maz-o Samba Member
Joined: February 21, 2017 Posts: 79 Location: Helsinki, Finland
Posted: Sun May 20, 2018 11:52 am Post subject: Best way to seal cracked crankcase seam? |
It looks like a previous owner teared open the case halves with a crowbar or something. There's a relatively big crack (or gap) below the flywheel under the last bolt (pictured below).
There's a similar yet smaller one on the other side below the oil pump. Both leak. It was stuffed with a silicone sealant at some point, which flew right off when I cleaned the engine with degreaser and a wire brush.
Question is what's the best way to seal it up without having to tear apart the whole engine.
Thanks!
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Sun May 20, 2018 12:12 pm Post subject: Re: Best way to seal cracked crankcase seam? |
leave it alone. it's not really on the sealing surface. if it does leak however, the case is kind of junk....unless you split it and go a little crazy with some extra sealant in that area _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Danwvw Samba Member
Posted: Sun May 20, 2018 1:51 pm Post subject: Re: Best way to seal cracked crankcase seam? |
Yeah, the case looks pretty normal to me, Hopefully, it's just near the edge and not across the sealing surface. Fixing it requires complete engine disassembly. But Yeah, that is not where your oil is likely leaking! Oil pump's usually seep a little and I would not worry about that unless it's leaving a drip on the garage floor in which case you can remove the oil pump and use new gaskets and case sealer to seal it. I don't use case sealer on the outer pump gasket just the inner one. Some people don't even use the thin outer gasket so it will make better oil pressure without the gap of the gasket.
Flywheel end oil leaks are usually a sign of a worn out engine where the #1 main bearing is loose in the case or it could just be a bad main seal. Still got to pull the engine and clutch to get to it. Does the engine have any end play at the crank pulley? (Car in neutral remove the fan belt and set it on a TDC or BDC) to test If it clunks when pushed in and out, if so then it needs rebuilding. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Sun May 20, 2018 1:55 pm Post subject: Re: Best way to seal cracked crankcase seam? |
Sweet Jesus.
Drain oil
Let sit overnight.
Degrease the area from top and bottom with acetone and hexanes ( MAF cleaner)
Paper towel dry.
JB weld into crack area and let set overnight _________________ .ssS! |
timvw7476 Samba Member
Posted: Sun May 20, 2018 1:58 pm Post subject: Re: Best way to seal cracked crankcase seam? |
^ try this, only I am lazy so I would leave the oil in & use brake parts cleaner^
that way you can try over & over again til is quits dripping. /sarc |
Danwvw Samba Member
Posted: Sun May 20, 2018 2:02 pm Post subject: Re: Best way to seal cracked crankcase seam? |
It's never a leaking case, it's the oil is coming from above.
I just realized you have the engine out, no big deal to check the main bearing (by checking crank end play) and install a new main seal, do you have a torquemaster?
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Sun May 20, 2018 2:22 pm Post subject: Re: Best way to seal cracked crankcase seam? |
Danwvw wrote: |
I agree pretty much.
That exact case joint......unless they had the bolt out and literally hammered the flat blade screwdriver all the way through to the case inside.... or ...through really hard prying....actually warped the case in that area.....then that is not what is leaking.
If they did jam teh screwdriver all the way through...then most likely the case is warped and as Skills noted....then its junk.
Ray |
Posted: Sun May 20, 2018 2:25 pm Post subject: Re: Best way to seal cracked crankcase seam? |
Is the engine out? If so flip it over and spray the area well with brake cleaner repeatedly and then fill the crack with JB Weld or Ultra Silicone. Loctite hydraulic sealand might work as well, it should be able to wick into the crack quite a ways.
I do agree that your leak may be coming from somewhere else but if it is coming from there and you can flip the case then now is the time to do any sealing you can there. |
SGKent Samba Member
Posted: Sun May 20, 2018 2:54 pm Post subject: Re: Best way to seal cracked crankcase seam? |
define leak - all VW engine eventually leak some oil. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Sun May 20, 2018 3:23 pm Post subject: Re: Best way to seal cracked crankcase seam? |
Whatever you use it has to be able to be applied to wet oil. It’s just not possible to drain the oil and expect the area to drip dry or even be able to be cleaned well enough for most sealants to stick. You need something like we used in aviation to seal running fuel leaks from integral wing fuel tanks. It was like two tootsie rolls that you’d mix in your hands and then push up into the seam and flatten out. It would stick and become hard as a rock in about 30 minutes. This was an approved temporary repair. I believe it was called Lyco Tabs but google isn’t helping me right now. The point is, RTV won’t stick and you’ll be wasting your time. Maybe JB Weld will work but their description didn’t say it would seal an oil leak. At least that I could find.
