05gh Samba Member
Joined: September 01, 2011 Posts: 157 Location: The Netherlands
Posted: Sat May 12, 2018 12:47 pm Post subject: oil leakage from oil cooler? |
Oil is dripping via air deflector plate. I geus the oil cooler seals are leaking oir oil pressure switch. Do I have to pull out the motor? or just remove the fan shroud?
(type 4 injection) _________________ 63 doubble door panel van
79 de luxe micro bus
Be the change that you wish to see in the world.
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Sat May 12, 2018 1:10 pm Post subject: Re: oil leakage from oil cooler? |
Check the oil pressure switch first, since it's easy to access.
A couple months ago, I was prepared to get dirty by replacing the oil cooler seals which I thought were leaking. But it just turned out to be the oil pressure switch. Replaced the switch, and no more drips. (Well, not quite, but a whole lot less.) _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
SGKent Samba Member
Posted: Sat May 12, 2018 1:12 pm Post subject: Re: oil leakage from oil cooler? |
unless you drive backwards everywhere I don't buy the conclusion that it is the oil cooler seals leaking oil. It might be inside the fan shroud along with pushrod tube seals. Check your breather hose as well to be sure it isn't constricted, _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
05gh Samba Member
Posted: Sat May 12, 2018 2:14 pm Post subject: Re: oil leakage from oil cooler? |
SGKent wrote: |
unless you drive backwards everywhere I don't buy the conclusion that it is the oil cooler seals leaking oil. It might be inside the fan shroud along with pushrod tube seals. Check your breather hose as well to be sure it isn't constricted, |
I have checked the oil breather hose just a little bit dirt and it's open. _________________ 63 doubble door panel van
Be the change that you wish to see in the world. |
05gh Samba Member
Posted: Sat May 12, 2018 2:42 pm Post subject: Re: oil leakage from oil cooler? |
KentPS wrote: |
A couple months ago, I was prepared to get dirty by replacing the oil cooler seals which I thought were leaking. But it just turned out to be the oil pressure switch. Replaced the switch, and no more drips. (Well, not quite, but a whole lot less.) |
it is black and a lot of greas around, start with replacing the switch and see wath happens.
Perhaps first start te engine and see if its dripping oil i gues. _________________ 63 doubble door panel van
Tcash Samba Member
Posted: Sat May 12, 2018 3:06 pm Post subject: Re: oil leakage from oil cooler? |
05gh wrote: |
It can be done with the engine in, but it is tight.
You really need to clean the engine and find out for sure where it is leaking from.
Pushrod tube o-ring replacement
https://www.thesamba.com/vw/forum/viewtopic.php?t=420944
Oil cooler seals T2
Good luck
Tcash |
timvw7476 Samba Member
Posted: Sat May 12, 2018 4:11 pm Post subject: Re: oil leakage from oil cooler? |
SGKent wrote: |
Oil gets blown back on the type IV,
check the valve cover on that side,
& the valve cover surface on the head itself.
Also the 'VW" letters stamped inside the cover SHOULD be upside down when put on correctly. |
Zed999 Samba Member
Posted: Sun May 13, 2018 2:43 am Post subject: Re: oil leakage from oil cooler? |
Doesn't look like cooler to me. Bite the bullet, degrease everything and watch. I used brake and clutch cleaner in a plant mister when I had a similar leak that I thought was sandwich plate seal. It was a new but cracked cooler. PITA to change but clearly dripping once everything was clean. |
Volswagon Samba Member
Joined: December 29, 2009 Posts: 299 Location: Knoxville, TN
Posted: Sun May 13, 2018 2:54 am Post subject: Re: oil leakage from oil cooler? |
If it's a Beetle switch it's not tapered and has to be screwed down tightly to seal.
Type 4 switches are tapered. _________________ I know the pieces fit, cos I watched them fall away.
Wanna hear God laugh? Just talk about your plans.
'75 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=697183&highlight=
Posted: Sun May 13, 2018 2:58 am Post subject: Re: oil leakage from oil cooler? |
[quote="timvw7476"]
SGKent wrote: |
Also the clip has to be facing up. Easier to put it on after the valve cover is in place. _________________ I know the pieces fit, cos I watched them fall away.
