IoWesty Samba Member
Posted: Sun May 20, 2018 5:57 am Post subject: Rubber Windoow Seals Bleed |
I still have the original rubber seals on my van The rubber appears to be in good shape. However, when I wash the van, the black from the rubber bleeds on to the paint when I wipe it dry resulting in black streaks.
Short of replacing all the rubber, are there any recommended rubber conditioners/restorers I should try? |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Sun May 20, 2018 8:54 am Post subject: Re: Rubber Windoow Seals Bleed |
Hi
Hard to believe 35-year old rubber seams are in good shape! Can you post some pictures? _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4098 Location: East Kootenay, British Columbia
Posted: Sun May 20, 2018 9:13 am Post subject: Re: Rubber Windoow Seals Bleed |
Mine do the same thing. It's aging. Have had it from other older vehicles.
You can help keep the rubber in good condition with different products. I use "303", but there are other cheaper products like "Back to Black"
After washing the van, treat the seals. Keep the stuff off the paint. _________________ Currently:
Defend democracy, support Ukraine.
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Posted: Sun May 20, 2018 9:15 am Post subject: Re: Rubber Windoow Seals Bleed |
gummi pflege or straight glycerine from the pharmacy might do the trick. New german seals are always a good alternative at this point. |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Mon May 21, 2018 9:36 am Post subject: Re: Rubber Windoow Seals Bleed |
I've been told the wiping and cleaning the window seals with lemon pledge helps. Give that a try. |
benandmj Samba Member
Joined: October 29, 2012 Posts: 550 Location: Atlanta
Posted: Mon May 21, 2018 9:41 am Post subject: Re: Rubber Windoow Seals Bleed |
Steve Arndt wrote: |
https://www.youtube.com/watch?v=uklF7VtqJq8 _________________ 85 Westfalia Weekender
91 Syncro Westy |
