stwesty Samba Member
Joined: May 10, 2015 Posts: 128 Location: Vancouver, Canada
Posted: Sun May 13, 2018 4:01 pm Post subject: Won't restart again after rebuild |
My engine won't start after a partial rebuild (replaced heads). I've done the points, static timing, and adjusted the valves.
I managed to get it started after a first static timing and it ran for 7 minutes at very high RPMs. It started to sputter a couple of times so I gave it a bit of gas and it continued until the 7ish minute mark.
After that I wasn't able to get it to start so I learned a bit more about the timing for my engine and set it properly (I was using the wrong marker for my first try).
I was then able to get it going for another 10-20 seconds or so and it sounded great but then with a single sputter it died.
I checked everything and realized my accelerator cable was caught up on a fuel line which explains the extremely high idle on the 7 minute run.
I removed the obstruction from the accelerator cable and now I can't get it to start at all. It turns over and every handful of seconds I get a single pop but that is it.
I checked the fuel pressure on my aftermarket Bugpack electric pump and is fine. I tried spraying some starting fluid across the open carbs but that didn't seem to have an effect. I also checked the two cutoff solenoids for the carbs, they are clicking when connecting/disconnecting.
What can I check next in the fuel distribution chain to see where things are failing? The fact that it ran twice means the timing is at least statically fine. I had 20L in the tank so I can't imagine 7 minutes of running drained it. _________________ 1974 Westfalia, automatic, dual-carb |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51121 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun May 13, 2018 4:04 pm Post subject: Re: Won't restart again after rebuild |
Got a dwell meter or timing light?, sounds like no spark or corroded points. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun May 13, 2018 4:08 pm Post subject: Re: Won't restart again after rebuild |
I measured the dwell and it was initially 60 so I adjusted it. I just bought a timing light so I wasn't able to test it during that 7 minute run. But the fact that it did run at some point and sounded decent means at least is reasonably timed statically, no?
Edit: unless of course something bumped or altered after my sucessfull-ish run I gess _________________ 1974 Westfalia, automatic, dual-carb
Danwvw Samba Member
Posted: Sun May 13, 2018 4:10 pm Post subject: Re: Won't restart again after rebuild |
Probably just flooded, you may need to change the spark-plugs, they fowl really easy on new engines when they are having difficulties like this.
I was having trouble on my 1641cc on the test bench after it sat for 2 weeks without being started. Turned out I was not pumping the gas enough on my dual Zenith 32 carbs. Do the accelerator pump jets squirt gas? _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Sun May 13, 2018 4:12 pm Post subject: Re: Won't restart again after rebuild |
How can I tell if the accelerator pumps squirt gas? Don't assume I know anything about carbs at this point... been doing a ton of reading, but it is one of the last areas of my bus I've done nothing with up until this point since they were fine before my rebuild. _________________ 1974 Westfalia, automatic, dual-carb |
Danwvw Samba Member
Posted: Sun May 13, 2018 4:21 pm Post subject: Re: Won't restart again after rebuild |
I was just looking at your pictures and it looks like you have the dual Solex's. But all carburated engines squirt gas inside the throat of the carb. You would remove the air cleaner and with the engine not running use a mirror and look or perhaps listen through a hose and pump the throttle to see if you can hear it squirt but really this was working before so it's probably something else. But it is a good way to know you are getting fuel. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Sun May 13, 2018 4:37 pm Post subject: Re: Won't restart again after rebuild |
Re-examine your points. Truly ensure that the gap is correct, the nylon block didn’t break off or the set screw did not loosen.
Don’t use starting fluid. Just get a soup can, crimp a fold on one edge to form a v shaped spout, and just use that to dribble a little gas. A LITTLE gas.
Make sure you are still getting spark. Shit happens. |
Tcash Samba Member
Posted: Sun May 13, 2018 6:02 pm Post subject: Re: Won't restart again after rebuild |
If it did not fire on starting fluid it is not a fuel or carb problem.
Check your spark, it should be a nice blue or white arc. Should not be orange.
Cranks Won't Start Test
Triple check that your spark plug wires are on right. Ask me how I know?
