Is there an A/C solution? Air Conditioning fail/fix/fail/repeat
mg93108
mg93108 is offline
PostPosted: Sat May 19, 2018 12:53 pm    Post subject: Is there an A/C solution? Air Conditioning fail/fix/fail/repeat Reply with quote
So what's the deal with the A/C?
I don't mean WHY does it fail....I mean HOW TO FIX it?
It is a rare day that a properly working air conditioner is seen in these.
I've owned 7 of them and the best I did was get one to run for 6 months after dropping $1000 into it.
What needs to be altered?
Is one compressor superior? I've heard the newer models (87 and newer?) have a 7 cylinder compressor and the old ones had only 5. Not sure if that's accurate at all.
Any suggestions or help would be appreciated
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sat May 19, 2018 1:46 pm    Post subject: Re: Is there an A/C solution? Air Conditioning fail/fix/fail/repeat Reply with quote
a/c is pretty bulletproof really....
I replace all hoses, receiver drier and condenser with one meant for a 134A system. USUALLY the evaporators are trouble free.
sometimes I will do a compressor, but not right away. I get the system up and running then decide if I like it or not by watching pressures.
every automotive system loses about 1/4lb per year due to the vibration etc. a typical system should go 5-6 years before it needs a sniff of the magic gas to make it perform well
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
Ahwahnee
Ahwahnee is offline
PostPosted: Sat May 19, 2018 2:50 pm    Post subject: Re: Is there an A/C solution? Air Conditioning fail/fix/fail/repeat Reply with quote
I had mine (an 84) done by a local shop and have been quite impressed with the result.
They replaced the hoses using barrier hoses, went with a later 3-speed radiator fan, installed a new radiator, a larger modern condenser and charged it with R12.
There has been no need for additional service or charge in the 6 years since.
Bottom line - these things can be made to work quite well.
MsTaboo
MsTaboo is offline
PostPosted: Sat May 19, 2018 3:27 pm    Post subject: Re: Is there an A/C solution? Air Conditioning fail/fix/fail/repeat Reply with quote
As noted by others, the hoses make a big difference. 30 year old hoses/fittings are gonna leak.
Plan on replacing all the hoses with newer style barrier hose. The new reduced diameter hose is easier to route and takes up less room.
I used the EZ-Clip system from Eaton, which does not require an expensive clamping tool.
https://hosewarehouse.com
http://www.eaton.com/Eaton/ProductsServices/Hydrau.../index.htm
http://www.coldhose.com
Do a search here on theSamba, lots of threads about all this.
Currently:
Defend democracy, support Ukraine.
elizer Premium Member
elizer is offline
PostPosted: Sat May 19, 2018 3:38 pm    Post subject: Re: Is there an A/C solution? Air Conditioning fail/fix/fail/repeat Reply with quote
My compressor went. I had a shop replace with a rebuilt condensor, new receiver dryer, expansion valve and went with 134a. It blows cold. I am impressed. I have nothing to compare it to because the compressor went on my maiden voyage.
I had a thermometer in the fridge to check to see how it was cooling so I hung it in front of the a/c vents.
djkeev
djkeev is offline
PostPosted: Sat May 19, 2018 3:48 pm    Post subject: Re: Is there an A/C solution? Air Conditioning fail/fix/fail/repeat Reply with quote
IF you want to fix your A/C once and have it last for the next 20 years, do it right.
As you know, band aids, even expensive band aids, don't work.
Replace the Condenser, the Hoses, Rec/Drier and yes..... the Compressor.
Flush out the Evaporator and expansion valve.
Reassemble, fill with r134a, get out your sweat shirt in the Summer and put it on for your A/C will be c c c c COLD! You'll appreciate the warmth.
My Wife bundles up in the front seat and dhaavers wife wraps up in a blanket!
https://www.thesamba.com/vw/forum/viewtopic.php?t=583818
Dave
Ghia
Vanagon
Beetle
Abscate
Abscate is offline
PostPosted: Sat May 19, 2018 9:28 pm    Post subject: Re: Is there an A/C solution? Air Conditioning fail/fix/fail/repeat Reply with quote
You get your AC license by owning
Vacuum pump
Manifold gauge set
You lose your license if you own
Any gauge on a hose type attachment to “top up your Freon”
Any Stop leak product for AC
.ssS!
markz2004
markz2004 is offline
PostPosted: Sun May 20, 2018 11:17 am    Post subject: Re: Is there an A/C solution? Air Conditioning fail/fix/fail/repeat Reply with quote
Redtek. Check the thread out.
87 Westy, 250k GW 2.4 - 2.0 Wink, 16" wheels
mg93108
mg93108 is offline
PostPosted: Wed Jun 20, 2018 7:53 am    Post subject: Re: Is there an A/C solution? Air Conditioning fail/fix/fail/repeat Reply with quote
What thread?
fxr
fxr is offline
PostPosted: Wed Jun 20, 2018 8:52 am    Post subject: Re: Is there an A/C solution? Air Conditioning fail/fix/fail/repeat Reply with quote
mg93108 wrote:
What thread?
https://www.thesamba.com/vw/forum/viewtopic.php?t=292488
Jim Crowther
Vespa GTS 300
Howesight
Howesight is offline
PostPosted: Wed Jun 20, 2018 11:14 am    Post subject: Re: Is there an A/C solution? Air Conditioning fail/fix/fail/repeat Reply with quote
The single most important item in repairing/restoring a Vanagon AC system is to replace all the hoses with modern barrier hoses. If this is not done, then the annual re-charge or even twice-annual recharge will be required.
This is the 5th anniversary of installing my made-from-scratch DIY Front AC system and the performance has not declined in any way. Except for the 18-year-old compressor that came with my Subaru SVX engine, all my components were new.
FWIW, the Vanagon condenser is not very efficient, but it rarely fails or leaks. The Vanagon evaporator is also very robust, almost never fails, and is very large. The TXV and the Receiver/Drier are simply maintenance items you change any time you open the system. Replacing the hoses is key.
Allowing your AC system to operate with a low fill of refrigerant is asking for compressor trouble. Yes, there is a low-pressure switch designed to prevent catastrophic and immediate compressor death, but running with low refrigerant is just a milder assault on the system as contrasted with a death blow. The refrigerant is what carries the lubricating oil into and through the compressor. The lower the refrigerant density, the lower the oil quantity circulated through the compressor. Think of it as similar in concept to the reduced oxygen available to mountaineers at high altitudes.
'86 Syncro Westy SVX
