SGKent Samba Member
Posted: Mon May 21, 2018 6:22 pm Post subject: Re: Help KentPS get back on the road? |
orwell84 wrote: |
I've heard it called shipwright's disease. One of the cleats is rusty so you replace it with a nice brass cleat, the deck it's attached to is a little spongey so that gets fixed too but while doing it you find, well you get the idea. I almost bought a small sailboat once until it occurred to me that it would be like a floating bus. |
LMAO
Gary - if there is anything you need PM me. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
wcfvw69 Samba Purist
Posted: Mon May 21, 2018 7:13 pm Post subject: Re: Help KentPS get back on the road? |
Did you compression test this engine when you did all the work to it way back when Kent? What were the results if you did? If the compression was good, you maybe able to skip re-ringing the pistons. Simply yank the other head off and inspect it carefully. I agree with Kent though in you're throwing the dice if you reuse it without a rebuild.
Not to be Debbie Downer but many folks do a top end on their (tired) engine. This then contributes to a rod knock due to the increased compression. _________________ Contact me at [email protected]
The Samba member since 2004.
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2539 Location: Plattsburgh, New York
Same thing with bathrooms...started a bathroom refresh and first thing I know, it's down to the studs and the subfloor and I'm renting a chaincutter to get out the old cast iron stinkpipe...my bus weakness is rust,,,it's the gift that keeps on giving.
Good luck getting rolling again. |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Tue May 22, 2018 4:43 am Post subject: Re: Help KentPS get back on the road? |
wcfvw69 wrote: |
Did you compression test this engine when you did all the work to it way back when Kent? What were the results if you did? If the compression was good, you maybe able to skip re-ringing the pistons. Simply yank the other head off and inspect it carefully. I agree with Kent though in you're throwing the dice if you reuse it without a rebuild. |
Yes Bill. The last compression check was done last fall, I think. The numbers were in the 120-130 range. _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
SGKent Samba Member
Posted: Tue May 22, 2018 9:53 am Post subject: Re: Help KentPS get back on the road? |
If you are not burning oil, and if you don't have a lot of blowby 120-130 is healthy - as long as it was reasonably equal on all cylinders. You are probably a candidate to send the heads (plural) to Adrian and have them rebuilt. Or buy new heads from Len Hoffman. If you put new heads on it, rebuild the whole engine and enjoy it for 100,000 miles. If you just have the heads reworked, enjoy it for 20,000 more miles and plan on a full rebuild then with new heads. That is my opinion. Others may feel differently. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Tue May 22, 2018 12:20 pm Post subject: Re: Help KentPS get back on the road? |
SGKent wrote: |
If you are not burning oil, and if you don't have a lot of blowby 120-130 is healthy - as long as it was reasonably equal on all cylinders. You are probably a candidate to send the heads (plural) to Adrian and have them rebuilt. Or buy new heads from Len Hoffman. If you put new heads on it, rebuild the whole engine and enjoy it for 100,000 miles. If you just have the heads reworked, enjoy it for 20,000 more miles and plan on a full rebuild then with new heads. That is my opinion. Others may feel differently. |
Kent,
This ^^ is what I was going to say if you came back with good compression numbers.
I wouldn't screw with the pistons/cylinders or rings. Get the heads fixed and run it for 20k miles or more w/luck. _________________ Contact me at [email protected]
Posted: Tue May 22, 2018 6:20 pm Post subject: Re: Help KentPS get back on the road? |
SGKent wrote: |
New heads would be great. But I saw the price online, and it's not feasible now. So a rebuild is definitely out of the question. I'd have to sell or park her for a couple years. Medical bills are already eating me alive, and it's going to get worse this summer.
It's never burned any oil, just a slight irritating leak I'm planning on fixing while the drivetrain is out. On the journey from PS to GC to Quartzite, I added about a half quart of oil. I try to keep the oil level even with the top line of the dipstick, and it was down about 1/4" the one time I added oil.
So, option two is rebuilding heads...
While I was with WilliamM, he had a 1700 head that was in good condition with new valve guides already installed. And he had valves that had been reground, and springs in good condition. He spent a couple hours showing me how to use a set of Neway valve seat cutters to get the best fit. So I am super confident the replacement head is good to go.
The plan is to remove the bad head and compare the volume of (the hopefully undamaged) #4 to the new head to determine if it's similar. And if it is comparable, to install it and do a compression check all the way around. And learn how to do a leak down test while I was at it. It's my understanding these tests will tell me how good the rings are functioning.
I don't know what is involved when someone rebuilds the heads, but I'm assuming it's similar to what BillM did for me in Quartzite. If the 1/2 head compression and volume is similar to the 3/4 side, what would be the benefit of rebuilding them? (Hope that doesn't sound flippant, as I am seriously asking. I'm still firmly entrenched in the "newbie" category of ACVW ownership.) _________________ -Kent-
---williamM |
Joined: January 01, 2007 Posts: 16881 Location: sticksville, ct.
