kerian159 Samba Member
Joined: February 24, 2008 Posts: 344 Location: Pensacola, FL
Posted: Fri May 11, 2018 12:36 pm Post subject: Engine Tin |
I'm looking for some info: The two pieces of tin that cover the push rod tubes is what i'm looking for. This is what i'm running on my bus for heater boxes (living in FL don't need the heater). I'm looking for what type of tin i'm missing, is it 411/12 or early bus tin? I'm going to be picking up some (hopefully) later this evening and would like to verify it before I pay for it. Thanks in advance. This is out of a Bus but i'm not 100% sure the heater boxes aren't from a 411/12
_________________ 1976 Type II Westy P22
"Growing older, but not up!" |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Sat May 12, 2018 9:05 pm Post subject: Re: Engine Tin |
Sorry I did not get to this yesterday. It looks pretty 411/412-ish.
Assuming you have the fan shroud and all of the top tin......at a glance you are missing four pieces. Tbe two forward vertical tin pieces that screw to the top two large cylinder covers....and the two large flat pieces that are typically called "sled tins". I will post the schematic in the am. Ray |
Posted: Sat May 12, 2018 9:26 pm Post subject: Re: Engine Tin |
Yeah the only ones I'm missing are the "sled" tin I've only ever seen two or three 411/12's in person. Not sure where I managed to obtain the heater boxes. _________________ 1976 Type II Westy P22
Posted: Sat May 12, 2018 10:52 pm Post subject: Re: Engine Tin |
kerian159 wrote: |
Yeah the only ones I'm missing are the "sled" tin I've only ever seen two or three 411/12's in person. Not sure where I managed to obtain the heater boxes. |
I will have to check part #'s...but they should be pretty much the same as 1.7L bus. Ray |
Posted: Fri Jun 01, 2018 6:39 am Post subject: Re: Engine Tin |
Unfortunately they are different enough to not fit right So now to find a 411/12 tin _________________ 1976 Type II Westy P22
Chris Walden Samba Member
Joined: June 03, 2010 Posts: 147 Location: Indianapolis, Indiana
Posted: Sat Jun 02, 2018 6:08 pm Post subject: Re: Engine Tin |
I have the “sled tins”. Not sure about the others. I’ll check my “stock” in the morning. You’re welcome to them gratis. Let me know.
Chris |
