guzzirider Samba Member
Joined: May 01, 2005 Posts: 107 Location: Durango CO at last
Posted: Mon May 21, 2018 7:26 pm Post subject: wiring a tach wirg electroninc ignition |
I want to install this tach
it is 12 V but no idea on how to wire it up. I assume a 12V lead goes to 12v terminal but other 2 ?? and I have pernotix electronic ignition
any help appreciated
_________________ 69 doublecab with 2" lift
Suzuki DR650
2016 Dodge Crew 1500 4x4 |
mukluk Samba Member
Posted: Mon May 21, 2018 7:34 pm Post subject: Re: wiring a tach wirg electroninc ignition |
I can see +12 above the first terminal and +6 above the empty slot, but cannot see what is above the two terminals on the right. What do they have moulded into the plastic above them?
Tachometers usually need power in, a ground, and a signal wire from the negative side of the coil. If the tach has backlighting, there will also be a power input for that bulb. The ground may be a separate wire, or it may be a chassis ground from the instrument to the mounting surface. _________________ 1960 Ragtop w/Semaphores "Inga" |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Mon May 21, 2018 7:38 pm Post subject: Re: wiring a tach wirg electroninc ignition |
I'm away from the vW right now, but believe that my VDO tach - in use since 1977 - has 12 volt positive, connector to coil negative side (terminal #1), dash light illumination, and a ground wire. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
herbie1200 Samba Member
Joined: April 27, 2006 Posts: 833 Location: Rome - Italy
Posted: Mon May 21, 2018 11:07 pm Post subject: Re: wiring a tach wirg electroninc ignition |
Verify if one of the two terminals has 0 ohms (continuity) to the metal; this terminal should probabily be the "-" terminal.
Your photo is not full inclusive; if there is another ground spade terminal it is the "-" |
Meiang Samba Member
Joined: September 27, 2016 Posts: 656 Location: Perth, Western Australia
Posted: Tue May 22, 2018 1:03 am Post subject: Re: wiring a tach wirg electroninc ignition |
The other two terminals are "1" next to the screw and "-" far right.
"1" connects to terminal 1 or -ve on the coil and "-" goes to ground. |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Tue May 22, 2018 4:30 am Post subject: Re: wiring a tach wirg electroninc ignition |
Awesome DOKA ! |
Posted: Tue May 22, 2018 6:37 am Post subject: Re: wiring a tach wirg electroninc ignition |
Thanks you. Does it matter that I have electronic points replacement.
12V goes to gauge power
next goes to - on coil
and one furthest from one marked 12V goes to ground
I have had DOKA for 26 yrs. It was originally the parts runner for VW dealer in Abilene TX. My college ROTC buddy bought it from the dealer while stationed with AF in TX. It was shipped to Philippines with an AF move and spent 4 yrs there. My friend had it painted those crazy PI taxicab colors while there. ( looks to have had slight nose damage there) Shipped back to US. My friend died in a AF C-130 crash in Idaho in 1990s. I bought it from his estate.
there is a place above gauge for light bulb _________________ 69 doublecab with 2" lift
Suzuki DR650
Meiang Samba Member
Posted: Tue May 22, 2018 8:23 am Post subject: Re: wiring a tach wirg electroninc ignition |
The "1" terminal should go to the coil irrespective whether you are using points or an electonic ignition module. |
Posted: Sat May 26, 2018 2:23 pm Post subject: Re: wiring a tach wirg electroninc ignition |
got the DOKA wired sort of
the tach works great
need to work on dash lights and fuel gauage
Thanks Guys _________________ 69 doublecab with 2" lift
Suzuki DR650