Good luck
Tcash |
Posted: Mon May 14, 2018 7:10 pm Post subject: Re: Won't restart again after rebuild |
I spot checked two spark plugs and both are getting bright white/blue sparks. I tried putting a couple of table spoons of gas down the open carbs and then starting it but still nothing. Am I supposed to put it down while it is running? _________________ 1974 Westfalia, automatic, dual-carb |
Tcash Samba Member
Posted: Mon May 14, 2018 8:10 pm Post subject: Re: Won't restart again after rebuild |
No
Try cleaning the plugs. As previously posted.
Good luck
Tcash |
Posted: Mon May 14, 2018 9:17 pm Post subject: Re: Won't restart again after rebuild |
Re-did the points, measured the dwell, did the static timing again, pulled all four spark plugs and cleaned them and re-tried. This is what it sounded like:
It sounded the same after trying the dribble of gas again too. Time to pull the carbs I guess? _________________ 1974 Westfalia, automatic, dual-carb |
Tcash Samba Member
Posted: Mon May 14, 2018 10:06 pm Post subject: Re: Won't restart again after rebuild |
Oh, now I'm definitely confused. 5 degrees AFTER TDC? I set it to 7.5 BTDC. I used the zero marker on the fan scale as zero TDC rather than the engine seam.
I have a 009 distributor, a vanagon engine block, a '74 fan shroud (only one marking on the actual fan), and it is an automatic. Just in case any of that matters.
Edit: the first time it ran for 7 mins I had been using the engine seam as the marker and had set it to 0 TDC. _________________ 1974 Westfalia, automatic, dual-carb |
Posted: Mon May 14, 2018 10:15 pm Post subject: Re: Won't restart again after rebuild |
Oh I see so 5 degrees after TDC is for AW engine code automatics (mine is a CV code). _________________ 1974 Westfalia, automatic, dual-carb |
Posted: Tue May 15, 2018 4:50 am Post subject: Re: Won't restart again after rebuild |
I am going to guess that you didn't get the dog on the bottom of the distributor shaft properly aligned with the slot in the dizzy drive prior to timing your engine and that eventually your engine corrected this omission and that now your timing is way off.
7.5° BTDC is the correct static timing for your engine no matter what the factory dynamic timing spec is.
Loosen the clamp around the bottom of your distributor and try to twist the rotor while pushing down on the distributor body as you turn back and forth slightly. Now check your static timing again. |
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2536 Location: Plattsburgh, New York
Posted: Tue May 15, 2018 6:38 am Post subject: Re: Won't restart again after rebuild |
I believe the 009 has the mark on the distributor body for cylinder #1 in a different place than stock. It's also easy to not index the drive gear properly. You have to go by where the rotor is pointing when #1 is at TDC ready to fire and adjust plug wires accordingly. This happens a lot. Ask me how I know. |
Tcash Samba Member
Posted: Tue May 15, 2018 10:24 am Post subject: Re: Won't restart again after rebuild |
Yeah, the marking on the 009 threw me off for a while. Mine barely has a hairline scratch as the marking and it was incorrect to boot.
I must have installed the drive gear incorrectly. I thought I measured the 12 degrees and had the segment correct, but something must be off since at #1 TDC (referenced by the valves) my rotor points roughly to the #4 cylinder.
What is the relationship between the engine type, the distributor type, and the angle and segment position of the distributor driveshaft?
I thought the purpose of getting the 12 degrees right was just to ensure the rotor lines up with the mark in the distributor for later convenience of finding #1 TDC without having to remove the valve covers.
If it is placed in at the wrong angle, you can still find #1 TDC via the valves, change your spark plug wires for 1-4-3-2, rotate the distributor while checking a timing lamp, adjust for 7.5 BTDC, the fine tune a bit with the static timing lamp, and away you go. Correct?
At this point I'm going to try the re-seating suggestion above and if that doesn't work pull out the distributor rotor and re-position it to 12 degrees and do the sequence all over again. _________________ 1974 Westfalia, automatic, dual-carb |
Posted: Tue May 15, 2018 10:54 am Post subject: Re: Won't restart again after rebuild |
The 12° position just guarantees that the vacuum can and condenser will not hit anything when you are turning the distributor body to time the engine, nothing more. |
curtp07 Samba Member
Posted: Tue May 15, 2018 11:28 am Post subject: Re: Won't restart again after rebuild |
Wildthings wrote: |
Important point.. I have an engine that didn’t have the drive gear set. In order to make the vacuum can not hit anything, I had to move the distributor and make a note of which way everything was set up. You could pull the drive gear out and risk that, or do as I did and live with it. Not a big deal. _________________ Subaru |
