Type 4 Secrets Revealed
Tcash
Tcash is offline
PostPosted: Sat May 12, 2018 12:12 pm    Post subject: Type 4 Secrets Revealed Reply with quote
The Type 4 Gods are shining on us.
Type 4 Secrets is back.
https://type4secrets.blogspot.com/p/home.html
Tcash
Tcash is offline
PostPosted: Sat May 12, 2018 12:46 pm    Post subject: Re: Type 4 Secrets Revealed Reply with quote
Archived
https://archive.org/
Sections
Welcome https://type4secrets.blogspot.com/p/home.html
Updates https://type4secrets.blogspot.com/
Type 4 Engine Reference https://type4secrets.blogspot.com/p/one-most-difficult-parts-of-working-on.html
Why a Type 4 engine? https://type4secrets.blogspot.com/p/why-type-4-engine.html
Type 4 engine How-To's https://type4secrets.blogspot.com/p/type-4-engine-how-tos.html
Type 4 Pictorial Tour https://type4secrets.blogspot.com/p/ever-since-i-first-posted-this-site-ive.html
Technical Articles https://type4secrets.blogspot.com/p/type-4-engine-technical-articles.html
Contributors https://type4secrets.blogspot.com/p/contributors.html
how-to (2) https://type4secrets.blogspot.com/search/label/how-to
reference (5) https://type4secrets.blogspot.com/search/label/reference
tech (27) https://type4secrets.blogspot.com/search/label/tech
tour (4) Crankcase, https://type4secrets.blogspot.com/search/label/tour
How To: Type 4 Conversion: Where to start https://type4secrets.blogspot.com/2017/08/how-to-type-4-conversion-where-to-start.html
How to: Make Your Own Kafer Brace https://type4secrets.blogspot.com/2017/07/how-to-make-your-own-kafer-brace_31.html
Reference: Type 4 Crankcases https://type4secrets.blogspot.com/2017/07/type-4-crankcases.html
Reference: Type 4 engine How-To's https://type4secrets.blogspot.com/2017/07/type-4-engine-how-tos.html
Reference: Type 4 Cylinder Heads https://type4secrets.blogspot.com/2017/07/type-4-cylinder-heads.html
Reference: Type 4 Torque Specifications https://type4secrets.blogspot.com/2017/07/type-4-torque-specifications.html
Reference: Type 4 Engine Reference https://type4secrets.blogspot.com/2017/07/type-4-engine-reference.html
Tech: Pancake cooling exhausts https://type4secrets.blogspot.com/2017/08/tech-pancake-cooling-exhausts.html
Tech: Upright Cooling exhausts https://type4secrets.blogspot.com/2017/08/tech-upright-cooling-exhausts.html
Tech: Porsche 914/912E exhausts https://type4secrets.blogspot.com/2017/08/tech-porsche-914912e-exhausts.html
Tech: Custom-made exhaust https://type4secrets.blogspot.com/2017/08/tech-custom-made-exhaust.html
Tech: CT / CZ Engines https://type4secrets.blogspot.com/2017/08/tech-ct-cz-engines.html
Tech: Type 3 Conversion https://type4secrets.blogspot.com/2017/08/tech-type-3-conversion.html
Tech: Type 4 Upright Cooling https://type4secrets.blogspot.com/2017/08/tech-type-4-upright-cooling.html
Tech: Industrial Type 4 engine https://type4secrets.blogspot.com/2017/08/tech-industrial-type-4-engine.html
Tech: Transaxles https://type4secrets.blogspot.com/2017/08/tech-transaxles.html
Tech: Type 4 Engine Tin https://type4secrets.blogspot.com/2017/08/tech-type-4-engine-tin.html
Tech: Type 4 Rockers https://type4secrets.blogspot.com/2017/08/tech-type-4-rockers.html
Tech: Type 4 Piston/Cylinders https://type4secrets.blogspot.com/2017/08/tech-type-4-pistoncylinders.html
Tour: Type 4 Crankcases https://type4secrets.blogspot.com/2017/07/type-4-crankcases_31.html
Tour: Type 4 Camshafts https://type4secrets.blogspot.com/2017/07/type-4-camshafts.html
Tour: Type 4 Cylinder Heads https://type4secrets.blogspot.com/2017/07/type-4-cylinder-heads_31.html
Tour: Type 4 Connecting Rods https://type4secrets.blogspot.com/2017/07/type-4-connecting-rods.html
Tour: Type 4 Connecting Rods https://web.archive.org/web/20180512193532/https:/...-rods.html
Good luck
Tcash
crownline Premium Member
crownline is offline
PostPosted: Sat May 12, 2018 2:30 pm    Post subject: Re: Type 4 Secrets Revealed Reply with quote
Very Happy Thank you tcash. Your the best.
1972 Bus 1700 cc Single Carb. But not a progressive.
Barelymuvin
Wish I still had the ones I got rid of.
"It"s got some dings and dents and neither of us is going to SEMA."
[url=http://www.vw-mplate.com/mplate-8446.png]Click to view image[/URL]
Clatter
Clatter is offline
PostPosted: Mon May 14, 2018 10:56 pm    Post subject: Re: Type 4 Secrets Revealed Reply with quote
Holy Sheep Shit!! Shocked Shocked Shocked Tom slider's masterwork!
This is the greatest work ever on the web. Take notes ladies.
Can this be put in the stickies?
How about copying it to this site here, so when 'Blogspot' goes bye-bye it still lives on??
Just when you thought this forum was totally worthless, Tim comes through!!!
I tried to get a copy of this, but that whole robots.txt issue prevented the wayback machine from archiving it any longer..
Tell us, how did this ever get saved?
Tom (Tuna) had left it for dead far as I could tell..
Bus Motor Build
Fastback Build
What's That Noise??
furgo
furgo is offline
PostPosted: Tue May 15, 2018 1:33 am    Post subject: Re: Type 4 Secrets Revealed Reply with quote
Here's an archive of the most recent blogspot site, if someone wants to host a mirror:
- Archived type4secrets.blogspot.com (zip file)
The last archived copy before the site was redirected to blogspot (and then no longer archived) seems to be from 2013. I've used this link for reference in the past:
- Tunacan.net (from archive.org)
It's difficult to know who put the "new" blogspot site together, probably the original author. In any case it's a bit involved to mirror it automatically in the way they set up the blogger site. Many of the images are not from the "new" site, but point to the web archive link above. Same for some of the links, which will redirect you to archive.org (just click on the "Links page" link on the Technical articles page, for an example).
All in all, good to see the site is live again Smile
'79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
