AceHH Samba Member
Joined: April 24, 2014 Posts: 107 Location: Between Hamburg and Haiti
Posted: Wed May 16, 2018 5:20 am Post subject: Front Window Problem |
Anyone else ever had this Problem?
Rubber ist good German Quality.
Mark Evans Samba Member
Joined: April 21, 2004 Posts: 1931 Location: Alsea,Oregon
Posted: Wed May 16, 2018 10:36 am Post subject: Re: Front Window Problem |
What brand of rubber? _________________ '63 Ragtop |
lucille66 Samba Member
Joined: June 29, 2008 Posts: 633 Location: ORANGE COUNTY
Posted: Wed May 16, 2018 10:44 am Post subject: Re: Front Window Problem |
I just installed new seals and chrome trim on my oval and it definitely did not look like this. Ill see if I can post some pics for ya. it looks like the windshield may need to be re seated in the channel properly? _________________ my first bug 66' build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=438348&highlight=lucille66 |
AceHH Samba Member
AceHH Samba Member
Posted: Wed May 16, 2018 11:39 am Post subject: Re: Front Window Problem |
lucille66 wrote: |
are you doing the installation yourself? |
I didn’t do it, but I would next Time with a Friend |
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 1899 Location: San Fernando Valley, CA
AceHH Samba Member
Posted: Wed May 16, 2018 12:00 pm Post subject: Re: Front Window Problem |
56Cabrio wrote: |
I had the same problem back in 2000 with some WW rubbers.
How you solve it? |
0nebadbug Samba Member
Joined: October 01, 2009 Posts: 1087 Location: Rockford, Illinois
Posted: Mon May 21, 2018 10:16 am Post subject: Re: Front Window Problem |
Mine did the same thing using the German WW gasket...
What I think is... it's not so much the gasket but the way their trims are made & the miniscule windshield differences between the 57 & 58 screen's lower corner radius's ... I'm 99% sure that their trims are better suited for 58 up windshield as there is a very slight difference to the bottom corner radii from a 57 down VS. a '58 up windshield... And with the bottom radius corners being slightly tighter & pointied on the '57 they pull the gasket just enough to where it won't let the gasket relax enough to fully seal those bottom corners.
When I installed min the first time I thought I messed something up so I uninstalled it, tried the backup set of windshield trims and did it again and got the same result in the same corners. So what I did after install was wait a a week to just let the windshield relax & then on a good hot day I cut piece of soft pine just smaller than the radius and then with a rubber mallet on the pine block I was able to finesse both the trim & the gasket seat a little tighter.
While it's still noticeable it's at least sealed as opposed to curling in... Just don't go gonzo when beating on it... I think mine took 3-4 good whacks on the rubber and then 5 or 6 light raps on the trim to make it slightly tighter.
The other possibility is you may have a 1958 windshield... _________________ ::: Slowoval ::: LaDawri Sebring ::: '61 Creampuff ::: Dust Storm '66 ::: |
AceHH Samba Member
Posted: Mon May 21, 2018 10:52 am Post subject: Re: Front Window Problem |
From 58 the Windshield is larger.
Than I must have other Problems.
I‘ll try it this Week.
Good that I have the old scratch Windshield. |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14576 Location: 18 miles North of the border
Posted: Tue May 22, 2018 1:25 am Post subject: Re: Front Window Problem |
Place a wooden dowel (paint mixing stick works too) against the rubber seal at the corner. Tap other end of wooden dowel with a rubber mallet. This will force the seal into the windscreen opening. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
