Frodge Samba Member
Posted: Fri May 11, 2018 2:19 pm Post subject: Fuel lines. |
Where can you get high quality braided fuel lines? I’m asking because I had power loss on my 2002 golf tdi. Ran be software and showed a boost problem. Checked over the car and some of the braided German vacuum lines were literally split and I had just changed them two years ago. The original vw lines lasted 15 years. Got me to thinking about the fuel lines for our bugs. I just want a top quality braided line. |
vwkirb Samba Member
Joined: January 16, 2007 Posts: 812 Location: Athens, GA
Posted: Fri May 11, 2018 5:13 pm Post subject: Re: Fuel lines. |
If you want to go the AN rout you can get them from the usual suspects like jegs or summits. _________________ Andrew Kirby |
Frodge Samba Member
Posted: Fri May 11, 2018 5:21 pm Post subject: Re: Fuel lines. |
AN? |
vwkirb Samba Member
Posted: Sat May 12, 2018 5:48 am Post subject: Re: Fuel lines. |
When you said braided I thought stainless steel, like the FI systems in some of those old rabbits ect.
Now I realize you meant cloth braided. Bel-Metric is a good source of all things metric.
https://www.belmetric.com/metric-hoses-c-14.html _________________ Andrew Kirby |
Frodge Samba Member
Posted: Sat May 12, 2018 5:58 am Post subject: Re: Fuel lines. |
vwkirb wrote: |
https://www.belmetric.com/metric-hoses-c-14.html |
Thanks for that source. What is the correct hose for the carb to fuel pump? What diameter? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76941 Location: Sneaking up behind you
Frodge Samba Member
Posted: Sat May 12, 2018 6:10 am Post subject: Re: Fuel lines. |
Thanks a lot! |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Sat May 12, 2018 8:35 am Post subject: Re: Fuel lines. |
Nor familiar with the brand mentioned, but I am pretty much over using the "German" braided hose. I have got it from several reputable vendors and its usually crapping out in a couple years. And we are only at a 10% ethanol gas here. Have been just buying bulk spools of regualr hose from my FLAPs. Better results so far. _________________ D-Dubya Manx clone - 63 Short pan,1914.
bluebus86 Banned
Posted: Sat May 12, 2018 9:49 am Post subject: Re: Fuel lines. |
andk5591 wrote: |
Nor familiar with the brand mentioned, but I am pretty much over using the "German" braided hose. I have got it from several reputable vendors and its usually crapping out in a couple years. And we are only at a 10% ethanol gas here. Have been just buying bulk spools of regualr hose from my FLAPs. Better results so far. |
lined hose, rated SAE 30R9 is the way to go, resists todays government mandated fuels. the new fuels cost more, deliver lower mpg, can pollute more when production is taken into account, and can be destructive to old car fuel systems, risk of leaks, and fires. speaking of which, read link below on safety wires and engine fires!
Bug On, fire safe! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
73SlowBug Samba Member
Joined: November 28, 2017 Posts: 439 Location: PENNSYLVANIA
Posted: Sat May 12, 2018 10:36 am Post subject: Re: Fuel lines. |
andk5591 wrote: |
Same here. If regular fuel hose is good enough for my modern car, it's good enough for my bug. Unless the original look is what you are going for, I see no reason to use the braided hose. Modern fuel hose lasts longer and is designed for modern ethanol fuels, and is readily available. I do understand those who want to keep their bugs "original", and if that's what you are going for, great, because that is admirable. Mine is all original *where practical*. |
Frodge Samba Member
Posted: Sat May 12, 2018 10:50 am Post subject: Re: Fuel lines. |
bluebus86 wrote: |
andk5591 wrote: |
Bug On, fire safe! |
Give me a link to what you’re using... |
Posted: Sat May 12, 2018 11:38 am Post subject: Re: Fuel lines. |
My spool is from Carquest rated SAE J30R7 I think the part number is CQ24060. Its nothing magical 1/4" ID fuel hose....BUT this is not rated for fuel injection. _________________ D-Dubya Manx clone - 63 Short pan,1914.
