Ofir Samba Member
Joined: September 26, 2005 Posts: 460 Location: Israel
Posted: Tue May 22, 2018 2:05 am Post subject: Ignition switch euro beetle 1966 or type 3. 111 905 865 B |
Hi,
I have euro bug 1966, it has KOLB ignition switch. (I found that this ignition switch can found also at early type 3)
I am looking for Ignition switch for euro beetle 1966. or early type 3.
KOLB early original switch
Where I can find it please? WTB placed at thesamba
Thanks
mukluk Samba Member
Ofir Samba Member
Posted: Tue May 22, 2018 2:11 pm Post subject: Re: Ignition switch euro beetle 1966 or type 3. KOLB |
Thanks for the part number 111-905-865E
Yet, it will not fit KOLB steering column ignition switch, but others,
Look on the pictures, they are different. |
Ofir Samba Member
Posted: Tue Jun 19, 2018 9:25 am Post subject: Re: Ignition switch euro beetle 1966 or type 3. 111905865B |
I found the part number: 111 905 865 B / 111905865B
Thanks
Karmannut Samba Member
Joined: August 05, 2007 Posts: 139 Location: North Canton Ohio
Posted: Sun Jun 24, 2018 6:47 am Post subject: Re: Ignition switch euro beetle 1966 or type 3. 111 905 865 B |
if you find them available or anyone else knows where to find them there are others of us looking for them too
https://www.thesamba.com/vw/forum/viewtopic.php?p=8719426&highlight=#8719426 _________________ Rupert- 64 Sea Blue Beetle with 66 Dove Lodgette tent
Bunny- 84 grey Rabbit Convertible
Pepper-18 Habanero Orange Beetle SE Premium
Air and Water do mix! |
Ofir Samba Member
Posted: Mon Jun 25, 2018 1:02 pm Post subject: Re: Ignition switch euro beetle 1966 or type 3. 111 905 865 B |
I found 2 NOS from germany, if you need, or someone else, please contact me thru messages.
They will fit all euro steering locks with 28mm electrical portion ignition switch, except "KOLB" steering lock.
I found that only "KOLB" use BIG CROSS electrical portion ignition switch, while all others use SMALL CROSS.
62ItalianRagtop Samba Member
Käfer63 Samba Member
Posted: Fri Aug 27, 2021 3:30 am Post subject: Re: Ignition switch euro beetle 1966 or type 3. 111 905 865 B |
Hello, I am also looking for the 28mm Kolb Zündschalter ( ignition switch ?).
Could you please Tell ne, where you bought yours a few years ago. 🙄
Thank You very much. |
Posted: Fri Aug 27, 2021 3:43 am Post subject: Re: Ignition switch euro beetle 1966 or type 3. 111 905 865 B |
Käfer63 wrote: |
Have you a picture of your steering lock ? Is it marked neimann or vw ? _________________ LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
http://tettodistraccio.blogspot.com/ |
Posted: Fri Aug 27, 2021 5:42 am Post subject: Re: Ignition switch euro beetle 1966 or type 3. 111 905 865 B |
[quote="62ItalianRagtop"]
Käfer63 wrote: |
Have you a picture of your steering lock ? Is it marked neimann or vw ?[
It‘s the Kolb Version only marked with VW
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