Found it
http://www.laco.com/repair-sealants/epoxy-tabs-type-o-/
LA-CO OylTite-Stik Oil Leaks Repair Sealant Stick, 1-1/4 oz https://www.amazon.com/dp/B002C3L5NO/ref=cm_sw_r_cp_api_i_.FFaBbB7H0R6G _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Tcash Samba Member
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sun May 20, 2018 6:02 pm Post subject: Re: Best way to seal cracked crankcase seam? |
aeromech wrote: |
Found it
LA-CO OylTite-Stik Oil Leaks Repair Sealant Stick, 1-1/4 oz https://www.amazon.com/dp/B002C3L5NO/ref=cm_sw_r_cp_api_i_.FFaBbB7H0R6G |
I will now drink more alcohol when I fly commercially..... _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Sun May 20, 2018 6:12 pm Post subject: Re: Best way to seal cracked crankcase seam? |
TomWesty wrote: |
aeromech wrote: |
Found it
I will now drink more alcohol when I fly commercially..... |
I’m ok with repairs like this because they have to pass muster.
It’s forgetting to lube the elevator jackscrew, or not following the BOEING repair manual on the tail bulkhead repair , that keeps you sitting up straight _________________ .ssS! |
Posted: Sun May 20, 2018 6:24 pm Post subject: Re: Best way to seal cracked crankcase seam? |
Abscate wrote: |
TomWesty wrote: |
aeromech wrote: |
Found it
It’s forgetting to lube the elevator jackscrew, or not following the BOEING repair manual on the tail bulkhead repair , that keeps you sitting up straight |
Me too. Commercial flight in the US has an impressive safety record. _________________ If you haven't bled on them, you haven't worked on them.
Mispeld Samba Member
Joined: April 29, 2018 Posts: 355 Location: Jacksonville - Coastal NC
Posted: Sun May 20, 2018 6:27 pm Post subject: Re: Best way to seal cracked crankcase seam? |
Maybe this???
Couldn't help it. I'll let myself out.... |
Posted: Sun May 20, 2018 6:47 pm Post subject: Re: Best way to seal cracked crankcase seam? |
They didn’t forget to lube the jackscrew. They didn’t have the proper tool in stock so they deferred it. Then maybe they forgot. Plus the bulkhead repair was caused by the engineers who drew it up, not the sheet metal mechanics that followed their drawings. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Sun May 20, 2018 7:16 pm Post subject: Re: Best way to seal cracked crankcase seam? |
aeromech wrote: |
They didn’t forget to lube the jackscrew. They didn’t have the proper tool in stock so they deferred it. Then maybe they forgot. Plus the bulkhead repair was caused by the engineers who drew it up, not the sheet metal mechanics that followed their drawings. |
Yeah that one was complicated. They were extending service interval but their tool to detect wear wasn’t accurately doing so. I think they Also Found the boiled hours were 1/4 the MFG hours. Good if you are skills, not good for aeroplanes.
The bulkhead one I was think about was JAL123 which was on the repair , since they cut the splice plate. Fail
I guess you can put it in BOEING for not saying “ don’t cut the splice plate, whose function is to transfer load across the crack”
But that’s kind of ENG 000 _________________ .ssS! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
Posted: Sun May 20, 2018 7:22 pm Post subject: Re: Best way to seal cracked crankcase seam? |
Mispeld wrote: |
Maybe this???
Don't laugh, I used a similar product to seal the inside of a porous toilet tank that was weeping. It's been 5 years and the outside is bone dry. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun May 20, 2018 7:46 pm Post subject: Re: Best way to seal cracked crankcase seam? |
Well I can’t speak for other aircraft mechanics, only myself. I worked for 23 years under my FAA license. Many of those years as a lead mechanic. I’ve signed off hundreds of log books in that time. Never once was I investigated or disciplined for anything. I think most other A&P’s fit in that description. One guy I worked with did get in a lot of trouble but like most mistakes, it got passed not only him but an inspector as well. He crossed the hydraulic lines when he changed a rudder pcu on a 737 back around 2002. The plane arrived in CLT with one empty system and the other overfilled and puking overboard. The redundancy built into the rudder system saved the day _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Mon May 21, 2018 4:09 am Post subject: Re: Best way to seal cracked crankcase seam? |
aeromech wrote: |
... You need something like we used in aviation to seal running fuel leaks from integral wing fuel tanks. .. |
Also got a click patch, https://www.aircraftspruce.com/catalog/hapages/04-06015.php I have never personally used them though. When I got called in it was because the leak was bad enough someone had to get in the tank
in the OP's case though I don't think an external adhesive sealant repair at the case damage is the solution.. besides the fact that external sealants are almost always a temporary repair. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
