swanlakers Samba Member
Joined: July 17, 2005 Posts: 370 Location: Lost in space
Posted: Sun May 13, 2018 7:37 pm Post subject: What is this crankshaft? |
I am not a Porsche guy, I was going to use this as a stroker in a 36hp block. Now I am going stock. Any way, I think this is a 74mm stroke crank from a 356. Anyone know what it is exactly?
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Fri May 18, 2018 10:43 am Post subject: Re: What is this crankshaft? |
you forgot (or edited out) this pic:
regardless of what it fits, it looks like scrap to me. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
356pre-a Samba Member
Posted: Tue May 29, 2018 9:49 am Post subject: Re: What is this crankshaft? |
8 dowels = that used to be in a 356, but looks like it's ready for its next phase in life as a book stand or lamp post. |
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3574 Location: Sarasota, in my adopted state of Florida
Posted: Mon Jun 04, 2018 7:15 pm Post subject: Re: What is this crankshaft? |
Can be fixed, modok comes to mind as one who could do it. The corrosion is a problem too and may clean up with a re-grind or could be welded up. It is good that the pins are no longer in it.
These 912/SC cranks have become very valuable and the cost to fix it would be a good investment. First thing would be to mag-it to see if it is junk or not.
Dan |
FeelthySanchez Samba Member
Joined: February 03, 2011 Posts: 1349 Location: Now is that a real poncho, or a Sears poncho?
Posted: Thu Sep 06, 2018 6:10 pm Post subject: Re: What is this crankshaft? |
swanlakers wrote: |
Anyone know what it is exactly? |
Native to the 356 SC and/or 912.
Dan Ruddock wrote: |
First thing would be to mag-it to see if it is junk or not. |
Better to 1st throw a mic on those journals. If serviceable, mag it after running a new/good gland nut in there to see what's left of the threads: they can be chased w/ a tap if Mr. Gland nut binds-up.
Remainder of the damage is at times repairable w/ 8 oversize dowels & some simple lathe work. No guarantees, tho. _________________
modok wrote: |
I would like if you had enough clue to communicate what you are doing. |
Ryan Tucker wrote: |
Enough clue..Whats that mean? |
OldIronSpine wrote: |
I'm not sure how compression works.
Turbos don't produce torque, they produce HP. Instead of torque.
The real problem with NA engines is you don't hear the nice whine of the turbo as it spools up.
Before I commit, I'm going to do more research because I don't really know what piston rings are. |
ChopperDave Samba Member
Joined: June 01, 2011 Posts: 1 Location: Washington State
Posted: Thu Sep 13, 2018 8:31 pm Post subject: Re: What is this crankshaft? |
Looks like a Counterweighted 356/912 crank. I think 63 and up if I am not mistaken. It’s in better shape than mine. While my Dowels look like new the crankshaft is now in two pieces where it should be one. |
dennis 356 Samba Member
Joined: January 09, 2009 Posts: 100 Location: Malmö, Sweden
Posted: Wed Oct 31, 2018 9:19 am Post subject: Re: What is this crankshaft? |
Any "to be continued" on this thread? Would actually be very interesting to read how it finally ended.....
Have actually what seems being an identical one, with even an identical issue, also punched R 161 02 01 501 and with measurements of the main bearing journal # 2 and 3 of 54.990 mm and the #1 main bearing journal of 49.991 mm it looks like being 1600 C and SC crankshaft, valuable someone pointed out?
Price to fix this "little problem" is minimum $500 according to the price proposition I received.
P.S. What is it with these cranks, are they on strike?
Dennis
badsix Samba Member
Joined: November 22, 2007 Posts: 228 Location: coos bay or.
Posted: Wed Oct 31, 2018 8:26 pm Post subject: Re: What is this crankshaft? |
dose yours have the deep rust pits the other one has. you guys need to check the classified under crankshaft. there's one for 300.00 needs reground i'd sure shop around before I thought about putting any money into one with bad pin holes and needing a regrind.
Jay D. |
Posted: Thu Nov 01, 2018 2:31 am Post subject: Re: What is this crankshaft? |
badsix wrote: |
Jay D. |
Thanks for the heads up, I´m of course not going to invest over $500 into a crank that´s not even needed, just laying around in my cellar for decades, on the other hand doesn´t need regrind as it has either been done long, long back in time, or has still been that nice when lifted out of the engine.
Dennis |
