sshulk Samba Member
Joined: August 29, 2008 Posts: 694 Location: Succasunna, NJ
Posted: Wed May 16, 2018 5:25 pm Post subject: Water in distributor cap? Bad? |
A question for you guys. When I took the distributor out. I tipped it over and water came out of the cap. The top part where the wires go in I know it got in from some bad rain that hit a few days ago but is this bad for the cap, the wires, the rotor? Anything in the dist. That could have been affected? _________________ 17 years old
German Looker in the Making
73 Super Autostick OG paint Marina Blue
72 Super
60 Mango Ragtop Camper Bug Project Thread
63 Ragtop Project
73 Auto Westfalia
2056 Type 4 Engine Build Thread
Filthy Buggers |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed May 16, 2018 5:41 pm Post subject: Re: Water in distributor cap? Bad? |
Water is conductive so it can cause a misfire or ground out the spark, it can also cause corrosion, just as bad but takes longer.
Dry it all out and keep an eye on it in the future, a dab of silicone grease in each hole before you insert the wire will help as well. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
73SlowBug Samba Member
Joined: November 28, 2017 Posts: 439 Location: PENNSYLVANIA
Posted: Wed May 16, 2018 5:43 pm Post subject: Re: Water in distributor cap? Bad? |
Might affect your points (if you have points still). Not permanently, just while there is moisture inside. Just let it dry out. It should be fine.
Edit: Don't drive it while its still wet. Might cause misfires. But it'll dry. _________________ Daily driven....Slowly. |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Wed May 16, 2018 7:25 pm Post subject: Re: Water in distributor cap? Bad? |
I assume it rains in the summer where you live. You might want to be proactive and get a new set of wires with new rubber boots. And, as stated, put a little dielectric grease in the boots.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
sshulk Samba Member
Posted: Wed May 16, 2018 8:08 pm Post subject: Re: Water in distributor cap? Bad? |
What brand are they. New boots should be nice and tight.
You can also buy a distributor cap cover that seals the top.
Richard O'Brien |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Zundfolge1432 Samba Member
Posted: Thu May 17, 2018 5:31 am Post subject: Re: Water in distributor cap? Bad? |
Old Baja off-road trick for water proofing, grab a can of hairspray and apply to cap and wires after it’s all together. It seals and water will roll right off use two coats maybe three. Also adds a shine mask off the areas you don’t want oversprayed. 😀 |
sshulk Samba Member
Posted: Thu May 17, 2018 6:36 am Post subject: Re: Water in distributor cap? Bad? |
Tim Donahoe wrote: |
Tim |
I wanna say they were WW but i have no idea, but new ones my dad bought 5 to 10 years back? Its 30 bucks for a new set from WW, and I need to order a few clips and little things so I add them to my order. _________________ 17 years old
72 Super
63 Ragtop Project
73 Auto Westfalia
Filthy Buggers |
Posted: Thu May 17, 2018 6:53 am Post subject: Re: Water in distributor cap? Bad? |
Hmmm let’s see 30 bucks for the wires or 3 bucks for hairspray or maybe free if your mom’s uses it..... lol 😂 |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Thu May 17, 2018 6:59 am Post subject: Re: Water in distributor cap? Bad? |
Take the distributor out with the cap & wires attached, turn it upside down & dip it in plastidip to just below where the cap seats to the distributor, INSTANT water proofing boot. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Thu May 17, 2018 7:17 am Post subject: Re: Water in distributor cap? Bad? |
TDCTDI wrote: |
Take the distributor out with the cap & wires attached, turn it upside down & dip it in plastidip to just below where the cap seats to the distributor, INSTANT water proofing boot. |
That would work too but if you have 30 bucks to throw down Maybe that’s the way. None of this surprises me anymore😀 here’s what we know for sure, most of what the oldtimers recommend are tried and true. It goes in one ear and out the other, but hey experience is the best teacher and school is in session. |
sshulk Samba Member
Posted: Thu May 17, 2018 7:20 am Post subject: Re: Water in distributor cap? Bad? |
I dont think its a problem, Personally id rather have the right wires that properly seal. LOL _________________ 17 years old
72 Super
63 Ragtop Project
73 Auto Westfalia
Filthy Buggers |
Posted: Thu May 17, 2018 7:30 am Post subject: Re: Water in distributor cap? Bad? |
Zundfolge1432 wrote: |
TDCTDI wrote: |
Personally, Plastidip is more available than hairspray, but hey, if you're still using Aquanet & you have it on hand, be my guest. Just putting another idea out there. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76938 Location: Sneaking up behind you
Posted: Thu May 17, 2018 7:54 am Post subject: Re: Water in distributor cap? Bad? |
Which is the same thing as the Plastidip with the exception that you don't have to fight trying to stretch that boot kit over wire ends, distributor cap, & coil. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Thu May 17, 2018 7:59 am Post subject: Re: Water in distributor cap? Bad? |
I’d like to have 30 dollars in my pocket. 😀 |
Posted: Thu May 17, 2018 8:02 am Post subject: Re: Water in distributor cap? Bad? |
TDCTDI wrote: |
TDCTDI wrote: |
Personally, Plastidip is more available than hairspray, but hey, if you're still using Aquanet & you have it on hand, be my guest. Just putting another idea out there. |
Available? Shit man there’s a Walgreens or CVS on every corner. They might even carry plasti dip too. 😀 |
bluebus86 Banned
Posted: Thu May 17, 2018 10:40 am Post subject: Re: Water in distributor cap? Bad? |
Water can cause corrosion in the dizzie internals. get it all dried out asap. WD 40 can be used, but make sure you clean up the wd 40 from the points with an oil free solvent. points dont like any oil on the contacts, it burns and arcs. but flodding the rest of the dizzie with wd 40 wont harm anything, it will help remove the water. then drive to heat it up.
good luck, stay dry, Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
AlmostHeavenWV_VW Samba Member
Posted: Thu May 17, 2018 11:49 am Post subject: Re: Water in distributor cap? Bad? |
bluebus86 wrote: |
good luck, stay dry, Bug On! |
Well, that sounds like a 'long way around' solution.
Just set it out in the sun, hang between two cheap "clamp utility lights" or place in oven on low (heat it up and dry it out)
Then replace those old plug wires, wouldn't hurt to have a new cap if also that old too _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
