Ricksurfin Samba Member
Joined: September 02, 2017 Posts: 295 Location: Huntington Beach, CA
Posted: Sun May 20, 2018 7:24 pm Post subject: 1974 Ignition switch removal |
I need help figuring out how to remove my ignition switch so I can replace the electrical portion. Everything I read says there should be a plate with two screws that you remove and then you can slide the entire ignition switch out, but on my 1974 I see no screws or plate, so I can’t figure out to remove it.
Here is a picture of what I have:
Posted: Sun May 20, 2018 7:51 pm Post subject: Re: 1974 Ignition switch removal |
I just pulled the plate that goes across from lock cylinder to center, but it didn’t release the ignition cylinder portion. |
FeelthySanchez Samba Member
Joined: February 03, 2011 Posts: 1349 Location: Now is that a real poncho, or a Sears poncho?
Posted: Sun May 20, 2018 8:00 pm Post subject: Re: 1974 Ignition switch removal |
Might try removing that big ol' snap ring.
No stabilizer used here, so maybe take a Dramamine: https://www.youtube.com/watch?v=ppMwQTcp3f4 _________________
modok wrote: |
I would like if you had enough clue to communicate what you are doing. |
Ryan Tucker wrote: |
Enough clue..Whats that mean? |
OldIronSpine wrote: |
I'm not sure how compression works.
Turbos don't produce torque, they produce HP. Instead of torque.
The real problem with NA engines is you don't hear the nice whine of the turbo as it spools up.
Before I commit, I'm going to do more research because I don't really know what piston rings are. |
Posted: Sun May 20, 2018 8:42 pm Post subject: Re: 1974 Ignition switch removal |
Prior to the video you linked starting, it looks like the snap ring and plastic collar have been removed. I guess I’ll remove the snap ring and see if the collar can then be removed. Don’t like the fact that he says in the video that he pounded it with a hammer and a screwdriver to remove it. Hopefully I don’t need to force it off. |
vwoldbug Samba Member
Posted: Sun May 20, 2018 9:30 pm Post subject: Re: 1974 Ignition switch removal |
There is bolt a under the plastic housing , it's either a sheer anti theft bolt to remove or a 6 mm Allen head bolt . Then remove the plastic sleeve and then unhook the electrical plugs . You should be able to remove the switch housing to get the screw out for the ignition switch . Do you have a Bentley manual and good luck . It's not bad to do . You don't remove the snap ring . |
Al Capulco Samba Member
Joined: October 31, 2005 Posts: 532 Location: Northridge, CA.
Posted: Sun May 20, 2018 10:54 pm Post subject: Re: 1974 Ignition switch removal |
You need to drill a small hole in the housing to release the lock cylinder. Do a search to get the necessary measurements. |
Posted: Mon May 21, 2018 6:54 am Post subject: Re: 1974 Ignition switch removal |
vwoldbug wrote: |
I removed the 6mm bolt, but still can’t get the assembly to come off. Is there something else attaching it? I,ve removed all wire connectors and the washer tubing.
I’m thinking that circlip needs to come off, but don’t want to start taking things apart if I don’t need to. |
Posted: Mon May 21, 2018 8:01 am Post subject: Re: 1974 Ignition switch removal |
Success!! After removing snap ring and collar, I was able to remove the upper portion and access the switch. Now, all I need to do is find a replacement electric portion of switch and run a new wire from fuse panel to coil. I’m trying to figure out the best way to do that, and I have a separate thread going on that.
Thanks to all! |
