sonntagfahre Samba Member
Joined: September 22, 2016 Posts: 11 Location: Istanbul, TURKEY
Posted: Sun May 13, 2018 12:53 pm Post subject: I need experts, need urgent help! |
I will going to buy 1967, samba 21 window. But in these days there was a production facility (Cifcitiler Auto) in Turkey. Owner sent me vin palettes. Bus have 2 Vin plattes. One original other one belongs to Turkish factory. Chassis numbers same! But i want to make sure that bus is original. Owner says they owned this bus since 45 years and it is impossible to convert it. Can someone help me?
Last edited by sonntagfahre on Sun May 20, 2018 10:20 am; edited 1 time in total |
sgellis Samba Member
Joined: July 06, 2016 Posts: 2013 Location: SW Nova Scotia, Canada
Posted: Sun May 13, 2018 1:08 pm Post subject: Re: I need experts, need urgent help! |
I will. Probably will come tomorrow. I will send. Thank you |
Lind Samba Member
Joined: November 06, 2000 Posts: 9913 Location: idaho
Posted: Sun May 13, 2018 1:16 pm Post subject: Re: I need experts, need urgent help! |
Those plates show the bus to be a 1966 11-window standard microbus. Not a 21-window bus. _________________ .
Wanted:
Posted: Sun May 13, 2018 1:19 pm Post subject: Re: I need experts, need urgent help! |
My brain really mixed so much! How did you understand? |
aa390392 Samba Member
Posted: Sun May 13, 2018 1:42 pm Post subject: Re: I need experts, need urgent help! |
Sonntagfahre,
Please do the following ,know and understand
1st UPPER right hand corner of THESAMBA GO TO TECHNICAL
THEN READ the following beneath that heading
Vin chassis number
Then read how to read m codes
Then study m codes
Then read export code
Will help you out a lot
Good luck
Thomas _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13269 Location: Tejas!
Posted: Sun May 13, 2018 1:57 pm Post subject: Re: I need experts, need urgent help! |
Thank you Erik. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sun May 13, 2018 4:42 pm Post subject: Re: I need experts, need urgent help! |
You can swap VINs and chop roofs- but that dash clock looks crooked to me. Without even looking up- you can feel behind the clock and tell if the metal has been punched at the factory or chopped for the clock. _________________
EverettB wrote: |
FU#5 |
Posted: Mon May 14, 2018 1:22 am Post subject: Re: I need experts, need urgent help! |
I will going to check it. Maybe best way to request certificate. Thanks! |
EmpiGT Samba Member
Posted: Mon May 14, 2018 8:32 am Post subject: Re: I need experts, need urgent help! |
sonntagfahre wrote: |
A birth certificate isn't going to help you verify its a 21 window from that vin plate. You're only going to find out info on what this bus used to be or what the vin plate came from. Lind already told you the vin is from an 11 window standard. But if the vin has been swapped look by the battery tray for the real vin if it hasn't been cut out. Also look for belly pans. A real 21 window should have them. If the vin in the engine bay doesn't match and is the vin to a deluxe, I think I would still stat away from it. The bus may have been stolen. |
Posted: Mon May 14, 2018 9:07 am Post subject: Re: I need experts, need urgent help! |
I will thank you.... |
Posted: Sat May 19, 2018 2:08 pm Post subject: Re: I need experts, need urgent help! |
After long conversarions with owner i decided not to buy this bus. Thank you so much all for helps. You saved me! |
Posted: Sat May 19, 2018 3:58 pm Post subject: Re: I need experts, need urgent help! |
Very smart move....drive out to Malatya Erhac air base and find the Kombi I left there in 1970. _________________ .
55 ragtop
56 delux sedan
56 Kabriolet |
Posted: Sat May 19, 2018 4:13 pm Post subject: Re: I need experts, need urgent help! |
I will try lol! |
