ThatClassic71Bug Samba Member
Posted: Sun May 20, 2018 3:32 am Post subject: RUST RUST RUST |
So i know the ideal thing to do would be to just change the pan or get a new bug but both of those are too much of a task.
Anyone have any DIY ideas to solve this rust problem? I thought thin malleable sheet metal that i could fold around the channel then fasten down would work.
Any ideas would be appreciated.
This is under my front right fender
green1303 Samba Member
Joined: February 04, 2014 Posts: 748 Location: Alexandria, VA
Posted: Sun May 20, 2018 3:43 am Post subject: Re: RUST RUST RUST |
That’s not a patch job, you need new heater channels and probably other rust repair around them. I did that job myself, but it takes some time. _________________ 1973 green Super Beetle |
Posted: Sun May 20, 2018 3:49 am Post subject: Re: RUST RUST RUST |
Yeah new heater channels would be amazing, but I'm looking for a temporary fix until i can afford that.
Cost of heater channels + someone to fit them.
I've seen Rick Higgins' and Chris Vallone's videos on heater channel replacement and its quite a job |
AlmostHeavenWV_VW Samba Member
Posted: Sun May 20, 2018 6:49 am Post subject: Re: RUST RUST RUST |
ThatClassic71Bug wrote: |
The problem with a 'temporary' fix for heater channels:
The heater channels are part of the structural frame of the chassis. Think more of them as frame rails that just happen to be used to carry heated air.
Bum frame rails are not something to try and 'bodge' or 'patch', the only fix is the proper fix. Otherwise, the vehicle's safety is compromised. _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Posted: Sun May 20, 2018 7:21 am Post subject: Re: RUST RUST RUST |
I'm with the previous members, either fix it correctly or don't bother until you can. Slap on the running boards and hide it until you find the time/money/help. _________________ **1971 Super Project
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Sun May 20, 2018 7:56 am Post subject: Re: RUST RUST RUST |
Agree with the above. If you cannot fix both right now, just fix one side, the worse one. You can lift the body off on one side and rest it on 4x6 blocks on the other side. Weld in a new channel and it looks like you may need a few other body pieces. Get that one side good, then save your pennies for the next side! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
sshulk Samba Member
Joined: August 29, 2008 Posts: 694 Location: Succasunna, NJ
Posted: Sun May 20, 2018 1:32 pm Post subject: Re: RUST RUST RUST |
Guys In my club, Filthy Buggers, they run really rusty cars. Rustier than that. What they did was weld a bar across the bottom along the door. Now when you hit a bump that whole car shakes a little less. But by doing this it helps the structural integrity of the car a little more. _________________ 17 years old
German Looker in the Making
73 Super Autostick OG paint Marina Blue
72 Super
60 Mango Ragtop Camper Bug Project Thread
63 Ragtop Project
73 Auto Westfalia
2056 Type 4 Engine Build Thread
Filthy Buggers |
Frodge Samba Member
Posted: Sun May 20, 2018 1:36 pm Post subject: Re: RUST RUST RUST |
sshulk wrote: |
Guys In my club, Filthy Buggers, they run really rusty cars. Rustier than that. What they did was weld a bar across the bottom along the door. Now when you hit a bump that whole car shakes a little less. But by doing this it helps the structural integrity of the car a little more. |
That’s pretty awful. |
67ctbug Samba Member
Posted: Sun May 20, 2018 2:53 pm Post subject: Re: RUST RUST RUST |
You need new channels... no patching that, it's the whole structure of the body. I made a YouTube video going over the repair. It's not that really that hard if you can weld, but it is important to do it right. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Starbucket Samba Member
Posted: Sun May 20, 2018 2:54 pm Post subject: Re: RUST RUST RUST |
Don't put two Surfboards on the roof and go 65 MPH. I had a Ghia that looked like that, back in the 60's ($35) and I was coming back from the beach with my friend and the whole body started to lift, side streets all the way home then off to the junkyard. |
sshulk Samba Member
Posted: Sun May 20, 2018 4:19 pm Post subject: Re: RUST RUST RUST |
Frodge wrote: |
sshulk wrote: |
Yeah but it does work. They plan to do the work on their cars but until they get the time it’s a temporary “fix” they use. _________________ 17 years old
72 Super
63 Ragtop Project
73 Auto Westfalia
Filthy Buggers |
Posted: Mon May 21, 2018 12:46 am Post subject: Re: RUST RUST RUST |
Starbucket wrote: |
This is amazing =D i can picture mine doing it as i do surf. Getting the 65 mph is more rare =D |
Posted: Mon May 21, 2018 12:48 am Post subject: Re: RUST RUST RUST |
sshulk wrote: |
THANKYOU this is the type of answer I'm looking for as it is what i had in mind.
