newt374 Samba Member
Joined: January 13, 2008 Posts: 13 Location: Rochester, NY
Posted: Sun May 20, 2018 9:04 pm Post subject: New build 1641 3&1 not firing |
Hi have a 1641 new build w110 cam 040 mofoco heads. I have spark at the end of the wires. New plugs, also swapped plugs w a cylinder that had a hot exhaust pipe. |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sun May 20, 2018 9:08 pm Post subject: Re: New build 1641 3&1 not firing |
What induction do you have, and do you have compression on those cylinders? _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Sun May 20, 2018 9:25 pm Post subject: Re: New build 1641 3&1 not firing |
It has brand new dual kadron set up from the kaddie shack. I have to barrow a compression tester |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Sun May 20, 2018 9:32 pm Post subject: Re: New build 1641 3&1 not firing |
Go back and check your valve adjustment again. Do all the adjuster screws look about even on the nut/threads ? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Sun May 20, 2018 9:38 pm Post subject: Re: New build 1641 3&1 not firing |
I checked 3&4 and they were correct. |
Posted: Sun May 20, 2018 9:42 pm Post subject: Re: New build 1641 3&1 not firing |
Had to go to work didn’t have time to check 1&2. |
Posted: Sun May 20, 2018 10:05 pm Post subject: Re: New build 1641 3&1 not firing |
Swap the spark plug wires on #1 and #3 and see what that does. |
busdaddy Samba Member
Posted: Sun May 20, 2018 10:27 pm Post subject: Re: New build 1641 3&1 not firing |
Kadrons won't idle on 4 cylinders unless you have a balance pipe between the manifolds, ain't aftermarket stuff fun? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tcash Samba Member
Posted: Sun May 20, 2018 10:58 pm Post subject: Re: New build 1641 3&1 not firing |
Switch the plug wires as suggested.
Here is a vid on the Kadron's
Good luck
Tcash |
Posted: Sun May 20, 2018 11:17 pm Post subject: Re: New build 1641 3&1 not firing |
busdaddy wrote: |
Kadrons won't idle on 4 cylinders unless you have a balance pipe between the manifolds, ain't aftermarket stuff fun? |
Jeff offers good support in my experience. Pretty straight forward carbs that are easy to make jet changes to. I haven’t found mine to be any more cantankerous than a 34 PICT 3. _________________ If you haven't bled on them, you haven't worked on them.
Posted: Mon May 21, 2018 12:27 am Post subject: Re: New build 1641 3&1 not firing |
I did swap the plug wires at the cap. Just checked lash on 1&2 they are good. I have a feeling I may not have done the cylinder shim spacing correctly the compression test tomorrow will show what’s up. It’s the only thing I can think of. |
Abscate Samba Member
Posted: Mon May 21, 2018 4:01 am Post subject: Re: New build 1641 3&1 not firing |
TomWesty wrote: |
busdaddy wrote: |
Jeff offers good support in my experience. Pretty straight forward carbs that are easy to make jet changes to. I haven’t found mine to be any more cantankerous than a 34 PICT 3. |
For a device that operates on pressure differences, That’s a low bar.
I kill myself, sometimes. _________________ .ssS! |
Zed999 Samba Member
Posted: Mon May 21, 2018 4:09 am Post subject: Re: New build 1641 3&1 not firing |
busdaddy wrote: |
This. Single barrel carbs need a balance pipe on a flat 4 engine. The more cam the greater the need. It's the firing order/valve timing, the second cylinder on each side sucks in exhaust from the first so 3 and 1 don't fire. |
Posted: Mon May 21, 2018 4:23 am Post subject: Re: New build 1641 3&1 not firing |
Just did compression test 2&4 @ 115 lbs 1&3 @ 108 lbs |
Tcash Samba Member
Posted: Mon May 21, 2018 5:44 am Post subject: Re: New build 1641 3&1 not firing |
newt374 wrote: |
1&3 should fire with 108 and you can expect those numbers to come up as the rings break in. |
Posted: Tue May 22, 2018 1:23 am Post subject: Re: New build 1641 3&1 not firing |
I’m going to get some hose barbs to hook the vacuum ports together on the intake manifolds. |
