Bob Brugge Samba Member
Joined: April 09, 2015 Posts: 721 Location: Missoula, MT
Posted: Sun May 20, 2018 12:31 pm Post subject: Stuck, help needed |
Hi guys.
I got my motor all put together and installed. I didn't change the stud on the oil cooler. Now it leaks everywhere.
Pulled the engine back out and tore off the fan shroud It was a sp engine and now it is a dp engine.
There is a stud that comes out of the case and holds down the side of the oil cooler. The sp one is shorter than the dp one. I have been trying the double nut method to remove it but all it does is pull the threads out of the top nut. Got some grade 8 nuts and same same.
So now I am stuck with a stud that is too short and no way to get it out. It is a universal case, and the case I have on my floor is the same type of universal case. The stud came out of it just fine.
I have thought about trying heat and vice grips, if that doesn't work, then I am really stuck. Any ideas? _________________ Keep on Dubbin'! |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Sun May 20, 2018 12:40 pm Post subject: Re: Stuck, help needed |
Heat and vice grips for starters.
If that fails. Grind the stud flush with the case. Center punch it accurately. Then drill it out. Start with a pilot hole and slowly work up in bit sizes until you can pick at the threaded part left over in the case. Be very careful not to drill through the top of the case.
It's likely had red locktite applied to the threads and it's good and stuck.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3466 Location: Paradise, Ca
Posted: Sun May 20, 2018 12:55 pm Post subject: Re: Stuck, help needed |
Why did it leak? |
veeweeman Samba Member
Joined: December 20, 2009 Posts: 940 Location: New Port Richey, FL
Posted: Sun May 20, 2018 3:04 pm Post subject: Re: Stuck, help needed |
jpaull wrote: |
Why did it leak? |
That was what I was wondering. .. _________________ Never be a follower...Do your own thing, make it your own! |
jason Samba Member
Posted: Sun May 20, 2018 3:46 pm Post subject: Re: Stuck, help needed |
He only used 2 of the three studs. |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4858 Location: sanger ca
Posted: Sun May 20, 2018 4:13 pm Post subject: Re: Stuck, help needed |
jason wrote: |
If that is the case some one should just step away from the tool box _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Mon May 21, 2018 4:36 pm Post subject: Re: Stuck, help needed |
The bastard still leaks oil...
Got the stud out, used heat and the double nut method.
Can't get it to start but it does leak.
Used red grease on the paper gasket at the cylinder base, hoped it would seal. As soon as my arm and hand heal, I am going to have to tear it out and take it back down. Barring anything real dumb, like a loose head stud or something, is there anyplace else I should be looking for leakage?
First build, thanks in advance. _________________ Keep on Dubbin'! |
boxkiteflyer Samba Member
Joined: May 22, 2008 Posts: 261 Location: Taylorsville, KY
Posted: Mon May 21, 2018 4:46 pm Post subject: Re: Stuck, help needed |
There is a tool that grips studs allowing you to remove them. I have a set of three in different sizes. The tool has fingers that grip around the stud. The fingers operate as mini-cams and get tighter and tighter as you turn the wrench. There are also single cam extractors that work the same but I haven't used those. I'm not talking 'Easy Out' stud extractors... too much work drilling and everything. The stud WILL come out or it will break using the cam function tool. Then you can center punch, drill, etc... |
Posted: Mon May 21, 2018 4:52 pm Post subject: Re: Stuck, help needed |
Are your cylinders leaking?
It could be the oil cooler itself, did you pressure check it yet?. ..there is information about doing this test on Samba. _________________ Never be a follower...Do your own thing, make it your own! |
Posted: Mon May 21, 2018 4:59 pm Post subject: Re: Stuck, help needed |
Bob Brugge wrote: |
Used red grease on the paper gasket at the cylinder base, <<<Well there's your problem right there!
First build, thanks in advance. |
The paper cylinder base gaskets should not be used EVER.
You need to pull the cylinders off the case. Don't remove the pistons from the barrels. Clean the bases and seal them with an RTV sealant.
I used Curil T on my cylinder bases and they leak a little.
