guzzirider Samba Member
Joined: May 01, 2005 Posts: 107 Location: Durango CO at last
Posted: Fri May 18, 2018 3:15 pm Post subject: NOS VDO Tach in Bay panel |
I am a doing wiring harness replacement in my 69 DOKA. I have a NOS ( new to me ) VDO tach that goes in a bus but am not sure of how to wire it
It has 4 slots for wires in the back of the tach
From left to right: one marked 12V , one marked 6V ( which has no terminal) and then two other terminals one of which looks like it has a "1" above it
I assume one is gauge power, one is a ground and one goes to + on coil correct
Thanks _________________ 69 doublecab with 2" lift
Suzuki DR650
2016 Dodge Crew 1500 4x4 |
Randy in Maine Samba Member
Posted: Fri May 18, 2018 6:02 pm Post subject: Re: NOS VDO Tach in Bay panel |
Suzuki DR650
Posted: Fri May 18, 2018 6:04 pm Post subject: Re: NOS VDO Tach in Bay panel |
so what will make this work I have a coil I am hooking this up to _________________ 69 doublecab with 2" lift
Suzuki DR650
Tbob Samba Member
Joined: May 26, 2007 Posts: 417 Location: Pensacola, Fl.
Posted: Sat May 19, 2018 4:29 am Post subject: Re: NOS VDO Tach in Bay panel |
Guzzirider, I have a VDO tach in my 1973 Bay. The 12v goes to switched power, a black wire on mine, the - goes to ground, brown wire on mine, and the 1 goes not to the coil positive, but to the coil connection that goes to the distributor. Mine is old school with points, not sure if electronic ignition would need something else in between. Hooking to the coil positive(IIRC, black number 15) may blow the tach. The tach signal wire needs some sort of signal to tell it how many times the ignition is triggering. On my van(oops, bus) that is a green wire. _________________ 1969 Deluxe, owned since 1973
1973 Westfalia, owned since 1983
1980 Westfalia, watercooled conversion
1985 Westfalia, stock!
1986 Westfakia, Audi I-4 conversion
A couple of trucks and a couple of Jeeps |
