Paulbeard Samba Member
Posted: Sat May 19, 2018 10:20 pm Post subject: Re: Cooling system anomaly (overflow tank…overflows?) |
Phaedrus wrote: |
I'm not convinced there's any need to be alarmed...
Dan over at Louis Foreign Auto could sort you out |
This is where I am…Dan knows the Tiico, especially this one, pretty well. I'll keep monitoring it. Maybe not using it as a daily driver is part of the problem… I hear things that ain't there. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Sun May 20, 2018 7:29 am Post subject: Re: Cooling system anomaly (overflow tank…overflows?) |
Paulbeard wrote: |
...No head space in the pressure tank and when cool the overflow tank drops back to MAX or just below... |
Okay - it is quite possible that you simply had the overflow quite full to begin with and opened it while it was in 'expansion mode'.
We all tend to stress a bit about coolant levels and engine heat - so it is normal to read too much into a situation. |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Sun May 20, 2018 3:42 pm Post subject: Re: Cooling system anomaly (overflow tank…overflows?) |
Any air in the system will eventually find its way out via the vent holes in the top of the overflow tank and if the tank is over full it will squirt water out along with the air. I had this happen after I removed the heater core to replace the fan and it wasn't a big deal (and it wasn't a blown water jacket seal which seems to be the default diagnosis on here for anything related to the cooling system). _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
E1 Samba Member
Joined: January 21, 2013 Posts: 6572 Location: Westfalia, Earth
Posted: Mon May 21, 2018 9:16 am Post subject: Re: Cooling system anomaly (overflow tank…overflows?) |
Have you tested the blue cap???
This sounds exactly like when mine have failed -- air bubbles and all. We had three fail within our first year, one black one from FLAPS, and two blue ones that were equally undesirable.
We carry two extras now, all made by Blau.
Here's the test:
https://m.youtube.com/watch?v=RT8Ew43mNg4
Thinking worst-case is never a good idea in Vanagon ownership, not good for blood pressure management. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