If you have leakage on a non running engine. You need to fix it before you move any further forward.
Buy Once, Cry Once!
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Mon May 21, 2018 5:12 pm Post subject: Re: Stuck, help needed |
I would definitely remove the paper gaskets as said above. But before removing the engine, pull off the fan shroud and look around for the leak. It might be the paper gaskets, oil cooler seals, bad cooler itself, or a head stud. How much.of a leak are we talking here?
Like a drip every 5 minutes, or engine is out of oil in 5 minutes? |
jpaull Samba Member
Posted: Mon May 21, 2018 5:39 pm Post subject: Re: Stuck, help needed |
Bob,
Everyone wants to help, but to guess where your leak is coming from is really hard given some things you have attempted.
You gotta take some stuff apart and show pictures. |
Posted: Tue May 22, 2018 9:07 am Post subject: Re: Stuck, help needed |
Pruneman99 wrote: |
Engine out of oil in maybe ten minutes. I will post some pics of the removal and tear down. _________________ Keep on Dubbin'! |
FeelthySanchez Samba Member
Joined: February 03, 2011 Posts: 1349 Location: Now is that a real poncho, or a Sears poncho?
Posted: Tue May 22, 2018 10:05 am Post subject: Re: Stuck, help needed |
Ten minutes is a hemorrhage - as in wrong oil cooler seals, a cracked cooler or engine case. _________________
modok wrote: |
I would like if you had enough clue to communicate what you are doing. |
Ryan Tucker wrote: |
Enough clue..Whats that mean? |
OldIronSpine wrote: |
I'm not sure how compression works.
Turbos don't produce torque, they produce HP. Instead of torque.
The real problem with NA engines is you don't hear the nice whine of the turbo as it spools up.
Before I commit, I'm going to do more research because I don't really know what piston rings are. |
Posted: Tue May 22, 2018 12:37 pm Post subject: Re: Stuck, help needed |
pics as promised, more to come
Posted: Tue May 22, 2018 1:23 pm Post subject: Re: Stuck, help needed |
Out of oil in 10 minutes? Definitely more than a leak. Was the oil cooler known good? A cracked oil cooler or something seriously wrong with the oil cooler seals maybe. Definitely a tear down is going to be needed. Possibly the cam plug?
From the pictures it looks like the firing order might be incorrect but it's hard to see where the wires go behind the cooler duct.
Firing order 1-4-3-2
Engine cylinder layout:
Front of car
3------1
4------2
Rear of car
"Normal" cap layout:
Front of car
---------2
3-_------------ 1
-------- 4
Rear of car
The distributor might be indexed different depending on the distributor and how the drive gear was dropped in but it will always be in the 1-4-3-2 clockwise starting with #1 and the engine on TDC. |
jpaull Samba Member
Posted: Tue May 22, 2018 2:15 pm Post subject: Re: Stuck, help needed |
When I advised for you to take pictures to help identify the problem areas, I was suggesting that you take pictures of the problem areas.
You took pictures of the top of the engine(where we dont see anything thats leaking) and you showed a picture of the ground with oil on it. Not really helping out much. Im just tryin to help you help yourself. |
Posted: Tue May 22, 2018 2:30 pm Post subject: Re: Stuck, help needed |
Try to get pictures of both sides looking up through the pushrod tubes
If the oil cooler is leaking bad it will usually run between cylinders 3-4....but I think others would like to see if your cylinders are leaking since you only used the paper gasket, either way you're gonna have to reseal those cylinders. ..Red RTV high temperature gasket sealer is the best for sealing the cylinder base to case (no paper gasket) _________________ Never be a follower...Do your own thing, make it your own! |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Tue May 22, 2018 2:48 pm Post subject: Re: Stuck, help needed |
I've used the paper gaskets and permatex on every stock engine I have ever built and never had a problem. I use black silicone on all my motors with larger cylinders.
Nothing wrong with the gaskets but you have to use permatex too.....not red grease. _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
Posted: Tue May 22, 2018 4:38 pm Post subject: Re: Stuck, help needed |
Volkswagen had a tsb to not use the paper gaskets and only rtv to avoid cylinder base leaks. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
