62kellison Samba Member
Posted: Sat May 19, 2018 6:09 am Post subject: floor pan help please guys. |
i am not a fabricator i am a mechanic by trade.i only have a jobsmart 125amp flux core welder.i wanted to patch this for now.next winter i was going to redo entire pan with new steel and boxed in.i am kinda stuck.the patch pans i have are uniform in depth all the way around.but my buggy pans go from deep to nothing."ramped"..so the back of my patch pan fits in nice.but the front wont.do i cut along the inside seam(bottom bend).a few inches then it will bend up and the sides will then drop down in?.i just dont want more welds or take the strength out of the already thin patch pan.if this makes any sense to u.or can someone give me a better way to put a patch in.ideas?..trying for uncomplicated for now.would like to run buggy for the summer.or maybe i should just tear it all out..and whats a good way to patch the few small holes on the inside edge of tunnel?.the leaves were catching inside the old seat slide rails and rotted thru a couple small spots on tunnel.these pics are the worst rot on the buggy.and i dont think its that bad.everywhere else is solid.except for the battery tray.
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8699 Location: Sunset, Louisiana
Posted: Sat May 19, 2018 7:02 am Post subject: Re: floor pan help please guys. |
You are trying to put a stock shaped patch panel over a floor that has had a section removed when it was shortened. Do whatever you need to do to make it fit. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20377 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat May 19, 2018 7:13 am Post subject: Re: floor pan help please guys. |
Trim replace pan to fit hole or modify hole to fit pan... Try to do butt weld, if you overlap you will create a space where dirt collects, then it will hold moisture, then it will rust some more.... BUT an overlap is acceptable if time or skills is a issue....As Q-Dog says "Do whatever you need to do to make it fit".... As for holes in side of tunnel, you can either cut out offending area and replace with strip of same gauge metal or lay a strip of metal over it... Treat inside of tunnel best you can with a rust neutralizing/preventative chemical first...... As for welds since material is thin your 125 amp FCAW machine can do it with no problem, finishes product will depend on your welding skills/technique... Biggest issue here is going to be burn through as materials is pretty thing... Might have to resort to body shop technique which is about 5,000,000 tack welds around perimeter till you finally have a full bond all the way around patch....
http://weldingtipsandtricks.com
As somebody here on the Samba stated, "do your temporary patches well becasue they tend to become permanent"...
Posted: Sat May 19, 2018 2:49 pm Post subject: Re: floor pan help please guys. |
thanks guys.i trimmed it down and beat the sides down.it actually came out way better than expected.thanks.i did whatever it took... |
