Francoc Samba Member
Posted: Fri May 18, 2018 10:42 am Post subject: How do you ACTUALLY get the fuel tank out? |
79 bus. Firewall is out. Straps are out. Two vapor connections on top are out. Two fuel connections at the bottom are out. Big filler hose is out. I can lift the tank about an inch, but it won’t go all the way up, and that is not nearly enough for the two tubes at the bottom to clear and be able to slide it out. What’s the trick? Help! |
Randy in Maine Samba Member
Posted: Fri May 18, 2018 10:51 am Post subject: Re: How do you ACTUALLY get the fuel tank out? |
Unhook the sending unit connections then push up from the bottom outlets tilting the tank higher in the front and bring it straight back.
Sometimes you have to wiggle it around some.... |
SGKent Samba Member
Posted: Fri May 18, 2018 11:34 am Post subject: Re: How do you ACTUALLY get the fuel tank out? |
you are there. Just have to make sure nothing is holding it in place. There is a foam pad on the bottom that will fall off but it may be hanging up. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Fri May 18, 2018 11:51 am Post subject: Re: How do you ACTUALLY get the fuel tank out? |
Right. It doesn't just pull right out freely. You do have to work at it a bit. IIRC, the top anchoring straps have to be bent up and out a little. But it's been a few years since I have done this... |
Bagger04 Samba Member
Joined: August 03, 2015 Posts: 33 Location: Port Huron, Michigan
Posted: Sat May 19, 2018 11:49 am Post subject: Re: How do you ACTUALLY get the fuel tank out? |
On my 79 with automatic I had to loosen rear mounts and let engine drop a little with a jack, came right out. |
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Sun May 20, 2018 7:00 am Post subject: Re: How do you ACTUALLY get the fuel tank out? |
Bagger04 wrote: |
You can get the tank out with the engine in on later Bays ?? _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
Posted: Sun May 20, 2018 7:09 am Post subject: Re: How do you ACTUALLY get the fuel tank out? |
crukab wrote: |
Bagger04 wrote: |
You can get the tank out with the engine in on later Bays ?? |
IMO it is easier and faster to just remove the engine, but it can be done by removing everything on top of the engine and lowering the engine and transmission as a unit a couple of inches. |
Tcash Samba Member
finkelstein Samba Member
Posted: Wed May 23, 2018 5:39 am Post subject: Re: How do you ACTUALLY get the fuel tank out? |
Randy in Maine wrote: |
crukab wrote: |
Bagger04 wrote: |
Its not too bad. Takes longer to jimmy the fuel filler neck on than anything else. |
Tcash Samba Member
Posted: Wed May 23, 2018 8:19 am Post subject: Re: How do you ACTUALLY get the fuel tank out? |
Lets us know how it was going back in. |