'75 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=697183&highlight= |
Tcash Samba Member
Posted: Sun May 13, 2018 7:13 am Post subject: Re: oil leakage from oil cooler? |
Oil cooler seals T2 |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Sun May 13, 2018 10:07 am Post subject: Re: oil leakage from oil cooler? |
timvw7476 wrote: |
never heard such a thing before, and seems counterintuitive based on the location of the tab on the side of the valve cover.
curious as to where have you seen this in factory service information. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Sun May 13, 2018 12:32 pm Post subject: Re: oil leakage from oil cooler? |
And....it makes no difference which way the VW logo faces. Have you ever measured the ramps and ledges for the bales on the VC?......I have.....after the last time I saw and endless thread on which way the logo goes.
The covers are absolutely symmetrical. They will fit and seal either way. Ray |
Posted: Mon May 14, 2018 5:40 am Post subject: Re: oil leakage from oil cooler? |
raygreenwood wrote: |
but Ray, what about the tabs on the side of the valve covers? aren't they supposed to go on a certain way? don't they mean anything? why are they there? type 1 valve covers aren't symmetrical, yet many of them have the tab.
the VW logo and the tabs are oriented a certain way on every type 4 valve cover i've looked at. besides, having the vw logo upside down when installed lust looks unprofessional.
Questions, Questions, Questions, flooding into the mind of the concerned young person today.
do you have a link to the "endless thread on which way the logo goes"? i'd like to read it. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
Posted: Mon May 14, 2018 10:20 am Post subject: Re: oil leakage from oil cooler? |
Anytime I ignore it & have VW logo 'up' I am remounting upside down,
they (valve covers) seem to center easily that way, with the exterior
flange with the hole it in on the downward portion of the cover. |
05gh Samba Member
Posted: Wed May 16, 2018 2:24 pm Post subject: Re: oil leakage from oil cooler? |
oil leakage was a main seal leakage. any suggestions to clean this mess. _________________ 63 doubble door panel van
Posted: Wed May 16, 2018 2:32 pm Post subject: Re: oil leakage from oil cooler? |
hazetguy wrote: |
the VW logo and the tabs are oriented a certain way on every type 4 valve cover i've looked at. besides, having the vw logo upside down when installed lust looks unprofessional. |
I picked up two NOS Factory T-127 1800 engines a few years back and all four valve covers had the logo upside down. Maybe this was a worker's way of showing disdain for his job or maybe the engineers had figured out the covers worked one way better than another. I had long before figured out that they seemed to seal better with the logo upside down. Can't explain why though. |
SGKent Samba Member
stuff old towels or non-shredding paper towels down below the wet area and spray it with carb cleaner. Do either the non-flammable or make sure you are in a vented area not near any flames, water heater etc. Then toss the paper towels in something in the sun for awhile until they vent off and then toss them in the trash although they will still be very flammable.
BEFORE you go further make sure the breather hose and breather tower are clean and open all the way to wherever your breather dumps. If not excess pressure will cause that seal to leak.
To remove the flange you can use one of the several solutions here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=572644&highlight=remove+fan+tool
you can make a tool out of a thick large washer to fit behind the hub once you back the center bolt out some but leave it in until the hub pops free (put bus in 2nd or 3rd gear). you tighten 3 bolts down on the tool evenly to pop the hub off. There is an O-ring behind it you will need to replace too. Be gentle removing the old seal so that you don't gouge the area around it.
next two photos from TheSamba by Jon - Hazetguy
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
Posted: Wed May 16, 2018 3:50 pm Post subject: Re: oil leakage from oil cooler? |
If you do decide you need oil cooler seals, i have done it with the engine in place. Its not to tough and it gives you a lot of access to clean and inspect many different parts of the engine.
This thread was a good guide
https://www.thesamba.com/vw/forum/viewtopic.php?t=352137&highlight=extractor _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
Tcash Samba Member
Posted: Wed May 16, 2018 4:38 pm Post subject: Re: oil leakage from oil cooler? |
05gh wrote: |
oil leakage was a main seal leakage. any suggestions to clean this mess. |
engine degreaser
purple power
Dawn dishwashing liguid
Tcash wrote: |
Type 4 Fan hub Puller
#9 Fan hub oring 021 119 125 A
Fan hub seal 021 105 247 A
Don't forget to put #7 spacing washer back in.
thnx to jersey
Good luck
Tcash
