to the Vanagon life today. Thanks for the quick salve to the comedy that was my trip to the gas station. Gosh I'll be reading this forum a lot. |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 13308 Location: Syracuse, NY
Posted: Sun Sep 23, 2018 8:00 pm Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
installing a new fuel filelr seal doe NOT require dropping the fuel tank at any sort.. you can remove the old and install the new tank filler seal via the holein the frame..
even the grommet on the tank top where the vent line comes up to the filler neck does NOT require dropping the tank..
patience, persistence and perseverance and maybe a little bit of WD40. (I use fluid film, it'll swell/rejuvenate the rubber some).
jwallis wrote: |
Jamo7 Samba Member
Joined: September 25, 2014 Posts: 121 Location: Seattle
Posted: Mon Sep 24, 2018 8:42 am Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
I completed this job over the summer and now have about a thousand miles on it. I used to get some liquid spill up, and strong gasoline odor with every fill up. Ever since, I get no liquid and the odor is significantly reduced.
I installed the Perko flap valve almost exactly like the OP's photo. I just cut out a section of the fill up hose that was the length of the valve and then slipped the marine fuel hose over each end of the fill up hose. It was a little delicate getting everything to fit in tight quarters and tight tolerances, but I find all my Vanagon jobs are like that...
I purchased the valve, hose and hose clamps from Fisheries Supply by Gasworks in Seattle. I can just pop in there for van trinkets on my way home from work.
Thanks for posting the idea and good luck to those planning to implement this.
James _________________ '84 Westy 2.1 wbx |
Posted: Tue Oct 02, 2018 1:13 pm Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
I purchased the Perko valve months ago...... just put it in today.
I picked up some 1 1/2" FUEL FILLER HOSE (many shops will try to sell you 1 1/2" radiator hose! Don't accept it!)
Dayco 80303
The valve, I put a quarter next to it for scale......
The instructions...... they say to install it at least 12" from the filler nozzle
The valve is directional, pay attention to this fact.....
Where the valve will go, measuring and marking.......
Making sure the filler pipe IS 1 1/2" diameter......
I have a pair of cutting pliers that use a standard Utility Knife blade. This tool was almost perfect for cutting the filler pipe. I didn't want to use a saw and have those bits floating around in the fuel tank......
Marking the second cut.......
I cut a chunk of fuel pipe and installed it all. It wasn't at all hard...... I used cheese grater clamps I had on hand, they should be upgraded to a better clamp.......
Does it work?
I don't know.
I'm doing front brake pads, packing wheel bearings and installing new shocks,
I'll soon find out, I'm taking a run in it this weekend.
Ghia
Vanagon
Beetle
DanHoug Samba Member
Joined: December 05, 2016 Posts: 2216 Location: Bemidji, MN
Posted: Tue Oct 02, 2018 1:38 pm Post subject: Re: Vanagon Fuel Fill "BURP" - SOLVED! |
nice photos. just remember to NEVER stick down a fuel siphon with a 'jiggler' on the end!! _________________ -dan
87 Westy, stock 2.1 w/ 4 spd ratty but reliable
89 Westy, stock 2.1 w/ 4 spd, fate unknown |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 8679 Location: Where?
Posted: Tue Oct 02, 2018 3:43 pm Post subject: Re: Vanagon Fuel Fill-up Puke - SOLVED! |
Thanks for adding the pictorial. I would suggest adding a third clamp around the hose where the perko valve is located in order to seal the hose to the outside of the valve. This will prevent any fuel from bypassing around the outside of the valve. Probably not necessary, but I don't think it will hurt anything and might make the difference between a proper shutoff and a burp especially as the hose ages.
Also, it looks like you set the valve toward the cap end of the filler farther than necessary. Having the valve as close to the tank as is reasonable will give the valve more reaction time and make it less likely to burp. |
Posted: Sun Oct 07, 2018 3:46 pm Post subject: Re: Vanagon Fuel Fill "BURP" - SOLVED! |
how tight is that swing flap? does gas dribble thru enough if you 'top up' multiple times? i can sometime put in an extra 0.8 gallon after the burp and i wonder how the valve affects maxing the tank out. _________________ -dan
cmayna Samba Member
Joined: August 18, 2014 Posts: 948 Location: SF Bay area, CA
Posted: Mon Oct 08, 2018 6:01 pm Post subject: Re: Vanagon Fuel Fill "BURP" - SOLVED! |
Never thought I'd be so blessed, buying a '90. Never have had a fuel fill issue. _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
Posted: Sun Nov 11, 2018 5:28 am Post subject: Re: Vanagon Fuel Fill "BURP" - SOLVED! |
Real world update on fuel check valve.
The Van left NJ, traveled to New England, back to NJ, South to North Carolina, veered SouthWest to New Orleans, then West through Texas, New Mexico and Arizona.......
All without so much as a burp or dribble of fuel on multiple fill ups. Multiple States, probably 4,000 or more miles driven.
They crossed into California yesterday, stopped for fuel with the States vapor recovery system and they are hard pressed to put fuel in! They say a 10th of a gallon between click offs.
Does anyone know of a possible why?
Does the California pump deliver fuel at very high volumes so that it overwhelms the check valve?
Is it somehow related to the vapor boot not allowing air in?
Anyone have a "work around" for this issue?
I am wondering about cutting a short piece of 3/4" PVC or similar pipe (what plastic pipe withstands getting wet with fuel?) and squishing it between the vapor boot and the vehicle to allow air Out? In?
Are they not pushing the nozzle far enough in, being held out by the boot, and the fuel is going into the tank vent tube at the entrance to the filler neck? This would cause a backup of fuel in short order I would think.
Why VW put the vent on the bottom?????
It is only California thus far that presents any issues at all.
Trouble is that they need to travel the entire length of the State to Crescent City.
They are staying a few days in SanDiego so modifications can be made if need be.
Thanks for any ideas or knowledge!
Ghia
Vanagon
Beetle
Joined: April 29, 2015 Posts: 678 Location: Berkeley Ca
Posted: Sun Nov 11, 2018 6:49 am Post subject: Re: Vanagon Fuel Fill "BURP" - SOLVED! Umm problems in California! |
Could be funky gas station. Have them try at a new spot. Sometimes the handle is crappy. |
