Keeponbussin77 Samba Member
Posted: Sun May 20, 2018 10:24 am Post subject: vacuum hose/stud size |
Hi all,
I've finally got the engine back in my bus, but I'm having trouble locating some of the connecting bits. What kind of hose is used for the vacuum line that connects the brake booster to the carb balance bar, and what are the little round plastic relay things interspersed with the hose called? Also, could someone tell me the size stud used to attach the crossmount to the van? 1974 bus t4 engine, by the way. forgot to include.
Thanks, and keep cruising.
Last edited by Keeponbussin77 on Mon May 21, 2018 7:09 pm; edited 1 time in total |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16926 Location: San Diego, California
Posted: Sun May 20, 2018 10:48 am Post subject: Re: vacuum hose/stud size |
https://www.rockauto.com/en/parts/gates,27231,vacuum+hose,230
The inline thingy is a check valve. Can you be more specific on which bolt you mean? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Tcash Samba Member
Posted: Sun May 20, 2018 11:45 am Post subject: Re: vacuum hose/stud size |
[quote="Keeponbussin77"]
https://www.belmetric.com/advanced_search_result.h...um%2C+fuel
Also, could someone tell me the size stud used to attach the cross mount to the van?
thx to jersey
Good luck
Tcash |
Randy in Maine Samba Member
Posted: Sun May 20, 2018 2:30 pm Post subject: Re: vacuum hose/stud size |
Assuming you are meaning the four bolts that attach the mustache bar to the frame rails, the originals were 8mm in diameter, but 5/16" bolts will work just as well. Either should be used with locknuts, preferable the crimped style, but nylocks will do. |
SGKent Samba Member
Posted: Sun May 20, 2018 2:42 pm Post subject: Re: vacuum hose/stud size |
OP - you need to specify what year and what type engine. I read your comments to be a T1 but others see a T4 engine. The answers are different.
On an early bay there is a braided cloth covered hose that runs from the engine to the brake booster. On a late bay there are plastic lines with rubber inserts, along with a rubber tee that go from the engine to the booster.
On an early bay the crossmember aka mustache bar is held on with three bolts then two at the engine mounts. On a late bay there are two rubber mounts on the engine, and the crossmember aka mustache bar is held to the frame rail with 4 bolts.
There are also differences in how the transmission mounts between early and late. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Tcash Samba Member
Posted: Sun May 20, 2018 5:22 pm Post subject: Re: vacuum hose/stud size |
Ha I thought Keeponbussin77, had a 77.
Keeponbussin77 wrote: |
Howdy all,
I'm spending my spare time rebuilding a 1974 Volkswagen Bay Window with that sweet, sweet 2.0 Liter type IV. The engine has most of the tin, but it's missing a few components. Does anyone know where I could find some kits or pieces to replace the lost ones? All I seem to be able to find are upright engine kits for the tin, and it's pretty frustrating. Thanks, all.
Also: The bus is being rebuilt for a sweet roadtrip to SoCal after college. Any tips for long distance travel? Don't bother with telling me to do a Subie swap-- I'm keeping her as original as possible. Thanks! |
Posted: Mon May 21, 2018 7:13 pm Post subject: Re: vacuum hose/stud size |
SGKent wrote: |
There are also differences in how the transmission mounts between early and late. |
74, t4 engine. apologies for forgetting. What size studs? and are you sure about the vacuum hose? The crusty one I have looks like regular braided hose. |
Posted: Mon May 21, 2018 7:51 pm Post subject: Re: vacuum hose/stud size |
You want vacuum rated hose of the correct size, whether it has a braided covering is not important. |