Rather than just continuing to drive on the Compromised shell - Temp fix is better than the body flying off aster a cold surf =D |
Joined: August 31, 2013 Posts: 12857 Location: North Carolina
Posted: Mon May 21, 2018 4:00 am Post subject: Re: RUST RUST RUST |
WTF?!? Do not drive a car in this condition. Forget about the fact that this is a large part of the structural integrity of the body, the heater channels are the outer structural member of the floor pans. If the heater channels are this bad then the pans are probably worse unless they have been replaced and if they have, they rely even more on the heater channels for support as they are thinner than the original pans.
Driving a vehicle in this condition is dangerous! Don’t be the idiot that puts their life at risk just because another pack of idiots bubble gum, duct tape, & bailing wire their shit back together to impress the rest of their idiot buddies. It’s just a “hardcore” downward spiral into the lowest common denominator. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Zundfolge1432 Samba Member
Posted: Mon May 21, 2018 4:18 am Post subject: Re: RUST RUST RUST |
TDCTDI wrote: |
Driving a vehicle in this condition is dangerous! Don’t be the idiot that puts their life at risk just because another pack of idiots bubble gum, duct tape, & bailing wire their shit back together to impress the rest of their idiot buddies. It’s just a “hardcore” downward spiral into the lowest common denominator. |
I’m afraid your good advice will fall on deaf ears. They are looking for approval and acceptance not logic. |
calo1956 Samba Member
Joined: April 18, 2011 Posts: 701 Location: long Island new york
Posted: Mon May 21, 2018 4:51 am Post subject: Re: RUST RUST RUST |
There are 37,000 fatalities on the highways every year, take a pro active approach, and spare the deviation of innocent lives lost... _________________ Enjoy the ride....
72 bug
80 westfalia |
sshulk Samba Member
Posted: Mon May 21, 2018 6:40 am Post subject: Re: RUST RUST RUST |
Dont get me wrong, I personally wouldn't drive a car unless it was decentt safe A little rust is fine, but not something rusted out, I just answered the OP's question, is there a temporary solution that could be used. Which is yes, although unsafe, it is a solution that would work. _________________ 17 years old
72 Super
63 Ragtop Project
73 Auto Westfalia
Filthy Buggers |
Posted: Mon May 21, 2018 6:43 am Post subject: Re: RUST RUST RUST |
sshulk wrote: |
Dont get me wrong, I personally wouldn't drive a car unless it was decentt safe A little rust is fine, but not something rusted out, I just answered the OP's question, is there a temporary solution that could be used. Which is yes, although unsafe, it is a solution that would work. |
If it's unsafe, it's not a working solution. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Frodge Samba Member
sshulk wrote: |
If it is a solution that is unsafe, how would it work? |
PuddleRainbow Samba Member
Joined: April 13, 2018 Posts: 288 Location: The Dirtiest Of Jersey
Posted: Mon May 21, 2018 6:51 am Post subject: Re: RUST RUST RUST |
We're all driving 45+ year old cars calling each other "unsafe" lol...... |
