croSSeduP Samba Member
Joined: June 13, 2004 Posts: 1106 Location: Western Washington State
Posted: Sun May 20, 2018 6:23 pm Post subject: 48IDA's; Things They Don't Tell You: It's Impossible |
Hey,
First time IDA user here in my '67 Sedan. So, I've discovered that it's impossible to install the 3/4 side carb. No matter what I do I cannot get a hand back there to drop a washer and a nut onto the stud near #3. I've taken the carb top off and still... I can't even get close getting a hand back there to put a washer/nut on the stud to tighten it down. Help? _________________ Please check my '67 sedan project progress!
http://www.thesamba.com/vw/forum/viewtopic.php?t=502253&highlight= |
nsracing Samba Member
Posted: Sun May 20, 2018 6:37 pm Post subject: Re: 48IDA's; Things They Don't Tell You: It's Impossible |
Just because you can't does not mean others can't.
People have been installing IDAs in VWs since way back. You will figure it out. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
Posted: Sun May 20, 2018 6:39 pm Post subject: Re: 48IDA's; Things They Don't Tell You: It's Impossible |
Put the manifold on first with the carb off. Use steel hardware so you can grab them with a magnet if needed. Use jet nuts with a 3/8" hex head. I use a 3/8 swivel socket on a 6" locking extension and a 1/4 drive ratchet. I place a paper towel over the socket and push the nut on. That way it doesn't come off until you tighten it and remove the wrench.
Then install the carb the same way. _________________ Glenn
Member #1009
#BlueSquare
Danwvw Samba Member
Posted: Sun May 20, 2018 6:43 pm Post subject: Re: 48IDA's; Things They Don't Tell You: It's Impossible |
Yeah, that's the secret a little nut. Found some 10mm in 12pt steel nuts that I am going to try! 11mm brass in hex might work but may be a little long to get the sparkplug wrench on. Maybe a 1/4" X 10" flex drive and handle. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
Glenn Mr. 010
Posted: Sun May 20, 2018 6:49 pm Post subject: Re: 48IDA's; Things They Don't Tell You: It's Impossible |
These are all M8 nuts
IDAs in my 74
IDAs in a 67
Member #1009
#BlueSquare |
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Sun May 20, 2018 6:52 pm Post subject: Re: 48IDA's; Things They Don't Tell You: It's Impossible |
OG 36hp shroud helps. |
Glenn Mr. 010
Posted: Sun May 20, 2018 6:55 pm Post subject: Re: 48IDA's; Things They Don't Tell You: It's Impossible |
I cut holes in the fender well so I can access #1 and #3.
I also use NGK BPC6ES plugs which have a 5/8 hex head vs the 13/16 of the BP6ES. This way you have more room to get the socket on.
And again I use a 5/8 deep swivel socket on a 6" locking extension and a 3/8 ratchet.
You see, it's all about using the right tools and a bit of trickery. _________________ Glenn
Member #1009
#BlueSquare |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun May 20, 2018 7:11 pm Post subject: Re: 48IDA's; Things They Don't Tell You: It's Impossible |
Glenn nails it....
My version...
Glenn Mr. 010
Posted: Sun May 20, 2018 7:19 pm Post subject: Re: 48IDA's; Things They Don't Tell You: It's Impossible |
Dale, the locking extension is a worthwhile addition. It prevents the socket from coming off the extension and staying on the nut. _________________ Glenn
Member #1009
#BlueSquare |
jason Samba Member
Posted: Sun May 20, 2018 7:20 pm Post subject: Re: 48IDA's; Things They Don't Tell You: It's Impossible |
I have short manifolds, more fun. I use a coat hanger or small rod too. Put the nut and washer on, put it against stud and slide them down. Easier than trying to get two fingers on them, spin them on with one finger. |
Rome Samba Member
Joined: June 02, 2004 Posts: 9651 Location: Pearl River, NY
Posted: Sun May 20, 2018 7:32 pm Post subject: Re: 48IDA's; Things They Don't Tell You: It's Impossible |
Glenn, I have absolutely no experience with 48IDAs so I'm approaching you for practical experience. But looking at the 4 nuts that hold the carb to each manifold, isn't there just as little space to get the inside two nuts onto the carb-manifold flange bolts due to the closeness of the fan shroud sides? Even with the air filter assembly and base plate completely off it seems this would be another delicate operation, especially the left carb's front inner attachment nut.
The 2nd 48IDA engine photo you posted appears to be John Plow's 2+ liter in his Euro '67. This engine is now for sale on theSamba; built by the same expert that did Glenn's current engine. |
Glenn Mr. 010
Posted: Sun May 20, 2018 7:52 pm Post subject: Re: 48IDA's; Things They Don't Tell You: It's Impossible |
Roland, having the nut wedged into the socket makes it real easy to get it threaded on to the stud. _________________ Glenn
Member #1009
#BlueSquare |
74 Thing Samba Member
Posted: Sun May 20, 2018 9:52 pm Post subject: Re: 48IDA's; Things They Don't Tell You: It's Impossible |
They make magnets for sockets too so that the fastener won't fall out
https://mrotools.com/522-lang-magnetic-socket-inse...glirvd_bwe
I usually just tear off a small piece of duct tape or gorilla tape and roll it into a ball and put it in my 3/8" socket. |
sled Samba Member
Posted: Sun May 20, 2018 10:02 pm Post subject: Re: 48IDA's; Things They Don't Tell You: It's Impossible |
honestly it totally depends on what manifolds you are using... _________________ drive your split. |
Posted: Sun May 20, 2018 10:03 pm Post subject: Re: 48IDA's; Things They Don't Tell You: It's Impossible |
Glenn wrote: |
Then install the carb the same way. |
Glenn - Thanks for this will give this a try. If problems may I PM you? BTW, I'm using stock dog house fan shroud and have the Berg 1 5/8" heater box merged exhaust. Peace.
TG _________________ Please check my '67 sedan project progress!
Posted: Sun May 20, 2018 10:08 pm Post subject: Re: 48IDA's; Things They Don't Tell You: It's Impossible |
nsracing wrote: |
That's the reason for the "things they don't tell you".
richierich Samba Member
Posted: Mon May 21, 2018 1:46 am Post subject: Re: 48IDA's; Things They Don't Tell You: It's Impossible |
Remove the decklid and hinges. Big help. |
Glenn Mr. 010
Posted: Mon May 21, 2018 5:18 am Post subject: Re: 48IDA's; Things They Don't Tell You: It's Impossible |
britegreenVWSB wrote: |
Glenn wrote: |
TG |
Sure.... I have a stock fan shroud. _________________ Glenn
Member #1009
#BlueSquare |
jeff68 Samba Member
Joined: November 02, 2007 Posts: 298 Location: Sarasota, Florida
Posted: Mon May 21, 2018 5:21 am Post subject: Re: 48IDA's; Things They Don't Tell You: It's Impossible |
One thing that no one mentioned that you need no matter which method or combination of tools you choose. PATIENCE! These kinds of situations require it! Just take your time and you'll get it. |
Posted: Mon May 21, 2018 6:08 am Post subject: Re: 48IDA's; Things They Don't Tell You: It's Impossible |
Glenn wrote: |
Dale, the locking extension is a worthwhile addition. It prevents the socket from coming off the extension and staying on the nut. |
It has a lock(sort of) see the little black button on side it holds socket more securely than typical spring/ball concept... Any way have not yet had problem losing socket...