Posted: Tue May 22, 2018 7:49 pm Post subject: Re: Help KentPS get back on the road? |
KentPS wrote: |
what would be the benefit of rebuilding them? [i](Hope that doesn't sound flippant, as I am seriously asking. |
having the EXACT same problem on the other head in 800 miles.
I appreciate your passion for the bus, but how many Band-Aids are you willing to pay for?
yea, these will run cobbled together...for how long? who knows. if you factor in all your down time, towing etc....it's getting expensive, huh?
at minimum I would do new heads, and a 100mph hone and re ring. because we know what's next....the cam gear coming loose from the cam, blowing a galley plug, or....or....or.....
I dunno....seems your plan is to put good money after bad.....multiple times. I don't want to see anyone do that, but you know...you can lead a horse to water.... _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Tue May 22, 2018 7:57 pm Post subject: Re: Help KentPS get back on the road? |
skills@eurocarsplus wrote: |
having the EXACT same problem on the other head in 800 miles. |
Are you saying the other head may also take a dump due to the possible overheating during the climb up to the Grand Canyon? _________________ -Kent-
---williamM |
Posted: Tue May 22, 2018 8:12 pm Post subject: Re: Help KentPS get back on the road? |
KentPS wrote: |
Are you saying the other head may also take a dump due to the possible overheating during the climb up to the Grand Canyon? |
I think it's about the other head being at the same place in its wear cycle and possibly not far behind. Not trying to speak for Skills, but I think that's the general idea. An engine that's wearing out may have 50 trips for ice cream left in it, but probably not too many Grand Canyon climbs. The engine in and outs eat lots of time and energy and they end up not being free either. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Tue May 22, 2018 8:29 pm Post subject: Re: Help KentPS get back on the road? |
I’ve seen this failure before in Mikes 1979. As I said earlier, unless you pull the injector connector, when you drive on a dead cylinder the fuel washes away the oil lubricating those rings which causes excessive wear.
How many miles did you drive with #3 at zero compression? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
airschooled Air-Schooled
Posted: Tue May 22, 2018 10:27 pm Post subject: Re: Help KentPS get back on the road? |
My vote is for matching replacement heads and new pistons and cylinders.
New heads because there was a failure, and the other head has about as many combustion events as the failed head. Make sure both heads have the same spigot size, valve size, CC volume, and exhaust port shape as your old heads!
New pistons and cylinders because my life is short and $300 is absolutely worth not having to deal with measuring parts with unknown history and milage, machine shops that don't specialize in VWs, and have to explain raygreenwood's very thorough posts to near-retiring machinists who just don't give a damn. The shops that will be able to hone it perfectly, pus the costs of the new rings, plug time to drive to San Diego or Inland Empire to find these machinists all add up… $300 plus an afternoon scrubbing them clean and painting the cylinders black?
www.airschooled.com |
Posted: Wed May 23, 2018 4:49 am Post subject: Re: Help KentPS get back on the road? |
She will be put up for sale. _________________ -Kent-
---williamM |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3330 Location: 802 The Pointless Forrest
Posted: Wed May 23, 2018 5:13 am Post subject: Re: Help KentPS get back on the road? |
Say it ain’t so. _________________ "Albatross"! |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Wed May 23, 2018 5:19 am Post subject: Re: Help KentPS get back on the road? |
Well- at least pull the head off and see what condition the cylinder is in.
Having no history of this engine - it could be a mid miler put together with original heads. So try and ignore all the "could", "Maybes" and "You otta's" and come back with a few facts- With out a micrometer in your hands- its all speculation. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Wed May 23, 2018 7:24 am Post subject: Re: Help KentPS get back on the road? |
KentPS wrote: |
She will be put up for sale. |
I've been there, and I'm sure a lot of other folks here have too. What happened sucks and is a real set back. I will never tell anyone to take shortcuts, but I do recommend weighing your expected use out of this bus against the work that can or should be done. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2541 Location: Ocean Beach in Beautiful BLUE California
Posted: Wed May 23, 2018 8:49 am Post subject: Re: Help KentPS get back on the road? |
scrivyscriv wrote: |
KentPS wrote: |
I've been there, and I'm sure a lot of other folks here have too. What happened sucks and is a real set back. I will never tell anyone to take shortcuts, but I do recommend weighing your expected use out of this bus against the work that can or should be done. |
Hey Kent - I'm nearing the same point in my life. Sad but reality. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
SGKent Samba Member
Posted: Wed May 23, 2018 1:23 pm Post subject: Re: Help KentPS get back on the road? |
OB Bus wrote: |
KentPS wrote: |
Hey Kent - I'm nearing the same point in my life. Sad but reality. |
Kent - are you selling it because of the cost repairing it, or because you no longer trust it? Not prying just want to be sure that this is what you really want. It will bring more running than needing repairs. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Brian Samba Moderator
Posted: Wed May 23, 2018 1:38 pm Post subject: Re: Help KentPS get back on the road? |
KentPS wrote: |
Cool, I could use a bus. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Wed May 23, 2018 2:25 pm Post subject: Re: Help KentPS get back on the road? |
Brian you vulture _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
