Expansion tank
abcdleines
abcdleines is offline
PostPosted: Thu May 17, 2018 7:54 am    Post subject: Expansion tank Reply with quote
About ready to reinstall my gas tank. PO got rid of the charcoal filter but the expansion tank was still hooked up in the trunk. I am going to be running dual Webers on a 1776 engine. I’m will be installing all the venting hoses from the filler hose to the back of the expansion tank and back to the gas tank as it was designed but can I terminate the hose coming from the front of the expansion tank to under the car? Thank you.
JayC
JayC is offline
PostPosted: Thu May 17, 2018 8:42 am    Post subject: Re: Expansion tank Reply with quote
My two cents (and I am sure others may disagree)...
When I put mine back together, I basically did it for the aesthetics. Both the canisters (trunk and under the rear) were blocked and probably hadn't had any air flow through them in years. I put everything back in, but I know the metal tube running down the passenger side is still blocked.
I haven't had any issues and no bad smells. I just like the looks of everything.
jay
74 Thing
74 Thing is offline
PostPosted: Thu May 17, 2018 1:59 pm    Post subject: Re: Expansion tank Reply with quote
There are two metal tubes in the car-one by the front bulkhead near the brake master cylinder and the other under the passenger side floorpan that runs the length of the car. I would hook up a piece of small vacuum hose and try to blow through these pipes. The ends often rusted shut so if you cut off an 1" off the end it usually clears the blockage.
You do not need to use this and you can vent to the air like early VW's, but you do need a vent one way or the other or there will be suction on your gas tank and you will have a fuel flow problem.
Ron Domeck
Ron Domeck is offline
PostPosted: Thu May 17, 2018 6:32 pm    Post subject: Re: Expansion tank Reply with quote
We make new metal lines on all the things we restore. The line is 1/8 line available at most parts store. Comes in 25ft that will do 2 cars. You can also use the center brake line, takes 2 and can be spliced with plastic hose. Take your old line to bend the new one.
Ron Domeck
PostPosted: Thu May 17, 2018 6:33 pm    Post subject: Re: Expansion tank Reply with quote
