BillllyJ Samba Member
Posted: Sun May 20, 2018 9:58 am Post subject: EJ 22 Swap Acceleration Problem |
Yo! I am looking for some input on an acceleration problem with an EJ 22 swap on a 1982 Diesel van. A problem recently developed in which the van seems to lose power when the gas pedal is depressed further; things seem to work well until the gas pedal hits a certain point and then the engine seems to lose it. The problem seems to be exacerbated while pulling up hills.
The vehicle ECU was recently replaced which solved a persistent electrical problem in which a few dash lights would stay on after removing the key.
I have a scan gauge hooked up and it is throwing a P0180 code which is apparently for a fuel temperature sensor. I am not sure if these Subaru swaps generally even have a fuel temperature sensor but I am sure a few of you would know the answer to that.
I have heard the fuel pump humming in the past and am going to install the Go West Fuel Filter upgrade kit. (Remove the pre-filter).
I am looking for other suggestions as to what this might be. I know it could be a number of things but I am learning The Samba Knows Best.
Thanks! |
Joined: April 29, 2015 Posts: 704 Location: Berkeley Ca
Posted: Sun May 20, 2018 10:17 am Post subject: Re: EJ 22 Swap Acceleration Problem |
Do you have vss installed?
Definitely remove prefilter.
Problem happens around 4 k rpm?
Sounds like you are obd2? |
wcdennis Samba Member
Joined: July 20, 2004 Posts: 955 Location: Winston-Salem NC
Posted: Sun May 20, 2018 10:57 am Post subject: Re: EJ 22 Swap Acceleration Problem |
Check the condition of your catalytic converter. |
AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1698 Location: The Old Pueblo
Posted: Sun May 20, 2018 5:24 pm Post subject: Re: EJ 22 Swap Acceleration Problem |
Check your timing belt. Mine jumped the boogey when I did a rolling start. Just two teeth and the van runs but lacks power and gets bad mileage. 1stclue was the motor was bouncing around at idle. 2nd clue was the power was down. Just a thought and pretty easy to inspect. _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
Posted: Sun May 20, 2018 9:58 pm Post subject: Re: EJ 22 Swap Acceleration Problem |
VSS I am not so sure. Vehicle speed sensor I assume? This van is new-ish to me and I am learning like so many of us. The speedometer itself is off but my scangauge appears dead on. OBD2 yes. Indeed the problem does seem to occur in the 3500-4000 RPM range. She is jumpy. She goes then she slows. Then she goes. You get the idea.
I have not yet gotten to remove the pre-filter and install a new filter or check the timing belt. I am hoping it is as easy as a clogged fuel filter.
This is not to mention the absurd issues with lights, blinkers, and wipers. Weird van. |
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1490 Location: Victoria,B.C.Canada
Posted: Mon May 21, 2018 4:10 am Post subject: Re: EJ 22 Swap Acceleration Problem |
Sounds like it could be your speed sensor (VSS). If you have an in/out diagnostic diagram for your ECU you could locate the VSS input and test for voltage when the van is running or the rear wheel is turning if it is attached to the rear wheel CV. The sensor could be out of adjustment,dirty or damaged. Another location for the VSS is on the back of the speedometer or in the O2 counter box in the speedometer cable, but you probably have the CV VSS. The VSS will have 3 wires - power,ground and signal. You could test the signal wire for voltage while turning the wheel if manual trans. Some sensors (larger cylindrical type Hall or Proximity) have a small LED that illuminates with a signal. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16502 Location: Brookeville, MD
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1857 Location: anchor pt. alaska
Posted: Mon May 21, 2018 7:21 pm Post subject: Re: EJ 22 Swap Acceleration Problem |
I've got a 2.5 suby with the cv joint flange mounted vss. It quit working a couple months ago. Looks like a rock hit it. Gotta fix it still. Anyhow if it is your vss it will trigger a limp mode at a very specific rpm and you start bucking and lose power. I don't have a tach but mine triggers at 53mph in third gear. I can drive 52 mph with no problem. If your issue is repeatable at exactly X rpm, they say around 4000 then you would have an easy fix. |
Posted: Mon May 28, 2018 12:39 am Post subject: Re: EJ 22 Swap Acceleration Problem |
Update: I removed the stock pre-filter and installed a new post pump fuel filter and it seems to have remedied the issue in full. Thanks for the input everyone! |
