Mrfun2fly Samba Member
Joined: November 29, 2015 Posts: 548 Location: New Mexico
Posted: Sat May 19, 2018 7:03 pm Post subject: Ignition wont stay running |
So here's the scoop, my car wont stay running unless I hold the key in place and as soon as I let go of the key, some sort of connect is lost and car dies:(
what can this be??
Thanks! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Sat May 19, 2018 7:05 pm Post subject: Re: Ignition wont stay running |
bad ignition switch. _________________ Glenn
Member #1009
#BlueSquare |
xzener Samba Member
Posted: Sun May 20, 2018 11:37 am Post subject: Re: Ignition wont stay running |
Glenn is right. Had the same problem, had to hold the key in the "ON" position to keep her going. Depending on the year, this is what fixed my 68 ignition...
_________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Starbucket Samba Member
Posted: Sun May 20, 2018 3:07 pm Post subject: Re: Ignition wont stay running |
If you have a bunch of keys on your key ring, try using the key alone. |
Posted: Sun May 20, 2018 3:37 pm Post subject: Re: Ignition wont stay running |
Glenn wrote: |
bad ignition switch. |
I pulled the key cylinder today so I'm prepared tomorrow when I get a new switch. After pulling the cylinder, I noticed there seems to be a decent amount of play in the the Key cylinder (or what this is called lol)
what's your thoughts??
Thanks! |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32630 Location: Reading Pennsylvania
Posted: Tue May 22, 2018 9:07 am Post subject: Re: Ignition wont stay running |
Yup, as you all said it was the the switch not the tumbler. Replaced last night, unfortunately w a cheap Chinese one but what options do I have so hopefully we can get a little time out of it.
Thanks again! |
