RICHIE P Samba Member
Joined: May 19, 2018 Posts: 16 Location: St. Paul, MN
Posted: Sat May 19, 2018 5:05 am Post subject: Burning Ignition! |
1971 1600 dual port Beetle driving to work last week the car shut down completely. It was running fine and just shut off about 5 miles shy.... Open decklid to find smoke coming from distributor! I removed cap and rotor to find previous owner had installed a Compu Tronix 'Mighty Module 3' in this vacuum advance distributor.
Upon closer inspection, Found the module was FRIED (wires melted where they met the box).
I acquired points, condenser, new Cap rotor and Bosch blue COIL from a local source and installed everything. I set static timing. Starts right up and runs better than it ever has....
BUT:
I drove it around like 5 miles up and down the rode and parked it, running BEAUTIFULLY and opened decklid only to find and electronic burning smell emanating. I got frustrated, closed the lid and walked away for now....
Locally known VW guru suggested that there's a wiring issue that caused the original ignition model to fry. I looked at wires to coil only choke, oil pressure come off hot side (plus switch) and only condenser to negative side. None of those wires look melted at ALL. The coil is brand new Bosch blue 12v.
HELP! |
sawed off Samba Member
Joined: September 15, 2016 Posts: 428 Location: Idaho
Posted: Sat May 19, 2018 5:24 am Post subject: Re: BURNING IGNITION! |
The electronic ignition kits need a certain ohm coil OR ballast resistor as to not burn up ignition kit. Those ballast resistors get real hot. Most ballasts are ceramic white. Do you have one? Did oil or a bug get into it and your just smelling something cooking? Is the ballast bad? |
Posted: Sat May 19, 2018 6:23 am Post subject: Re: BURNING IGNITION! |
No ballast present. My limited understanding says there's a resistor internal on coil. |
scdevon Samba Member
Joined: October 18, 2017 Posts: 163 Location: Rockies
Posted: Sat May 19, 2018 6:39 am Post subject: Re: BURNING IGNITION! |
How's your charging system voltage and engine ground?
The primary resistance of the coil needs to be around 3 to 4 ohms on these cars with no external ballast resistor. I'm sure your new coil is OK, but it never hurts to check. _________________ 1970 Beetle 1600 DP |
Luft kühl Samba Member
Joined: January 21, 2009 Posts: 1178 Location: Allentown, PA
Posted: Sat May 19, 2018 7:37 am Post subject: Re: BURNING IGNITION! |
RICHIE P wrote: |
I looked at wires to coil only choke, oil pressure come off hot side (plus switch) and only condenser to negative side. |
Oil pressure should not be connected to the coil. Verify that all of your wiring connections are correct.
bluebus86 Banned
Posted: Sat May 19, 2018 8:23 am Post subject: Re: BURNING IGNITION! |
Luft kühl wrote: |
RICHIE P wrote: |
Yeah. when the oil pressure switch closes, it shorts to ground, if hooked to ignition that will cause problems, loss of ignition voltage, and given time a harness meltdown, the ignition circuit is NOT fused. Unless the pressure switch is of very high resistance, I doubt the car could even be started as that switch is closed prior to starting. Maybe the original poster is mistaken on the wiring?
Next time the electric system smokes or smells of burning, please disconnect the battery before leaving the vehicle unattended, walking away. In some cases, even with ignition off, a short may continue to short, resulting in a fire and total loss of the Bug or worse.
Aways DISCONNECT BATTERY in the afore mentioned case, PLEASE!
anyway, welcome to samba, Please provide photos of the engine bay showing the wires, maybe we can make sense of this unfortunate incident.
Bug On with safe wires! We is here to help! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5367 Location: Lefty, CA
vwoldbug Samba Member
Posted: Sun May 20, 2018 9:54 pm Post subject: Re: Burning Ignition! |
Is the wire to choke element pinched behind the carburetor . |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15989 Location: North Florida, USA
Posted: Mon May 21, 2018 5:51 am Post subject: Re: BURNING IGNITION! |
RICHIE P wrote: |
Did you measure the primary resistance in your new coil, or did you just assume it was the same as stock?
The Bosch "blue coil" with part# = 00012 represents a collection of coils and over the years came with different internal primary resistance. This is the problem. There is more than one "Bosch blue coil". Here is a good write up on the problem:
http://www.ratwell.com/technical/BlueCoil.html _________________ AshMan40
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6622 Location: Houston, Texas
Posted: Mon May 21, 2018 10:56 am Post subject: Re: BURNING IGNITION! |
ashman40 wrote: |
RICHIE P wrote: |
http://www.ratwell.com/technical/BlueCoil.html |
You do have to be careful. I had Bosch send me the wrong ones, which I promptly sent back. Unfortunately, 00012 has a few different meanings to them.
Make sure you purchase one from a VW shop and ask to see a picture. Ask if it is epoxy/gel filled.
It should look like this: https://www.thesamba.com/vw/classifieds/detail.php?id=2132647
The newest ones come in the blue and white boxes. You won't see that on ratwell's page. You need to look at the coil itself with the bracket, stamp on the bottom, and connectors. _________________ www.vwnos.com [email protected]
